发表于 2010-6-9 01:45:20
显示全部楼层
I think the most advantage of AXI is out-of-order completion. As you know, this allows a master (in your case is ARM926EJ-S) to access other slaves without waiting for responses from the slower slaves. In contrast, AHB have to end transactions in order.
Therefore, from this point of view, if ARM926EJ-S uses 2 AHB master ports, it is assumed that ARM926EJ-S have to access data in order, so I don't think maybe you cannot get such benefit as AXI out-of-order characteristics. |
