查看: 68815|回复: 213
Antenna-Magus Professional
发表于 2012-2-1 18:06:20 | 显示全部楼层 |阅读模式
Antenna Magus is actually nothing like any other antenna design software product. It takes on a completely new approach to designing antennas. You may have seen other "Antenna  design software" tools that are intended to assist engineers with antenna design but aren't really that useful since many of them consist  of a very small selection of known antennas that can only be designed for a limited set of objectives over a small range of input parameters.
ALL PART FROM 01 TO 21 WITH sERIAL NUMBERS
Antenna-Magus(Professional).part01.rar (14 MB , 下载次数: 1649 )
Antenna-Magus(Professional).part02.rar (14 MB , 下载次数: 1125 )
Antenna-Magus(Professional).part03.rar (14 MB , 下载次数: 1130 )
Antenna-Magus(Professional).part04.rar (14 MB , 下载次数: 1062 )
Antenna-Magus(Professional).part05.rar (14 MB , 下载次数: 1139 )
TO BE CONTINUED ...
 楼主| 发表于 2012-2-1 18:47:46 | 显示全部楼层
PART 06 to 11
Antenna-Magus(Professional).part06.rar (14 MB , 下载次数: 940 )
Antenna-Magus(Professional).part07.rar (14 MB , 下载次数: 892 )
Antenna-Magus(Professional).part08.rar (14 MB , 下载次数: 994 )
Antenna-Magus(Professional).part09.rar (14 MB , 下载次数: 1163 )
Antenna-Magus(Professional).part10.rar (14 MB , 下载次数: 955 )
Antenna-Magus(Professional).part11.rar (14 MB , 下载次数: 969 )
 楼主| 发表于 2012-2-1 19:46:20 | 显示全部楼层
PART 12 TO 17
Antenna-Magus(Professional).part12.rar (14 MB , 下载次数: 954 )
Antenna-Magus(Professional).part13.rar (14 MB , 下载次数: 1237 )
Antenna-Magus(Professional).part14.rar (14 MB , 下载次数: 1104 )
Antenna-Magus(Professional).part15.rar (14 MB , 下载次数: 1070 )
Antenna-Magus(Professional).part16.rar (14 MB , 下载次数: 837 )
Antenna-Magus(Professional).part17.rar (14 MB , 下载次数: 830 )
 楼主| 发表于 2012-2-1 20:08:34 | 显示全部楼层
FINAL PARTS 18 TO 21
Antenna-Magus(Professional).part18.rar (14 MB , 下载次数: 864 )
Antenna-Magus(Professional).part19.rar (14 MB , 下载次数: 897 )
Antenna-Magus(Professional).part20.rar (14 MB , 下载次数: 960 )
Antenna-Magus(Professional).part21.rar (4.52 MB , 下载次数: 794 )
发表于 2012-2-2 01:11:49 | 显示全部楼层
1. 360报告说有木马
2. 关掉360来安装,所提供的SN无地方应用,希望提供较详细安装lic过程,谢谢
 楼主| 发表于 2012-2-2 03:17:14 | 显示全部楼层
hi fengsui
i have karspersky with original license, i must verify again tomorrow but thanks for reporting
for the installation is simple just put the SN in installation (it work fine for me)
antenna_sn.rar (119 Bytes , 下载次数: 694 )
发表于 2012-2-2 03:57:58 | 显示全部楼层
which version is it?
发表于 2012-2-2 16:49:16 | 显示全部楼层
回复 6# nassim
我主要是不知在哪一步可以用到SN,在安装时设置LIC时有三种选择,automaticlly retrieve;Manually;Floating.
第一个自动设置要输入一个注册码,好像不是SN的格式,第二个手动设置需要一个lic文件,那个SN文件也不可以;第三个用浮动lic,需要设置lic服务器,乱选一个可以使得安装继续进行(前两个选项都不能让安装进行下去)。安装完后因为没有lic服务器,还是没法启动,在lic设置时sn还是没地方可以正确输入。
望指教,谢谢!
发表于 2012-2-3 12:35:40 | 显示全部楼层
antenna_sn.rar (119 Bytes) 这个文件怎么用?
发表于 2012-2-6 11:10:56 | 显示全部楼层
那个版本呀
GMT+8, 2025-12-25 06:29 , Processed in 0.025584 second(s), 7 queries , Gzip On, Redis On.
