查看: 366|回复: 6
c tools oa version
发表于 2025-10-28 14:18:52 | 显示全部楼层 |阅读模式
hello, i have question about oa version with I.C251 and qauntsu23 qrc.
25 have different oa (newer oa) verison with q23, so i can't use extract feature.
is there any solution?
here's the list that ive tried down below
1) export oa_home=IC251's path -> qrc failed.
2) export oa_home=qrc23's path -> IC25 failed.
+) now i'm using oa_unsupported_plat=linux_rhel_70_gcc93x
发表于 2025-10-28 14:43:31 | 显示全部楼层
你安装完以后config oa的时候选择退出,或者你现在把安装目录下的OA link的路径从绝对路径换成当前木录下的相对路径,然后再环境变量中将OA_HOME注销掉就好了啊
 楼主| 发表于 2025-10-28 15:06:56 | 显示全部楼层
powertoy 发表于 2025-10-28 14:43
你安装完以后config oa的时候选择退出,或者你现在把安装目录下的OA link的路径从绝对路径换成当前木录下的 ...
at that phase, (oa setup popup after installing)
i didn't configure anything special and just passed the process by repeating enter..
is 23 release is compatible with 25 release??
发表于 2025-10-28 15:12:04 | 显示全部楼层
对啊就是这样的
发表于 2025-10-28 17:23:34 | 显示全部楼层
do not set environment OA_HOME
点评
it really works ! !  发表于 2025-10-28 19:58
发表于 7 天前 | 显示全部楼层
thanks
GMT+8, 2025-11-5 14:54 , Processed in 0.020846 second(s), 4 queries , Gzip On, Redis On.
