查看: 8616|回复: 15
Calibre 2013 on RHEL 6.5
发表于 2014-6-14 11:24:52 | 显示全部楼层 |阅读模式
I have installed ixl_cal_2013.3_39.24_mib from [url]http://bbs.eetop.cn/thread-442844-1-1.html[/url]Also, I used calibre 2011 licgen to create license.dat However, when I run DRC, it's failed!
*Error* License "111" could not be checked out.
ERROR (XSTRM-209): Virtuoso Framework License (111) could not be found. Either the license server is down or the license is not available. Ensure that the valid license is available.INFO (XSTRM-273): Translation failed. '1' error(s) and '0' warning(s) found.
Can anyone help me??
.bashrc
export MGLS_LICENSE_FILE=27001@Dragon
export MGC_HOME=/home/mdxuan/EDA/Mentor/Calibre2013/ixl_cal_2013.3_39.24
export LM_LICENSE_FILE=/home/mdxuan/EDA/Mentor/Calibre2013/ixl_cal_2013.3_39.24/license/license.dat
export PATH=$MGC_HOME/binPATH
export PATH=$MGC_HOME/pkgs/mgls/libPATH
MGC_CALIBRE_LAYOUT_SERVER=Dragon:2345
Run DRC
Run DRC
ERROR
ERROR
发表于 2014-6-14 12:26:23 | 显示全部楼层
跟calibre没关系,应该是你的 cadence破解不完全。
发表于 2014-6-15 14:14:14 | 显示全部楼层
mark一下,可能这个对我有点用
发表于 2014-6-19 09:20:45 | 显示全部楼层
111是的virtuoso的feature
发表于 2014-6-19 11:57:32 | 显示全部楼层
谢谢!!!
发表于 2014-6-20 20:02:58 | 显示全部楼层
  看看
 楼主| 发表于 2014-7-1 22:18:22 | 显示全部楼层
回复 2# snk88
I were patched IC616 again and IC616 work well (IC616, MMSIM131, ASSURA616-4.1). However, these is another problem
登录/注册后可看大图
MGC_CALIBRE_LAYOUT_SERVER=Dragon:8989
export MGC_CALIBRE_LAYOUT_SERVER
I changed many port however it doesn't work!!!
Do you have any idea?
Socket???
Socket???
发表于 2014-7-2 13:46:54 | 显示全部楼层
Can you run simulation with mmsim? I think you haven't patched Virtuoso fully.
发表于 2014-7-6 10:16:03 | 显示全部楼层
 楼主| 发表于 2014-7-7 11:41:08 | 显示全部楼层
回复 8# kid1412_net
Thanks so much! I have patched IC 6.1.6.060, ASSURA616-4.14.11, MMSIM13.1.078, Calibre 2013.3_29.24 again! All things work great!
Calibre 2013.3_39.24
GMT+8, 2025-9-8 06:19 , Processed in 0.033078 second(s), 6 queries , Gzip On, Redis On.
