在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
楼主: haimag
[资料] cortex-m0设计开始了吗?提供一些cortex-m0的资料, 希望有帮助
发表于 2014-11-7 14:49:37 | 显示全部楼层
好东西  谢谢啦
发表于 2015-3-13 18:49:54 | 显示全部楼层
M0+ SoftCore
发表于 2015-3-13 19:04:03 | 显示全部楼层
││IPXACT_lib.pm        52.81 KB
│└─logical        (5 folders, 0 files, 0 bytes, 2.17 MB in total.)
│├─cm0p_cti        (1 folders, 0 files, 0 bytes, 108.69 KB in total.)
││└─verilog        (0 folders, 1 files, 108.69 KB, 108.69 KB in total.)
││CM0PCTI.v        108.69 KB
│├─cm0p_dap        (1 folders, 0 files, 0 bytes, 307.41 KB in total.)
││└─verilog        (0 folders, 13 files, 307.41 KB, 307.41 KB in total.)
││CM0PDAP.v        6.29 KB
││cm0p_dap_ap.v        5.41 KB
││cm0p_dap_ap_cdc.v        5.71 KB
││cm0p_dap_ap_mast.v        33.15 KB
││cm0p_dap_ap_mast_defs.v        2.78 KB
││cm0p_dap_dp.v        14.86 KB
││cm0p_dap_dp_cdc.v        6.36 KB
││cm0p_dap_dp_jtag.v        69.16 KB
││cm0p_dap_dp_jtag_defs.v        4.04 KB
││cm0p_dap_dp_pwr.v        7.25 KB
││cm0p_dap_dp_sw.v        120.51 KB
││cm0p_dap_dp_sw_defs.v        10.70 KB
││cm0p_dap_top.v        21.17 KB
│├─cm0p_integration        (2 folders, 0 files, 0 bytes, 856.80 KB in total.)
││├─cssoc        (3 folders, 0 files, 0 bytes, 744.00 KB in total.)
│││├─config        (0 folders, 1 files, 253 bytes, 253 bytes in total.)
││││default_cfg.conf        253 bytes
│││├─include        (0 folders, 1 files, 7.23 KB, 7.23 KB in total.)
││││cortexm0plusintegrationcs_macros.hs        7.23 KB
│││└─pil_m0plus        (1 folders, 0 files, 0 bytes, 736.53 KB in total.)
│││└─pil_cortexm0plus_default_cfg        (3 folders, 5 files, 543.66 KB, 736.53 KB in total.)
││││fabric_config_stitchercore.xml        1.76 KB
││││pil_cortexm0plus_default_cfg.adg        506.97 KB
││││pil_cortexm0plus_default_cfg_design.xml        21.68 KB
││││pil_cortexm0plus_default_cfg_report.xml        10.99 KB
││││render.csh        2.27 KB
│││├─cxapbic_2Sx7M_config        (0 folders, 3 files, 15.52 KB, 15.52 KB in total.)
││││cxapbic_2Sx7M_config.xml        14.79 KB
││││cxapbic_2Sx7M_config.xml.checksum        25 bytes
││││render.csh        727 bytes
│││├─dap_ss_default_system_config        (1 folders, 5 files, 74.24 KB, 75.35 KB in total.)
│││││dap_ss_default_system.adg        51.57 KB
│││││dap_ss_default_system_design.xml        9.26 KB
│││││dap_ss_default_system_report.xml        9.89 KB
│││││fabric_config_stitchercore.xml        1.68 KB
│││││render.csh        1.83 KB
││││└─cxdapbusic_1x4_config        (0 folders, 3 files, 1.11 KB, 1.11 KB in total.)
││││cxdapbusic_1x4_config.xml        380 bytes
││││cxdapbusic_1x4_config.xml.checksum        25 bytes
││││render.csh        735 bytes
│││└─pil_ss_m0plus_config        (0 folders, 5 files, 102.00 KB, 102.00 KB in total.)
│││fabric_config_stitchercore.xml        1.65 KB
│││pil_ss_m0plus.adg        79.12 KB
│││pil_ss_m0plus_design.xml        9.42 KB
│││pil_ss_m0plus_report.xml        10.27 KB
│││render.csh        1.54 KB
││└─verilog        (0 folders, 6 files, 112.80 KB, 112.80 KB in total.)
││CM0PINTEGRATION.v        27.42 KB
││cm0p_ahb_cs_rom_table.v        11.49 KB
││cm0p_csi_ahb_interconnect.v        5.18 KB
││cm0p_wic.v        9.94 KB
││CM0PMTBINTEGRATION.v        25.16 KB
││CORTEXM0PLUSINTEGRATIONCS.v        33.61 KB
│├─cortexm0plus        (1 folders, 0 files, 0 bytes, 840.67 KB in total.)
││└─verilog        (0 folders, 15 files, 840.67 KB, 840.67 KB in total.)
││cm0p_core.v        422.37 KB
││cm0p_dbg_bpu.v        12.76 KB
││cm0p_dbg_ctl.v        20.94 KB
││cm0p_dbg_dwt.v        15.58 KB
││cm0p_dbg_if.v        23.25 KB
││cm0p_dbg_sel.v        31.86 KB
││cm0p_matrix.v        29.28 KB
││cm0p_matrix_sel.v        28.28 KB
││cm0p_mpu.v        33.88 KB
││cm0p_nvic.v        92.78 KB
││cm0p_top.v        30.62 KB
││cm0p_top_clk.v        5.06 KB
││cm0p_top_dbg.v        24.32 KB
││cm0p_top_sys.v        52.85 KB
││CORTEXM0PLUS.v        16.83 KB
│└─models        (4 folders, 0 files, 0 bytes, 107.63 KB in total.)
│├─cells        (1 folders, 0 files, 0 bytes, 61.90 KB in total.)
││└─generic        (0 folders, 20 files, 61.90 KB, 61.90 KB in total.)
││cm0p_acg.v        2.22 KB
││cm0p_dap_cdc_capt_sync.v        4.19 KB
││cm0p_dap_cdc_comb_and.v        2.22 KB
││cm0p_dap_cdc_comb_and_addr.v        2.25 KB
││cm0p_dap_cdc_comb_and_data.v        2.25 KB
││cm0p_dap_cdc_send.v        3.94 KB
││cm0p_dap_cdc_send_addr.v        4.00 KB
││cm0p_dap_cdc_send_data.v        4.00 KB
││cm0p_dap_cdc_send_reset.v        3.48 KB
││cm0p_dap_jt_cdc_comb_and.v        2.23 KB
││cm0p_dap_sw_cdc_capt_reset.v        2.91 KB
││cm0p_dap_sw_cdc_capt_sync.v        3.97 KB
││cm0p_dbg_reset_sync.v        2.67 KB
││cm0p_pmu_acg.v        2.23 KB
││cm0p_pmu_cdc_send_reset.v        3.42 KB
││cm0p_pmu_cdc_send_set.v        3.41 KB
││cm0p_pmu_sync_reset.v        3.54 KB
││cm0p_pmu_sync_set.v        3.53 KB
││cm0p_rst_send_set.v        2.33 KB
││cm0p_rst_sync.v        3.11 KB
│├─cpf        (0 folders, 2 files, 12.35 KB, 12.35 KB in total.)
││CM0PINTEGRATION.cpf        6.23 KB
││CORTEXM0PLUSIMP.cpf        6.11 KB
│├─upf        (0 folders, 2 files, 15.63 KB, 15.63 KB in total.)
││CM0PINTEGRATION.upf        8.28 KB
││CORTEXM0PLUSIMP.upf        7.35 KB
│└─wrappers        (0 folders, 1 files, 17.75 KB, 17.75 KB in total.)
│CORTEXM0PLUSIMP.v        17.75 KB
发表于 2015-7-6 17:23:10 | 显示全部楼层
对 eetop.cn_LPC1114_CodeBase_v0.8.0.zip 感兴趣,下来看看,谢谢分享
发表于 2016-3-6 09:33:20 | 显示全部楼层
看看,不错
发表于 2016-3-30 13:53:58 | 显示全部楼层
发表于 2016-8-24 16:22:17 | 显示全部楼层
发表于 2016-8-24 16:23:02 | 显示全部楼层
发表于 2018-12-21 15:12:07 | 显示全部楼层
发表于 2019-1-3 16:03:20 | 显示全部楼层
有没有M3的
GMT+8, 2024-4-26 09:22 , Processed in 0.034232 second(s), 5 queries , Gzip On, Redis On.
