win7系统32位,按照crack的说明做完后,打开软件就出现以下提示:
LICENCING FAILURE for L-EDIT
Checking hardware lock...
Failed to obtain version 11.1 license.
This feature was not found on this computer.
Environment variable LSERVRC=C:\Windows\lservrc found.
The 'lservrc' file must have a valid license string for this feature.
Trying to locate a license server on the local subnet...
Failed to obtain base license.
The Rainbow SentinelLM license server could not be located or does not have a license string for this feature.
Make sure that the server is running and the client and server computers can 'ping' each other.
If you are trying to use a network license, set the environment variable TANNERHOST=nnn.nnn.nnn.nnn,
replacing the nnn's with the IP address of the computer running the Rainbow SentinelLM license server.
在网上搜,有人说添加环境变量LSERVRC 后可以用,我试过之后也不行。急用软件啊,有没有人遇到过同样情况的? |
