查看: 31250|回复: 101
[招聘] 英特尔半导体有限公司(西安)
发表于 2012-8-20 18:34:50 | 显示全部楼层 |阅读模式
近期招聘:西安:射频工程师,数字IC设计工程师,有意的朋友邮件联系!
大连:
Supplier Service Program Analyst
Description
Fab 68, in Dalian, PRC is Intels first Greenfield fab in a new geography in 15 years. In this position, you will be playing a key role in the supplier management for field service support requirements on all capital equipment for Fab 68. Responsibilities center on determining  implementing the correct service support models over time to cost-effectively maintain the fab equipment. You will also be participating in designing the Supplier Service Teams roles to support start up  sustaining operations. You will be developing, implementing,  managing effective supplier management practices for F68 factory customers. Following completion of the startup phase, you will be working to continually improve service efficiency  costs. Your responsibilities will include but not be limited to:
- Learning Intel culture  systems
- Implementing Supplier management systems including contract management  supplier improvement
- Providing ongoing cost tracking, forecasting, presentations,  others to hit SSP cost goals  overall supplier management
- Working with our training erparts to implement the SSP strategy to underst, forecast,  obtain commitments for the training capacity to start-up the tools  reduce costs over time as the fab ramps
- Establishing  running systems to bring in  assimilate green badge personnel, follow up with stakeholders  suppliers on service  quality issues,  others
- Partnering with key internal/external stakeholders to identify  implementing solutions so waste elimination benefits  cost reduction are realized
- Interfacing with SSP erparts in other Intel factories to underst  build on lessons learned from previous start-ups
- Analyzing  evaluating options from large,  sometimes complex data sets
- Responsible for distill analyses, results  options into simple, straightforward communication
- Creating  uting to financial forecasts
Qualifications
You should possess a Bachelor of Science degree in a Business, Manufacturing, or Engineering discipline plus at least two years of related experience or equivalent. Additional qualifications include:
- Demonstrated, effective verbal  written communications  problem solving skills
- Strong personal  leadership skills
- Ability to bring groups with diverse interests  goals together  obtain their commitment to a single, integrated plan which meets Fab68s business goals for key toolsets
- Need to create  maintain strong feedback loops between suppliers  stakeholders, to ensure we achieve service quality  cost goals
- Ability to communicate in English both verbally  in written form
- Given this is a startup  in a new Intel location, you will need to tolerate ambiguity  demonstrate flexibility due to inevitable surprises.
The following qualifications would be added advantages:
- Direct experience in implementing  managing contracts  supplier service management
- Supplier management experience  an understing of key fab suppliers  functional area requirements for equipment service personnel
- Underst or learn Intels commercial  contracting requirements,  also the fabs technical, service level,  cost needs
Process Engineer
Job description
In this position, you will be reporting to Process Engineering Manager  working closely with process engineering, yield/integration,  manufacturing teams to start up  ramp the 1st Intel 300 mm Fab in Asia  will be located in Dalian. Applying to this posting will allow you to be considered for all process engineer positions available at this time. It may require training assignment in the US for up to one year before locating to Dalian, China. Your responsibilities will include but not be limited to:
Transferring process technology into F68, the 1st Intel 300 mm Fab in Asia.
Leading  owning process  equipment qualification, tool preventative maintenance, management of troubleshooting activities, regular monitoring of tool/process performance, defect analysis/reduction,  cost reduction to achieve both operation  equipment excellence under LEAN principle.
Working with existing Intel 300mm fabs around the world to improve tool  process performance, reduce cost,  increase flexibility in process transfer.
Working with  leading manufacturing equipment teams to develop inventive solutions to improve ution  efficiency in a high-volume manufacturing environment.
Qualifications
You should possess a Bachelors or a Masters degree or a Doctorate in Engineering or Sciences  more than 3 plus years of direct semiconductor industry experience. Additional qualification includes:
Good understing of factory /or fabrication operations
A strong understing of semiconductor process technology issues, manufacturing science  systems,  engineering applications
Critical data  Engineering analysis skills  software proficiency. Ability to summarize complex data sets for technical  non-technical audiences
Technical expertise within Semiconductor Processing  be able to provide technical direction on all quality issues.
Excellent listening, written  verbal communication, tolerance of ambiguity,  commitment to task.
Demonstrated technical leadership capability including strong training, mentoring  coaching skills.
Demonstrated the capability of working in  leading a high performing team culture which includes: setting high expectations, driving acability to those expectations, role modeling the desired culture, possess excellent teamwork, demonstrated problem solving  prioritization skills,  driving high performance maintenance goals for the group.
Ability to work in a culturally diverse environment.
Fluency in Marin  good comm of English
IC人才网原链:http://www.jobic.cn/Html/JobDetail/37007.html
注册简历:http://www.jobic.cn/Resume/Register.aspx
邮箱:abel.zhang@jobic.cn
电话:0755-26490606
 楼主| 发表于 2012-9-10 18:20:13 | 显示全部楼层
 楼主| 发表于 2012-9-11 18:13:25 | 显示全部楼层
 楼主| 发表于 2012-9-17 19:03:33 | 显示全部楼层
发表于 2012-9-17 21:06:38 | 显示全部楼层
明年就该我了,目标:西安
 楼主| 发表于 2012-9-18 18:47:13 | 显示全部楼层
回复 5# junzhenglee
    谢谢关注,加油!
发表于 2012-9-18 19:12:01 | 显示全部楼层
上海有没
 楼主| 发表于 2012-9-19 18:05:29 | 显示全部楼层
回复 7# 304598231
    上海暂时满了,现在西安量比较大
 楼主| 发表于 2012-9-26 17:55:00 | 显示全部楼层
发表于 2012-10-3 23:59:09 | 显示全部楼层
intel什么时候跑西安去了么?不是在大连吗?
GMT+8, 2025-7-5 19:12 , Processed in 0.024302 second(s), 7 queries , Gzip On, MemCached On.
