查看: 22|回复: 0
[其它] 89600 VSA 2026 v30.00.306.00
发表于 2 小时前 | 显示全部楼层 |阅读模式
89600 VSA2025 (Build 29.00), VSA2025 U1 (Build 29.20), and VSA2025 U2 (Build 29.40) and VSA2026 (30.00) are the latest several releases of Keysight’s PathWave Vector Signal Analysis software shipped in 2025 and 2026, a comprehensive set of tools for demodulation and vector signal analysis. Use 89600 VSA software tools to explore every facet of a signal and optimize your designs. Measure a broad range of signals including 6G Research, 5G NR/5G-Advanced, WLAN, IoT/UWB, Satellite Communication, Advanced Radar, Custom Modulation, Custom OFDM and more. Gain greater insight in frequency, time, modulation domains and optional decoding. Compatible with signal analyzers, oscilloscopes, network analyzers, logic analyzers, FieldFox handheld, signal source and many more test instruments.
有兴趣交流,请PM 或 contact 1085958372@qq.com
GMT+8, 2025-12-2 17:49 , Processed in 0.039130 second(s), 4 queries , Gzip On, Redis On.
