楼主: snk88
ads2014.01 linux patch+systemvue2013.08 patch
发表于 2014-4-12 00:13:26 | 显示全部楼层
回复 28# snk88
抱歉老大,又来麻烦你了。还是不行。我怀疑你压缩的时候是不是有问题。
解压adspatch.tar文件, 得到 adspatch/Licensing/2014.01/linux86_64/bin 目录下
libagsl.so 链接错误,覆盖后这个链接到了安装后原来的libagsl.so.2014.01, 我记得在Windows下有个重要的.dll要替换,而且好像连 aglmmgr 也要替换。
麻烦老大你看看你的压缩文件有没有问题。dandeng 网友也是同样的问题 -- “invalig signature ...”。
多谢多谢!
 楼主| 发表于 2014-4-12 01:00:00 | 显示全部楼层
回复 31# YULONGUTK
加上这个看看行不行
libagsl.tar.gz (2.6 MB , 下载次数: 284 )
   看看cksum
  1. 3526294049 2003464 ./SystemVue/2013.08/linux_x86_64/lib/libagsl.so.2013.05
  2. 3228772123 2429144 ./thermal/lib/lib64/libagsl.so
  3. 2797149126 1718518 ./thermal/lib/lib64/libagsl.so.old
  4. 2366956331 2428999 ./thermal/lib/lib64/libagsl_Aug9.so
  5. 3484855329 2903728 ./fem/2013.07/linux_x86_64/bin/libagsl.so
  6. 2429321011 4121588 ./arttrans/xgbrvu_agilent
  7. 3374776968 1531540 ./arttrans/dxf2egs
  8. 1627207916 3344126 ./arttrans/boolmt
  9. 2678626573 1885600 ./arttrans/m2dxf
  10. 1506803670 1446864 ./arttrans/gdsfilt
  11. 3126917978 1071648 ./arttrans/m2iges
  12. 4000745123 1355328 ./arttrans/egs2dxf
  13. 3411923116 4113060 ./arttrans/xgbrvu
  14. 727297452 1105216 ./arttrans/gbr2gdxb
  15. 3248710749 1113584 ./arttrans/m2gds
  16. 3402401546 1090304 ./arttrans/m2gbr
  17. 1914959158 3717184 ./arttrans/mtools
  18. 564363631 8998427 ./lib/linux_x86_64/libagsl.so
  19. 564363631 8998427 ./psm/linux_x86_64/lib/libagsl.so
  20. 222523598 1753104 ./psm/linux_x86_64/lib/libagsl.so.2012.08
  21. 222523598 1753104 ./psm/linux_x86_64/lib/libagsl.so.2012
  22. 3563841741 1874560 ./Licensing/2014.01/linux_x86_64/bin/aglmanalyzer_exe
  23. 769157669 2321600 ./Licensing/2014.01/linux_x86_64/bin/agileesofd
  24. 3763286362 1911872 ./Licensing/2014.01/linux_x86_64/bin/aglmpref_exe
  25. 3653053816 8998395 ./Licensing/2014.01/linux_x86_64/bin/libagsl.so
  26. 812220699 1945280 ./Licensing/2014.01/linux_x86_64/bin/aglmtool_exe
  27. 2041445720 1985128 ./Licensing/2014.01/linux_x86_64/bin/aglmutil_exe
  28. 3194843326 1752168 ./Licensing/2014.01/linux_x86_64/bin/aglmconfig
  29. 875131691 1061532 ./Licensing/2014.01/linux_x86_32/bin/aglmanalyzer_exe
  30. 2739095857 1345756 ./Licensing/2014.01/linux_x86_32/bin/agileesofd
  31. 824864068 1532268 ./Licensing/2014.01/linux_x86_32/bin/aglmpref_exe
  32. 1059590437 4943055 ./Licensing/2014.01/linux_x86_32/bin/libagsl.so
  33. 2397330469 4927857 ./Licensing/2014.01/linux_x86_32/bin/libagsl.so.2013.09
  34. 2912955583 1567884 ./Licensing/2014.01/linux_x86_32/bin/aglmtool_exe
  35. 4029649724 1179940 ./Licensing/2014.01/linux_x86_32/bin/aglmutil_exe
  36. 3499038390 1376788 ./Licensing/2014.01/linux_x86_32/bin/aglmconfig
  37. 543319951 2866040 ./Momentum/11.20/linux_x86_64/lib/libagsl.so
    复制代码
发表于 2014-4-12 06:10:05 | 显示全部楼层
Reply 28 # snk88
i installed it on Centos 6.5 X64 bit, and i got These errors could you Help me please and this is my. bashrc File
[Code] export HPEESOF_DIR = / home/chris/ADS2014_01 export PATH = $ HOME / ADS: $ HPEESOF_DIR / bin: $ PATH export PATH = $ HPEESOF_DIR / bin: $ PATH [/ code]
发表于 2014-4-12 06:14:07 | 显示全部楼层
回复 31# YULONGUTK
could you please tell me from where i can download redhat 6.5 ?
发表于 2014-4-12 10:37:09 | 显示全部楼层
nice,楼主高手
 楼主| 发表于 2014-4-12 11:20:42 | 显示全部楼层
回复 33# chris2013
   reinstall。
发表于 2014-4-12 12:05:26 | 显示全部楼层
回复 34# chris2013
老兄,随便搜搜都可以啊,这里我搜到一个。http://pan.baidu.com/s/19s7Ra
 楼主| 发表于 2014-4-12 12:10:19 | 显示全部楼层
回复 37# YULONGUTK
   可以了么?
发表于 2014-4-12 12:16:42 | 显示全部楼层
多谢了
发表于 2014-4-12 13:18:56 | 显示全部楼层
回复 32# snk88
after you adding this new file,
it works on my computer
RHEL6.4 (64bit)
you are really great, I thank you very much, Now my
IC615 can joint together with ADS.
thank you so much!!!
GMT+8, 2025-12-11 05:41 , Processed in 0.020769 second(s), 4 queries , Gzip On, Redis On.
