在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 2264|回复: 0
[讨论] 专家解析雅思作文高效结尾法
发表于 2011-7-4 13:38:52 | 显示全部楼层 |阅读模式
 专家解析雅思作文高效结尾法。我们要注意的是结尾段由三个要素组成,其中第2个要素是必须的 ,但是句子的数量可以是3句也可以是2句甚至1个句子。首先我们来看一个例子:
  I agree that we need to make sure that animals that are used for testing new products have the minimum of suffering. However, I am convinced that animal testing is necessary, and that it will continue to benefit humans in new and wonderful ways.
  上面这个例句中,作者将自己的观点隐藏在了一个宾语从句之后,起到了一个欲扬先抑的效果。但是这种效果必须搭配一个展望未来才能起到渲染的效果。我们来对比另外一个例子:
  In conclusion, physical punishment can be a useful method of discipline. However, it should be the last choice for parents. If we want to build a world with less violence we must begin at home, and we must teach our children to be responsible.
  大家不难发现,2个句子都使用了相似的衔接方式,即首句委婉地回顾全文,将观点的对立面用"让步"的方式表达出来,同时也是对于主体段观点的回顾。然后再是用转折阐述自己的看法和观点。最后再用一个对于未来的期望来支撑自己的观点。分析认为,这种顺序安排的优点在于对于文章的主体有很好的总结,但同时观点又是非常鲜明有力的,加上对于未来的润色,使得表达更流畅。用同样的方法,我们再来看第三个例句:
  To sum up, although there are undoubtedly some problems with increased levels of education, I feel strongly that the country can only progress if all its people are educated to the maximum of their ability.
  和前2个结尾不同,第三个结尾尽管也是先回顾了全文,但是它将作者的观点和对未来的期望写在了一个条件状语从句里。如此就给出了我们在构造"展望未来"时的一个思路,即搭配条件状语从句或者介宾短语跟在观点句之后。此种结尾发展方式同样适用于分析解决型大作文的结尾段布局,比如:
  All in all, although the problem of drugs may seem impossible to eliminate, there are concrete steps that can be taken to weaken the hold of drugs on society. The danger from drugs is too great to ignore.
  对于毒品对社会的危害,作者先是承认现状的无法改变,进而乐观地阐述了自己的观点即采取了切实有效的行动后可以减弱其危害。最后用毒品的危害性来对未来作展望。换句话说,在社会类分析解决型议论文中,我们在展望未来时可以考虑用强调其长远的影响作为突破口。又如:
  In short, there are several things that the government can do to allow more people to finish school. However, a number of society attitudes also have to change if the country's people are to achieve their full potential.
  这个结尾的题目是讨论辍学这一社会现象导致的问题和解决方案的。我们发现使用前面提到的条件状语从句也可以作为这类题材结尾的重要句型。来源:365前程网
GMT+8, 2024-4-27 02:29 , Processed in 0.017030 second(s), 8 queries , Gzip On, Redis On.
