查看: 33476|回复: 74
[原创] USB首选协议、数据分析软件BUS HOUND 6.0.1完美版
发表于 2013-1-3 15:24:28 | 显示全部楼层 |阅读模式
USB开发工具 USB监视工具,可以观察USB资料传输情况,为调试USB不可缺少的工具,其他汇流排也可以,如串口,PS2,IDE等等。USB开发工具 USB监视工具,可以观察USB资料传输情况,为调试USB不可缺少的工具,其他汇流排也可以,如串口,PS2,IDE等等。
Bus Support
USB 1.0 & 2.0
SCSI & ATAPI
IDE & SATA
FireWire, 1394a/b
Bluetooth
Fibre Channel
iSCSI, SAS
PC Card, PCMCIA
serial port
parallel port
ps/2 ports
...and more
OS Support
32-bit and 64-bit
Windows 7
Windows 2008
Windows Vista
Windows 2003
Windows XP
Windows XP Embedded
Windows 2000
Windows NT 4.0
Windows Me
Windows 98
Windows 95
Device Support
DVD, CD, Blu-ray
Hard drives, tape drives
Removable drives
Web Cams, Cameras
Mice, Keyboards, HID
Printers, Scanners
Speakers, Modems
...and everything else!
Power User Features
·Capture megabytes of I/O at a time
·View I/O on screen in real time
·Trigger on conditions
·Build and submit custom commands
·Issue bus and device resets
·Capture the system startup process
·View low level protocol including SCSI sense data and SMART commands
·View microsecond resolution timing
·Drag and drop captured data to other applications or save it to a zip file
·Capture isochronous and control transfers
·View IRPs and other device driver packets
Ideal Uses
·Inspect low level I/O
·Debug device drivers or firmware
·Reverse engineer protocol
·Acquire performance measurements
·Research the principles of device operation
Bus Hound 6.0.1.rar (873.15 KB , 下载次数: 741 )
发表于 2013-1-8 14:30:48 | 显示全部楼层
请问有没有crack?
 楼主| 发表于 2013-1-8 15:05:32 | 显示全部楼层
发表于 2013-1-8 23:06:17 | 显示全部楼层
下来看看,谢谢。.....
发表于 2013-1-9 00:12:05 | 显示全部楼层
不错的好东东
发表于 2013-1-12 11:10:10 | 显示全部楼层
跟5.0有什么区别吗?
 楼主| 发表于 2013-1-20 00:41:40 | 显示全部楼层
回复 6# jeffkuang
没用过5.0无法比较
发表于 2013-1-21 13:28:11 | 显示全部楼层
EN ,5.0用的时候就挺好用的。看看6.0的怎么样
发表于 2013-3-5 09:37:06 | 显示全部楼层
回复 1# nerohark
    好东西,谢谢了!
发表于 2013-3-19 08:16:27 | 显示全部楼层
谢谢分享 辛苦了
GMT+8, 2025-11-7 17:48 , Processed in 0.028462 second(s), 8 queries , Gzip On, Redis On.
