楼主: smc1017
Synopsys License Error
 楼主| 发表于 2024-7-30 04:47:57 | 显示全部楼层
joshua2784920 发表于 2024-7-29 20:29
You could download SCL 24.06.....
补充内容 (2024-6-30 23:13):
I have already managed to verify the licenses, but when I invoke fc_shell, I encounter the following message:
Unable to get shell start-up license keys. Cannot invoke shell. Following license(s) must exist: Fusion-Compiler-NX.
Maximum memory usage for this session: 96.53 MB
Maximum memory usage for this session including child processes: 96.53 MB
CPU usage for this session: 2 seconds (0.00 hours)
Elapsed time for this session: 143 seconds (0.04 hours)
Thank you for using Fusion Compiler.
also here is my license
Synopsys.txt
1.02 MB, 下载次数: 143 , 下载积分: 资产 -2 信元, 下载支出 2 信元
lic
发表于 2024-7-30 05:19:27 | 显示全部楼层
smc1017 发表于 2024-7-30 04:47
I have already managed to verify the licenses, but when I invoke fc_shell, I encounter the followi ...
Did you perform below sequence after lmgrd start ?
  % ../daemon/snpslmd/lmutil lmreread -c snpslmd.lic
Acually, the sequence for the snpslmd daemon with working license file.
% ../daemon/snpslmd/lmgrd  -c  snpslmd.lic  -l snpslmd.log
% cat  snpslmd.log
     you need to wait until fully message done ,  you might repaet "cat  snpslmd.log" command for wating  until snpslmd read and service started.
And .... you need to share "snpslmd.log" ,  "snpslmd.lic"  and  "fc_shell.log" file also.    :::   This mean that   daemon log file , license file and  tool log file.
The partial message is not enought to figure out  the issue.
发表于 2024-7-30 08:00:05 | 显示全部楼层
smc1017 发表于 2024-7-30 04:29
I have already managed to verify the licenses, but when I invoke fc_shell, I encountered the follow ...
In my running test of "Fusion Compiler" with your license file, tere is no issue.
This mean that  your license file has no problem.
You has been missed below procedure becasue your log file has no event rereading step.
发表于 2024-7-30 11:31:43 | 显示全部楼层
07/29/2024 23:39:33 (snpslmd) All revenue keys ("SN=RK:..." on feature line ) have been excluded.
Your license file was not passed the sss check. Try lmreread -c xxx  to see whether you are lucky.
 楼主| 发表于 2024-7-30 17:45:35 | 显示全部楼层
This mean th ...
fc_shell
[SCL] Error: One possible reason for this error is that FLEXlm version of the application is higher than the license daemon version. If this is the case, please upgrade the license daemon to latest version (SCL-602)
Unable to get shell start-up license keys. Cannot invoke shell. Following license(s) must exist : Fusion-Compiler-NX.
Maximum memory usage for this session: 96.54 MB
Maximum memory usage for this session including child processes: 96.54 MB
CPU usage for this session: 18 seconds (0.00 hours)
Elapsed time for this session: 116 seconds (0.03 hours)
I use scl2024.06
发表于 2024-7-30 21:13:59 | 显示全部楼层
smc1017 发表于 2024-7-30 17:45
fc_shell
[SCL] Error: One possible reason for this error is that FLEXlm version of the applicatio ...
You naver answer for my question about "lmreread".
This is important and essential.
There is no trace of rereading in the daemon log you show.
If you don't answer this, you will not make any progress on this issue.
The other person above said that it was lucky to get reread working because he doesn't know how to get it to work with the Synapsis fake license.
Why do you think it works in my tests with the same license file you provided, but not in yours?
 楼主| 发表于 2024-8-1 18:28:30 | 显示全部楼层
here it's
snpslmd.txt
492.76 KB, 下载次数: 79 , 下载积分: 资产 -2 信元, 下载支出 2 信元
log
发表于 2024-8-2 21:27:15 | 显示全部楼层
TT.7z file include below files.
log.snpslmd_1st                : 1st your.snpslmd_lic log      - Invalid license key (inconsistent authentication code)
log.snpslmd_2nd        : 2nd your.snpslmd_lic log file - has no error )
your.snpslmd_lic        : your snpslmd_lic file with my server name and mac
        SERVER abdelazeem 000c294d9fe9 27050
        DAEMON snpslmd
        => change to my server MAC and name
        #SERVER abdelazeem 000c294d9fe9 27050
        SERVER lnx2016 3417EBC787D4 27004
        DAEMON snpslmd
your.snpslmd_lic.jpg        : lic checkout success and fc_shell running after your.snpslmd_lic.log capture
your.snpslmd_lic.log        : log file when daemon start and reread
my.snpslmd_lic.jpg        : lic checkout success and fc_shell running with my license file
pubkey_v1.6.tar.gz        : pubkey_verify , synopsys_checksum
This mean that your license file has no issue.
I have confirmed from your log file that you ran lmreread after executing lmgrd.
It seems that the following two binary patches were not applied after installing FusionCompiler V-2023.12-SP4.
You need to execute the following two commands with root privileges.
This is because if you run them from a user account, the patch may not be applied if the file mode is often set to read-only.
        % pubkey_verify -y
        % synopsys_checksum -y
In my case, I do not use 1shell or 1patch.
I use the pubkey_v1.6 version.
The fact that this was not executed is likely the reason it did not work for you.
There are no other reasons why FusionCompiler would not run.
TT.7z
3.45 MB, 下载次数: 296 , 下载积分: 资产 -2 信元, 下载支出 2 信元
500
 楼主| 发表于 2024-8-3 00:53:20 | 显示全部楼层
joshua2784920 posted on 2024-8-2 21:27
Doesn't work-
CPU usage for this session: 16 seconds (0.00 hours)
Elapsed time for this session: 101 seconds (0.03 hours)
发表于 2024-8-3 04:24:39 | 显示全部楼层
thanks, admire your patience
GMT+8, 2025-11-3 05:11 , Processed in 0.022040 second(s), 4 queries , Gzip On, Redis On.
