查看: 3398|回复: 2
[求助] LVS SOFTCHK PWELL UPPER/LOWER/CONTACT,求解释,万分感谢!!!!
发表于 2019-1-18 17:38:17 | 显示全部楼层 |阅读模式
看了SVRF后,还是不懂LVS SOFTCHK  layer  UPPER/CONTACT/LOWER 的意思,其中UPPER/CONTACT/LOWER的区别是什么,分别代表什么意思的,来自版图小白的无助的呐喊,求解释,万分感谢!!!!!!
发表于 2019-1-19 16:03:14 | 显示全部楼层
我们画版图的,还需要精通验证规则的编写吗?好吓人啊!
  1. LVS Softchk
  2. Specification statement
  3. LVS SOFTCHK lower_layer [LOWER | CONTACT | UPPER] [ALL]
  4. [DIRECT] [MASK]
  5. Parameters
  6. • lower_layer
  7. A required original layer or layer set, or a derived polygon layer.
  8. • LOWER | CONTACT | UPPER
  9. An optional keyword set that selects polygons involved in conflicting connections from the
  10. specified layer. Possible choices are:
  11. LOWER — Selects lower_layer polygons from an Sconnect operation. This is the
  12. default behavior if you do not include a selection from this set in the statement.
  13. CONTACT — Selects contact_layer polygons from an Sconnect operation.
  14. UPPER — Selects upper_layer polygons from an Sconnect operation.
  15. For Sconnect operations without the BY keyword, CONTACT and UPPER are
  16. synonymous.
  17. • ALL
  18. An optional keyword that specifies all electrical nodes involved in conflicting connections
  19. to the lower_layer polygon are eligible for reporting. By default, the node that Sconnect
  20. chooses as the intended connection is not reported. The ALL keyword has no effect if you
  21. specify LOWER.
  22. • DIRECT
  23. An optional keyword that places the operation in the Direct verification set. This keyword
  24. applies only to ICtrace. This option is used by default.
  25. • MASK
  26. An optional keyword that places the operation in the Mask verification set. This keyword
  27. applies only to Calibre. This option is used by default.
    复制代码
 楼主| 发表于 2019-1-21 09:45:03 | 显示全部楼层
回复 2# yanpflove
    亲,文档我也有,也看了,就是UPPER,CONTACT,UPPER几个选项有些不是特别理解,我不想囫囵吞枣,故发帖看看各位大神的见解。
GMT+8, 2025-12-17 21:21 , Processed in 0.012129 second(s), 3 queries , Gzip On, Redis On.
