查看: 28538|回复: 38
[求助] Failed to open the TCP port number in the license.
发表于 2011-3-17 14:54:33 | 显示全部楼层 |阅读模式
How can solve the following question during install sentaurus2008 issue?
Thanks
 楼主| 发表于 2011-3-17 16:04:54 | 显示全部楼层
[root@localhost bin]# ./lmgrd
14:47:21 (lmgrd) -----------------------------------------------
14:47:21 (lmgrd)   Please Note:
14:47:21 (lmgrd)
14:47:21 (lmgrd)   This log is intended for debug purposes only.
14:47:21 (lmgrd)   In order to capture accurate license
14:47:21 (lmgrd)   usage data into an organized repository,
14:47:21 (lmgrd)   please enable report logging. Use Macrovision's
14:47:21 (lmgrd)   software license administration  solution,
14:47:21 (lmgrd)   FLEXnet Manager, to  readily gain visibility
14:47:21 (lmgrd)   into license usage data and to create
14:47:21 (lmgrd)   insightful reports on critical information like
14:47:21 (lmgrd)   license availability and usage. FLEXnet Manager
14:47:21 (lmgrd)   can be fully automated to run these reports on
14:47:21 (lmgrd)   schedule and can be used to track license
14:47:21 (lmgrd)   servers and usage across a heterogeneous
14:47:21 (lmgrd)   network of servers including Windows NT, Linux
14:47:21 (lmgrd)   and UNIX. Contact Macrovision at
14:47:21 (lmgrd)   www.macrovision.com for more details on how to
14:47:21 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
14:47:21 (lmgrd)   for your enterprise.
14:47:21 (lmgrd)
14:47:21 (lmgrd)
14:47:21 (lmgrd)
14:47:21 (lmgrd) The license server manager (lmgrd) running as root:
14:47:21 (lmgrd)        This is a potential security problem
14:47:21 (lmgrd)        and is not recommended.
[root@localhost bin]# 14:47:21 (lmgrd) Failed to open the TCP port number in the license.
发表于 2011-3-27 11:49:30 | 显示全部楼层
同样的问题,楼主解决了没?
发表于 2011-4-1 16:04:29 | 显示全部楼层
把license文件里面的port随便改个其他的试试。
发表于 2011-4-1 16:05:41 | 显示全部楼层
发表于 2011-7-21 00:48:26 | 显示全部楼层
ddddddddddddd
发表于 2011-7-21 12:42:18 | 显示全部楼层
旁观一下,学习一下。
发表于 2011-8-4 15:40:37 | 显示全部楼层
回复 1# mickey1999
    Can  you help me sir? Please tell me how to solve the problem. thank you!
发表于 2011-8-9 12:39:24 | 显示全部楼层
請更換Port Number再啟用看看。謝謝。
发表于 2011-9-7 12:54:39 | 显示全部楼层
感谢楼主分享
GMT+8, 2025-12-22 21:25 , Processed in 0.024834 second(s), 7 queries , Gzip On, Redis On.
