查看: 1580|回复: 2
[求助] innovus如何使用signoffTimeDesign
发表于 2024-10-7 13:05:12 | 显示全部楼层 |阅读模式
悬赏500资产已解决
        如题,我在使用innovus执行signoffTimeDesign和signoffOptDesign时出现以下错误,根据提示需要设置remoteHost,但是不知道怎么进行设置,这个问题该怎么解决呢?
  1. <CMD> setMultiCpuUsage -remoteHost 0
  2. <CMD> signoffTimeDesign -reportOnly
  3. *info: Tempus executable from /mnt/ssv/SSV19.10.000/bin
  4. *info: Starting servers to calculate signoff timing ... : (mem=1102.2M)
  5. **ERROR: (DMMMC-202):        Distributed processing has failed. The number of clients for job distribution has not been specified. You must specify it using the -remoteHost parameter of the setMultiCpuUsage command. In addition, you can also use the -cpuPerRemoteHost parameter to specify the thread count per client to enable multithreading on clients.
  6.
    复制代码
最佳答案
查看完整内容
setMultiCpuUsage -localCpu 8 -cpuPerRemoteHost 2 -remoteHost 4
发表于 2024-10-7 13:05:13 | 显示全部楼层
 楼主| 发表于 2024-10-7 15:02:38 | 显示全部楼层
虽然看到您的答案前已通过help文档找到答案,还是非常感谢您的回复!
GMT+8, 2025-9-18 07:24 , Processed in 0.013831 second(s), 4 queries , Gzip On, Redis On.
