查看: 218|回复: 0
求助,Virtuoso导入Verilog时出问题
发表于 7 天前 | 显示全部楼层 |阅读模式
已经安装了Xcelium,并且shell执行which xmvlog有正常路径,并能运行。
Xcelium:24.3
Virtuoso:23.1
导入时出现如下错误:
ERROR: Failed to run the xmvolog analyzer because the analyzer binary could not be located. Either the analyzer binary does not exist in the shell search path or you do not have the required permission on the file. set the correct shell search path and update the file permissions before running the command again
我找到了这篇文章:https://support.cadence.com/apex ... Name=ArticleContent 但是没有账号看不了解决方法。
有老哥能帮忙下一下文章或者有解决办法吗?谢谢!
GMT+8, 2025-9-26 06:45 , Processed in 0.010088 second(s), 3 queries , Gzip On, Redis On.
