查看: 2752|回复: 6
[求助] 刚开始接触ADC,3阶,过采样64,1位量化的模型,效果很差,请各位给些改进建议。
发表于 2013-9-26 16:47:35 | 显示全部楼层 |阅读模式
如题,三阶离散一位量化ADC。求建议。感激。
order=3,M=64
order=3,M=64
SNR
SNR
发表于 2013-9-26 16:53:28 | 显示全部楼层
Architecture is OK, but the spectrum seems very bad.
I think you should change the integrator coefficients.
 楼主| 发表于 2013-9-26 17:02:04 | 显示全部楼层
回复 2# feynmancgz
I have calculated several times about the coefficients compared with the outcome H(z) from Matlab. Is there any possibility that the simulation .m file does not fit with my architecture for I only change the parameter such as the order, osr. I do not well understand the file which I borrowed from others.
发表于 2013-9-26 19:34:35 | 显示全部楼层
回复 3# suken
   Maybe, It's possible
 楼主| 发表于 2013-9-26 21:04:49 | 显示全部楼层
回复 4# feynmancgz
thanks
发表于 2013-10-12 09:14:01 | 显示全部楼层
回复 1# suken
  三阶及以上1bit 量化很容易产生量化器过窄,请尝试减小输入信号幅度或改为多bit 结构。
 楼主| 发表于 2013-10-16 19:57:37 | 显示全部楼层
回复 6# huasheng2008
thanks i will try again
GMT+8, 2025-9-7 16:02 , Processed in 0.025555 second(s), 6 queries , Gzip On, Redis On.
