查看: 1682|回复: 16
[Help] How to get VMANAGER24.09 up and running? 200 points for help
发表于 2025-4-8 15:50:48 | 显示全部楼层 |阅读模式
悬赏200资产未解决
After installing it and using Flex patcher and pubkey_verify_java, I did not start a profile server and did not open the tool:
[root@localhost vManager_environment]# vmgrserver -start -profile vManager_Server/vManager_Server_2409/
============================= WARNING ===========================
  System limits check:
  - Max allowed descriptors: 1024, required minimum: 65536
  Its Highly recommended to fix this before starting the server
Starting Verisium Manager Standard Server [localhost:102].......... [FAILED]
ERROR: Server not started:
FAILED deploying
Stopping server
Stopping Server.. [OK]
Who has used it? Please help me fix this issue. Thank you.
 楼主| 发表于 2025-4-8 16:10:07 | 显示全部楼层
通过网盘分享的文件:Base_VMANAGER24.09.001_lnx86_1of1.tar
链接: https://pan.baidu.com/s/18tOeu4gFxBDOOG6-2UXsXQ?pwd=wz1a 提取码: wz1a
--来自百度网盘超级会员v1的分享
通过网盘分享的文件:Update_VMANAGERAGILE24.09.002_lnx86_1of1.tar
链接: https://pan.baidu.com/s/1fB4WhEpfbQYTOdprczqrXg?pwd=8tdt 提取码: 8tdt
--来自百度网盘超级会员v1的分享
发表于 2025-4-8 16:13:42 | 显示全部楼层
数据库这些创建了吗?
 楼主| 发表于 2025-4-8 16:16:10 | 显示全部楼层
iou230usoeui 发表于 2025-4-8 16:13
数据库这些创建了吗?
[user@localhost vManager_environment]$ vmgrdb -start -db_dir vManager_DB/vManager_DB_2409/
Starting Database Server 16.3...
Postgres database server logs can be found in /tools/vManager_environment/vManager_DB/vManager_DB_2409/pg_server.log
Database server started in 0 secs.
发表于 2025-4-8 16:38:37 | 显示全部楼层
vmanager 服务器端口是 102 ?
发表于 2025-4-8 16:44:35 | 显示全部楼层
I got a same issue. Please help
 楼主| 发表于 2025-4-8 17:18:48 | 显示全部楼层
[lampn0@localhost vManager_environment]$ vmgrcreatedb -db_dir vManager_DB/vmgr_2409_2323 -db_port 2323 -sys_username admin -sys_password admin
About to create DB. original output dump can be found in /tmp/vmgr-create-db-1744103624320.out
Database created successfully...
[lampn0@localhost vManager_environment]$ vmgrdb -start -db_dir vManager_DB/vmgr_2409_2323
Postgres database server logs can be found in /home/vManager_environment/vManager_DB/vmgr_2409_2323/pg_server.log
[lampn0@localhost vManager_environment]$ vmgrprofile -create -profile vManager_Server/vmgr_2409_2323 -db_sys_username admin -db_sys_password admin -db_host localhost -db_port 2323 -db_name vmanager_db -db_user lampn0 -db_password lampn0 -host localhost -port 21
----- Creating the profile -----
Create vmanager_db database...
Database vmanager_db Was created.
User: lampn0, Password *****
Database vmanager_db is connected.
- Starting vmgr Project Migration...
Profile vmgr_2409_2323 created
[root@localhost vManager_environment]# vmgrserver -start -profile vManager_Server/vmgr_2409_2323
Starting Verisium Manager Standard Server [dt21-linux:21]..........,[FAILED]
FAILED deploying
Stopping server
Stopping Server..[OK]
发表于 2025-4-8 18:07:40 | 显示全部楼层
I would fix the descriptors as given in the warning.
Do you have enough free memory (min 2GB RAM check with free -g) ?
 楼主| 发表于 2025-4-8 18:11:05 | 显示全部楼层
Do you have enough free memory (min 2GB RAM che ...
Yes, my PC has 32GB RAM
 楼主| 发表于 2025-4-8 18:34:06 | 显示全部楼层
*************** Profile 'vmgr_2409_2323' settings: **************
Type=STANDARD
Server port=21
Server host=localhost
Server maximum heap size = 65536m
DB Host = localhost
DB Port = 2323
DB User = lampn0
DB Name = vmanager_db
Server is not running.
GMT+8, 2025-9-29 07:47 , Processed in 0.015734 second(s), 3 queries , Gzip On, Redis On.
