楼主: KHL
Plexim Plecs Standalone v3.2.7 win32/64 + Crack
发表于 2013-1-7 10:08:35 | 显示全部楼层
资产不足了,悲剧
发表于 2013-1-26 07:22:59 | 显示全部楼层
to rp2004
It is like a conversation with a deaf mute
.......полный "песец"......
发表于 2013-2-10 14:26:56 | 显示全部楼层
this thing doesn't works anymore
发表于 2013-2-10 14:43:54 | 显示全部楼层
回复 62# owennnn
you are correct... nobody cares to drop a line, but the guy from the previous post has obviously faced the same problem. the BEAN doctors are not good, but unfortunately they are the only ones curing this otherwise very good prog
发表于 2013-3-5 06:40:40 | 显示全部楼层
The bean crack does not work with all versions of Plecs. Till now the only version which works correctly is v3.2.3 x32 cracked the mtct (M a s t e r   T u r k i s h   C r a c k  T e a M) crack.
I use that for several months now and no license problem yet.
发表于 2013-3-9 15:42:40 | 显示全部楼层
回复 65# 1andro1
Can you share v3.2.3? Thanks!
发表于 2013-3-10 12:09:07 | 显示全部楼层
the bean crack works with a particular system date(s) only (lousy doctors..). for example 3.3.4 works if the date is say 20.12.2012. There is a small free program called runasdate that changes the date of the application, but doesn't touch the system date.  I've managed to run 3.3.4 in combination with runasdate.
发表于 2013-3-10 18:22:20 | 显示全部楼层
great job rp2004.
I have tried to change the system clk but Plecs complained about that and corrupted the files. Then I move to older version of Plecs.
发表于 2013-3-10 18:38:49 | 显示全部楼层
回复 66# tman2018
Do you still need v323 or you will use the rp2004 idea?
发表于 2013-3-10 21:12:55 | 显示全部楼层
maybe is a good idea to share 323_x32 and 323_x64 in case my method fails one day.
GMT+8, 2025-11-10 07:06 , Processed in 0.025801 second(s), 4 queries , Gzip On, Redis On.
