Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_0_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_10_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_11_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_12_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_13_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_14_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_15_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_16_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_17_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_18_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_1_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_2_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_3_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_4_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_5_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_6_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_7_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_8_~output" must drive a top-level pin
Error: Output port O of I/O output buffer "pre_syn.bp.sub8_u2_lookup_gray_9_~output" must drive a top-level pin
Error: Quartus II Analysis & Synthesis was unsuccessful. 19 errors, 99 warnings
Error: Peak virtual memory: 464 megabytes
Error: Processing ended: Thu Oct 27 19:14:18 2011
Error: Elapsed time: 00:26:20
Error: Total cpu time (on all processors): 00:26:18
Error: Quartus II Full Compilation was unsuccessful. 21 errors, 99 warnings
以后再运行每次都这样,
敬请各路高手指点,小生不尽感谢!
