在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 85286|回复: 413
我用过的最好用的LDO补偿的方法(SCI 论文)
发表于 2009-3-8 20:17:48 | 显示全部楼层 |阅读模式
A 3-A CMOS low-dropout regulator with adaptive Miller compensation
Abstract A 3-A CMOS low-dropout regulator (LDO) is
presented by utilizing adaptive Miller compensation (AMC)
technique, which provides high stability, as well as fast
line and load transient responses. The proposed LDO has
been fabricated in a standard 0.5 μm CMOS technology,
and the die area is small as 1330 μm×1330 μm with the
area-efficient waffle layout for power transistors. Both load
and line regulation are less than ±0.1%. And the output
voltage can recover within 80 μs for full load changes.
The power–supply rejection ratio (PSRR) at 20 KHz is
−30 dB.Moreover, it is stable enough with a ceramic capacitor
small to 2.2 μF, and the added series resistance is not
needed.
Keywords Adaptive Miller compensation . Loop-gain
stability . Low-dropout regulator . Waffle power transistors
sci.pdf
1.4 MB, 下载次数: 9066 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-3-8 23:16:42 | 显示全部楼层
有一篇US的专利,是关于动态补偿的,写的挺好的。
发表于 2009-3-9 09:03:47 | 显示全部楼层
发表于 2009-3-9 09:27:07 | 显示全部楼层
xie xie a
发表于 2009-3-9 09:34:29 | 显示全部楼层
dddddddddddddddddd
发表于 2009-3-9 09:46:32 | 显示全部楼层
很好的資料,感謝大大無私的分享。
发表于 2009-3-9 10:09:23 | 显示全部楼层
我正在找这paper,没有在学校那么方便了。
发表于 2009-3-9 13:00:51 | 显示全部楼层
急需这样的资料,谢谢楼主
发表于 2009-3-9 14:38:43 | 显示全部楼层
Thanks  a lot !
发表于 2009-3-9 14:40:03 | 显示全部楼层
抓來看看
GMT+8, 2025-6-10 11:37 , Processed in 0.028305 second(s), 8 queries , Gzip On, MemCached On.
