【资料原名】:MIMO-OFDM Wireless Communications with MATLAB
【原书作者】:Yong Soo Cho, Jaekwon Kim, Won Young Yang, Chung G. Kang
【阅读语言】:English
【页数 】:439
【出版社】 :John Wiley & Sons
【出版日期】:2010
【文件格式】:pdf
【目录】:
CHAPTER 1: THE WIRELESS CHANNEL : PROPAGATION AND FADING
1.1 LARGE-SCALE FADING
1.1.1 General Path Loss Model
1.1.2 Okumura/Hata Model
1.1.3 IEEE 802.16d Model
1.2 SMALL-SCALE FADING
1.2.1 Parameters for Small-Scale Fading
1.2.2 Time-Dispersive vs. Frequency-Dispersive Fading
1.2.3 Statistical Characterization and Generation of Fading Channel
CHAPTER 2: SISO CHANNEL MODELS
2.1 INDOOR CHANNEL MODELS
2.1.1 General Indoor Channel Model
2.1.2 IEEE 802.11 Channel Model
2.1.3 Saleh-Velenzuela (S-V) Channel Model
2.1.4 UWB Channel Model
2.2 OUTDOOR CHANNEL MODELS
2.2.1 FWGN Model
2.2.2 Jakes Model
2.2.3 Ray-Based Channel Model
2.2.4 Frequency-Selective Fading Channel Model
2.2.5 SUI Channel Model
CHAPTER 3: MIMO CHANNEL MODELS
3.1 STATISTICAL MIMO MODEL
3.1.1 Spatial Correlation
3.1.2 PAS Model
3.2 I-METRA MIMO CHANNEL MODEL
3.2.1 Statistical Model of Correlated MIMO Fading Channel
3.2.2 Generation of Correlated MIMO Channel Coefficients
3.2.3 I_METRA MIMO Channel Model
3.2.4 3GPP MIMO Channel Model
3.3 SCM MIMO CHANNEL MODEL
3.3.1 SCM Link-Level Channel Parameters
3.3.2 SCM Link-Level Channel Modeling
3.3.3 Spatial Correlation of Ray-Based Channel Model
CHAPTER 4: INTRODUCTION TO OFDM
4.1 SINGLE-CARRIER VS. MULTI-CARRIER TRANSMISSION
4.1.1 Single-Carrier Transmission
4.1.2 Multi-Carrier Transmission
4.1.3 Single-Carrier vs. Multi-Carrier Transmission
4.2 Basic PRINCIPLE OF OFDM
4.2.1 OFDM Modulation and Demodulation
4.2.2 OFDM Guard Interval
4.2.3 OFDM Guard Band
4.2.4 BER of OFDM Scheme
4.2.5 Water-Filling Algorithm for Frequency-domain Link Adaptation
4.3 CODED OFDM
4.4 OFDMA: MULTIPLE ACCESS EXTENSIONS OF OFDM
4.4.1 Resource Allocation - Subchannel Allocation Types
4.4.2 Resource Allocation - Subchannelization
4.5 DUPLEXING
CHAPTER 5: SYNCHRONIZATION FOR OFDM
5.1 EFFECT OF STO
5.2 EFFECT OF CFO
5.2.1 Effect of Integer Carrier Frequency Offset (IFO)
5.2.2 Effect of Fractional Carrier Frequency Offset (FFO)
5.3 ESTIMATION TECHNIQUES FOR STO
5.3.1 Time-Domain Estimation Techniques for STO
5.3.2 Frequency-Domain Estimation Techniques for STO
5.4 ESTIMATION TECHNIQUES FOR CFO
5.4.1 Time-Domain Estimation Techniques for CFO
5.4.2 Frequency-Domain Estimation Techniques for CFO
5.5 EFFECT OF SAMPLING CLOCK OFFSET
5.5.1 Effect of Phase Offset in Sampling Clocks
5.5.2 Effect of Frequancy Offset in Sampling Clocks
5.6 COMPENSATION FOR SAMPLING CLOCK OFFSET
5.7 SYNCHRONIZATION IN CELLULAR SYSTEMS
5.7.1 Downlink Synchronization
5.7.2 Uplink Synchronization
CHAPTER 6: CHANNEL ESTIMATION
6.1 PILOT STRUCTURE
6.1.1 Block Type
6.1.2 Comb Type
6.1.3 Lattice Type
6.2 CHANNEL ESTIMATION BASED ON TRAINING SYMBOL
6.2.1 LS Channel Estimation
6.2.2 MMSE Channel Estimation
6.3 DFT-BASED CHANNEL ESTIMATION
6.4 DECISION-DIRECTED CHANNEL ESTIMATION
6.5 ADVANCED CHANNEL ESTIMATION TECHNIQUES
6.5.1 Channel Estimation Using a Superimposed Signal
6.5.2 Channel Estimation in Fast Time-Varying Channels
6.5.3 EM (Expectation-Maximation) Channel Estimation
6.5.4 Blind Channel Estimation
CHAPTER 7: PAPR REDUCTION
7.1 INTRODUCTION TO PAPR
7.1.1 Definition of PAPR
7.1.2 Distribution of OFDM Signal
7.1.3 PAPR and Oversampling
7.1.4 Clipping and SQNR
7.2 PAPR REDUCTION TECHNIQUES
7.2.1 Clipping and Filtering
7.2.2 PAPR Reduction Code
7.2.3 Selective Mapping
7.2.4 Partial Transmit Sequence
7.2.5 Tone Reservation
7.2.6 Tone Injection
7.2.7 DFT Spreading
CHAPTER 8: INTER-CELL INTERFERENCE MITIGATION TECHNIQUES
8.1 INTER-CELL INTERFERENCE COORDINATION TECHNIQUE
8.1.1 Fractional Frequency Reuse
8.1.2 Soft Frequency Reuse
8.1.3 Flexible Fractional Frequency Reuse
8.1.4 Dynamic Channel Allocation
8.2 INTER-CELL INTERFERENCE RANDOMIZATION TECHNIQUE
8.2.1 Cell-Specific Scrambling
8.2.2 Cell-Specific Interleaving
8.2.3 Frequency-Hopping OFDMA
8.2.4 Random Sub-Carrier Allocation
8.3 INTER-CELL INTERFERENCE CANCELLATION TECHNIQUE
8.3.1 Interference Rejection Combining Technique
8.3.2 IDMA Multiuser Detection
CHAPTER 9: MIMO: CHANNEL CAPACITY
9.1 USEFUL MATRIX THEORY
9.2 DETERMINISTIC MIMO CHANNEL CAPACITY
9.2.1 Channel Capacity when CSI is Known to the Transmitter Side
9.2.2 Channel Capacity when CSI is Not Available at the Transmitter Side
9.2.3 Channel Capacity of SIMO and MISO Channels
9.3 CHANNEL CAPACITY OF RANDOM MIMO CHANNELS
CHAPTER 10: ANTENNA DIVERSITY AND SPACE-TIME CODING TECHNIQUES
10.1 ANTENNA DIVERSITY
10.1.1 Receive Diversity
10.1.2 Transmit Diversity
10.2 SPACE-TIME CODING (STC) : Overview
10.2.1 System Model
10.2.2 Pairwise Error Probability
10.2.3 Space-Time Code Design
10.3 SPACE-TIME BLOCK CODE (STBC)
10.3.1 Alamouti Space-Time Code
10.3.2 Generalization of Space-Time Block Coding
10.3.3 Decoding for Space-Time Block Codes
10.3.4 Space-Time Trellis Code
CHAPTER 11: SIGNAL DETECTION FOR SPATIALLY MULTIPLEXED MIMO SYSTEMS
11.1 LINEAR SIGNAL DETECTION
11.1.1 ZF Signal Detection
11.1.2 MMSE Signal Detection
11.2 OSIC SIGNAL DETECTION
11.3 ML SIGNAL DETECTION
11.4 SPHERE DECODING METHOD
11.5 QRM-MLD METHOD
11.6 LATTICE REDUCTION-AIDED DETECTION
11.6.1 Lenstra-Lenstra-Lovasz (LLL) Algorithm
11.6.2 Application of Lattice Reduction
11.7 SOFT DECISION FOR MIMO SYSTEMS
11.7.1 Log-likelihood-Ratio (LLR) for SISO Systems
11.7.2 LLR for Linear Detector based MIMO System
11.7.3 LLR for MIMO System with a Candidate Vector Set
11.7.4 LLR for MIMO System using a Limited Candidate Vector Set
CHAPTER 12: EXPLOITING CHANNEL STATE INFORMATION AT THE TRANSMITTER SIDE
12.1 CHANNEL ESTIMATION ON THE TRANSMITTER SIDE
12.1.1 Using Channel Reciprocity
12.1.2 CSI Feedback
12.2 PRECODED OSTBC
12.3 PRECODED SPATIAL-MULTIPLEXING SYSTEM
12.4 ANTENNA SELECTION TECHNIQUES
12.4.1 Optimum Antenna Selection Technique
12.4.2 Complexity-Reduced ANtenna Selection
12.4.3 Antenna Selection for OSTBC
CHAPTER 13: MULTI-USER MIMO
13.1 MATHEMATICAL MODEL FOR MULTI-USER MIMO SYSTEM
13.2 CHANNEL CAPACITY OF MULTI-USER MIMO SYSTEM
13.2.1 Capacity of MAC
13.2.2 Capacity of BC
13.3 TRANSMISSION METHODS FOR BROADCAST CHANNEL
13.3.1 Channel Inversion Methods
13.3.2 Block Diagonalization Method
13.3.3 Dirty Paper Coding (DPC)
13.3.4 Tomlinson-Harashima Precoding |
part1.rar
2.86 MB, 下载次数: 1806
, 下载积分:
资产 -2 信元, 下载支出 2 信元
part2.rar
2.86 MB, 下载次数: 1640
, 下载积分:
资产 -2 信元, 下载支出 2 信元
part3.rar
2.86 MB, 下载次数: 1692
, 下载积分:
资产 -2 信元, 下载支出 2 信元
part4.rar
1.87 MB, 下载次数: 1585
, 下载积分:
资产 -2 信元, 下载支出 2 信元
