查看: 270|回复: 1
[求助] innovus,有scan chain是不是就不要设置setPlacemode了?
发表于 2025-11-14 16:03:29 | 显示全部楼层 |阅读模式
佬门,defIn scan.def,设置setPlaceMode
setPlaceMode -place_global_ignore_scan false
setPlaceMode -place_global_reorder_scan true
错误如下,我是不是要把这两句话删除了。
**ERROR: (IMPSP-9100): Scan chains exist in this design but are not defined for 70.89% flops and -place_global_ignore_scan is set to false. Placement and timing QoR can be severely impacted in this case!
It is highly recommend to keep -place_global_ignore_scan option as its default value 'true' with scan chains definition.
发表于 2025-11-14 18:05:10 | 显示全部楼层
如果是这两句引起的 就四种情况 都跑下试试啊
GMT+8, 2025-12-8 04:18 , Processed in 0.014304 second(s), 3 queries , Gzip On, Redis On.
