在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 21804|回复: 129
[原创] 【Springer 2010 新书】Low-Power High-Resolution Analog to Digital Converters
发表于 2010-11-7 13:02:46 | 显示全部楼层 |阅读模式
[size=120%]Low-Power High-Resolution Analog to Digital Converters: Design, Test and Calibration (Analog Circuits and Signal Processing)
By Amir Zjajo, José Pineda de Gyvez
  • Publisher:   Springer
  • Number Of Pages:   250
  • Publication Date:   2011-05-04
  • ISBN-10 / ASIN:   9048197244
  • ISBN-13 / EAN:   9789048197248
With the fast advancement of CMOS fabrication technology, more and more signal-processing functions are implemented in the digital domain for a lower cost, lower power consumption, higher yield, and higher re-configurability. This has recently generated a great demand for low-power, low-voltage A/D converters that can be realized in a mainstream deep-submicron CMOS technology. However, the discrepancies between lithography wavelengths and circuit feature sizes are increasing. Lower power supply voltages significantly reduce noise margins and increase variations in process, device and design parameters. Consequently, it is steadily more difficult to control the fabrication process precisely enough to maintain uniformity. The inherent randomness of materials used in fabrication at nanoscopic scales means that performance will be increasingly variable, not only from die-to-die but also within each individual die. Parametric variability will be compounded by degradation in nanoscale integrated circuits resulting in instability of parameters over time, eventually leading to the development of faults. Process variation cannot be solved by improving manufacturing tolerances; variability must be reduced by new device technology or managed by design in order for scaling to continue. Similarly, within-die performance variation also imposes new challenges for test methods.
In an attempt to address these issues, Low-Power High-Resolution Analog-to-Digital Converters specifically focus on: i) improving the power efficiency for the high-speed, and low spurious spectral A/D conversion performance by exploring the potential of low-voltage analog design and calibration techniques, respectively, and ii) development of circuit techniques and algorithms to enhance testing and debugging potential to detect errors dynamically, to isolate and confine faults, and to recover errors continuously. The feasibility of the described methods has been verified by measurements from the silicon prototypes fabricated in standard 180nm, 90nm and 65nm CMOS technology.
Low-Power High-Resolution Analog to Digital Converters Design, Test and Calibration.rar
3.46 MB, 下载次数: 1379 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-11-7 13:53:00 | 显示全部楼层
ACSP的新书
很好
发表于 2010-11-7 14:05:51 | 显示全部楼层
thanks!!!
发表于 2010-11-7 18:06:26 | 显示全部楼层
好书啊,顶起
发表于 2010-11-7 18:30:26 | 显示全部楼层
ddddddddddddddddddddddddddd
发表于 2010-11-7 22:16:46 | 显示全部楼层
good reference
发表于 2010-11-7 22:30:02 | 显示全部楼层
thanks for sharing
发表于 2010-11-7 23:08:48 | 显示全部楼层
thanks...
发表于 2010-11-8 08:13:22 | 显示全部楼层
下来看看,谢谢。
发表于 2010-11-8 11:20:03 | 显示全部楼层
good, thanks.
GMT+8, 2024-4-30 22:54 , Processed in 0.030688 second(s), 8 queries , Gzip On, Redis On.
