查看: 9422|回复: 14
[求助] LVS文件
发表于 2016-10-8 11:25:40 | 显示全部楼层 |阅读模式
SMIC40nm,在做数字库,出现这个问题,小弟请教各位大神帮忙解答.
以inv1为例:
                   CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of instances (see below).
LAYOUT CELL NAME:         INV_X1_HV
SOURCE CELL NAME:         INV_X1_HV
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              4         4
Nets:               4         4
Instances:          1         0    *    MN (4 pins)
                     1         0    *    MP (4 pins)
                     1         0    *    D (2 pins)
                     0         1    *    nod33ll_ckt (4 pins)
                     0         1    *    pod33ll_ckt (4 pins)
Total Inst:         3         2
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              4         4
Nets:               4         4
Instances:          0         1    *    nod33ll_ckt (4 pins)
                     1         0    *    _invv (4 pins)
Total Inst:         1         2
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                 INCORRECT INSTANCES
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    (_invv)                                                   ** missing injected instance **
       Devices:
         M2(0.857,3.149)  MP(POD33LL_CKT)
         M1(0.857,0.708)  MN(NOD33LL_CKT)
  2    ** missing instance **                                    XPM2  nod33ll_ckt
  3    ** missing instance **                                    XPM1  pod33ll_ckt
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               4          4            0            0
   Nets:                4          4            0            0
   Instances:           0          0            0            1    nod33ll_ckt
                        0          0            0            1    pod33ll_ckt
                        0          0            1            0    _invv
   Total Inst:          0          0            1            2
o Statistics:
   1 layout instance was filtered and its pins removed from adjoining nets.
o Initial Correspondence Points:
   Ports:        VDD_HV VSS IN OUT
                                         SUMMARY
Total CPU Time:      0 sec
Total Elapsed Time:  0 sec
发表于 2016-10-8 12:03:48 | 显示全部楼层
看LVS 文件对器件的定义
发表于 2016-10-8 13:41:00 | 显示全部楼层
netlist上没有include子电路定义的文件。
 楼主| 发表于 2016-10-8 14:10:31 | 显示全部楼层
回复 2# maomao198477
   MOSFET定义是正确的,
 楼主| 发表于 2016-10-8 14:17:05 | 显示全部楼层
回复 3# tuohong
   没懂,是在netlsit export 中 include  subskt 文件么,这个我已经弄过了。
 楼主| 发表于 2016-10-8 14:18:01 | 显示全部楼层
回复 3# tuohong
发表于 2016-10-8 15:10:53 | 显示全部楼层
回复 1# 宫海龙
netlist 中nod33ll_ckt, pod33ll_ckt
如果是mos, 那就是layout 上的MN, MP device 对应netlist 中的nod33ll_ckt, pod33ll_ckt, netlist 中缺少diode device.
如果不是mos, 那就是
layout 上的MN, MP, Diode 被认成nod33ll_ckt, pod33ll_ckt 了!
 楼主| 发表于 2016-10-8 17:14:26 | 显示全部楼层
回复 7# Yestare
   这属于一个翻新项目,用之前的runset文件来run,也是不过的,但是之前的已经正确,所以现在还找不到问题所在。
发表于 2016-10-9 09:29:06 | 显示全部楼层
回复 8# 宫海龙
去lvs cmd中看一下device的层次是否正确,有可能是认错device了
发表于 2016-10-9 09:48:37 | 显示全部楼层
是不是runset区分大小写了?
回复 支持 0 反对 1
GMT+8, 2025-11-15 09:01 , Processed in 0.029284 second(s), 3 queries , Gzip On, Redis On.
