查看: 25091|回复: 29
[原创] ModelSim 6.4 SE (New Crack)
发表于 2010-4-28 03:06:10 | 显示全部楼层 |阅读模式
ModelSim SE
ModelSim SE (Special Edition) is a UNIX, Linux, and Windows-based simulation and debug environment, combining high perrformance with the most powerful and intuitive GUI in the industry.
 楼主| 发表于 2010-4-28 03:08:59 | 显示全部楼层
Features:
    * Multi-language, high performance simulation engine
    * Verilog, VHDL, SystemVerilog Design
    * Code Coverage
    * SystemVerilog for Design
    * Integrated debug
    * JobSpy Regression Monitor
    * Mixed HDL simulation option
    * SystemC Option
    * TCL/tk
    * Solaris and Linux 32 & 64-bit
    * Windows 32-bit
 楼主| 发表于 2010-4-28 03:10:02 | 显示全部楼层
Benefits:
    * High performance HDL simulation solution for FPGA & ASIC design teams
    * The best mixed-language environment and performance in the industry.
    * Intuitive GUI for efficient interactive or post-simulation debug of RTL and gate-level designs
    * Merging, ranking and reporting of code coverage for tracking verification progress
    * Sign-off support for popular ASIC libraries
    * All ModelSim products are 100% standards based. This means your investment is protected, risk is lowered, reuse is enabled, and productivity is enhanced.
    * Award-winning technical support.
 楼主| 发表于 2010-4-28 03:11:06 | 显示全部楼层
 楼主| 发表于 2010-4-28 03:12:15 | 显示全部楼层
 楼主| 发表于 2010-4-28 03:13:35 | 显示全部楼层
Password:
MJ
 楼主| 发表于 2010-4-28 03:15:17 | 显示全部楼层
to use keygen/license try these:
install modelsim 6.4
download the keygen
create the folder c:\flexlm
run the MentorKG.exe, at command line write c:\...\mentorkg -hd -o license.dat
put the license.dat at flexlm folder
run the Licensing Wizard of modelsim and at "user tools" tab click at the edit environment variables,
in "add a new value" write c:\flexlm\license.dat for both LM_LICENSE_FILE and MGLS_LICENSE_FILE
the modelsim now runs full for all of your life
 楼主| 发表于 2010-4-28 03:17:36 | 显示全部楼层
There exist a new keygen for all mentor products until now, for example for ModelSim 6.6, and it works great, there is the link
http://www.sonsivri.com/forum/in ... 4.msg92924#msg92924
 楼主| 发表于 2010-4-28 03:20:10 | 显示全部楼层
 楼主| 发表于 2010-4-28 03:22:16 | 显示全部楼层
and now a new one ....
GMT+8, 2025-11-28 23:45 , Processed in 0.018032 second(s), 3 queries , Gzip On, Redis On.
