楼主: smc1017
Synopsys License Error
 楼主| 发表于 2024-7-29 01:52:59 | 显示全部楼层
joshua2784920 发表于 2024-7-28 13:37
When you generate lic file using "scl_keygen.exe" , then you don't need to verify SSS Feature by sss ...
I doesn't work also -
回复 支持 0 反对 1
 楼主| 发表于 2024-7-29 01:54:43 | 显示全部楼层
gobar25 发表于 2024-7-28 15:42
its tragic  that nobody offered the original poster any solution
Noone.
发表于 2024-7-29 05:49:11 | 显示全部楼层
Could you upload your snpslmd daemon log file?
I mean that it should be full file not a partial one.
The log file that have all envent from initial daemon start to when you check out fail.
This is helpful to resoulve it.
Addtionally,  you need to the command sequence to run daemon .
Could you campare with your command sequence to run daemon ?
In my case ,....
1. daemon run starting
      % ../daemon/snpslmd/lmgrd  -c  snpslmd.lic  -l snpslmd.log
2.  repeat  until  below message showing...
     % cat  snpslmd.log
07/28/2024 16:22:18 (snpslmd) ------------------------------------------------------------------
07/28/2024 16:22:18 (snpslmd) Checking the integrity of the license file...
07/28/2024 16:22:18 (snpslmd) The SSS features are garbled.
07/28/2024 16:22:18 (snpslmd) All revenue keys ("SN=RK:..." on feature line) have been excluded.
3. After this message showing , then perform to lmreread  with the same license file
     % ../daemon/snpslmd/lmutil lmreread -c snpslmd.lic
4. Afer that, you could find below message.
16:22:34 (lmgrd) Done rereading
16:22:34 (lmgrd) ...Finished rereading
5.  And then review the check out status on log file when you run S tools.
    % tail -f  snpslmd.log
发表于 2024-7-29 16:06:46 | 显示全部楼层
论坛搜索一下2023.09的scl patch
 楼主| 发表于 2024-7-29 19:32:22 | 显示全部楼层
I mean that it should be full file not a partial ...
here is the file.
synopsys.txt
1.33 MB, 下载次数: 119 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Log
发表于 2024-7-29 20:02:55 | 显示全部楼层
smc1017 发表于 2024-7-29 19:32
here is the file.
It seems to be using an unpatched snpslmd.
Please refer below. And find the "patched snpslmd" 2024.06
https://pan.baidu.com/s/19oay2_fhxw2wLIRzGMPoGg?pwd=51ny     code : 51ny
01.Synopsys >> scl >> scl_v2024.06 >> scl_v24.06-Linux64.zip
点评
Your link is no more working, can you share the working link?  发表于 2024-12-26 16:41
发表于 2024-7-29 20:03:33 | 显示全部楼层
here is the file.
same error, im also fetting in my sysytem, some one help me ... . . .
发表于 2024-7-29 20:29:59 | 显示全部楼层
here is the file.
You could download SCL 24.06.....
补充内容 (2024-6-30 23:13):
链接:https://pan.baidu.com/s/11Z7-U-oj_RQEE4UPja-F7w
提取码:yicl
 楼主| 发表于 2024-7-30 03:55:48 | 显示全部楼层
joshua2784920 posted on 2024-7-29 20:29
Additional content (2024-6-30 23:13):
I have already managed to verify the licenses, but when I invoke fc_shell, I encounter the following message:
Unable to get shell start-up license keys. Cannot invoke shell. Following license(s) must exist: Fusion-Compiler-NX.
Maximum memory usage for this session: 96.53 MB
Maximum memory usage for this session including child processes: 96.53 MB
CPU usage for this session: 2 seconds (0.00 hours)
Elapsed time for this session: 143 seconds (0.04 hours)
Thank you for using Fusion Compiler.
also here is my log file
07/29/2024 23:12:46 (snpslmd) ------------------------------------------------------------------
07/29/2024 23:12:46 (snpslmd) Checking the integrity of the license file...
07/29/2024 23:12:46 (snpslmd) The SSS features are garbled.
07/29/2024 23:12:47 (snpslmd) All revenue keys ("SN=RK:..." on feature line) have been excluded.
07/29/2024 23:12:47 (snpslmd) ------------------------------------------------------------------
07/29/2024 23:12:51 (snpslmd) INFO: Server WAN NC data enabled
23:12:53 (snpslmd) Changing message security level from -1 to 0
23:12:53 (snpslmd) SLOG: Statistics Log Frequency is 240 minute(s).
23:12:53 (snpslmd) SLOG: TS update poll interval is 0. TS update is detected by midnight reread only.
23:12:53 (snpslmd) SLOG: Activation borrow reclaim percentage is 0.
23:12:53 (snpslmd) (@snpslmd-SLOG@) ===============================================
23:12:53 (snpslmd) (@snpslmd-SLOG@) === Vendor Daemon ===
23:12:53 (snpslmd) (@snpslmd-SLOG@) Vendor daemon: snpslmd
23:12:53 (snpslmd) (@snpslmd-SLOG@) Start-Date: Mon Jul 29 2024 23:12:53 EEST
23:12:53 (snpslmd) (@snpslmd-SLOG@) PID: 6397
23:12:53 (snpslmd) (@snpslmd-SLOG@) VD Version: v11.19.6.0 build 293152 x64_linux ( build 293152 (ipv6))
23:12:53 (snpslmd) (@snpslmd-SLOG@) === Startup/Restart Info ===
23:12:53 (snpslmd) (@snpslmd-SLOG@) Options file used: None
23:12:53 (snpslmd) (@snpslmd-SLOG@) Is vendor daemon a CVD: Yes
23:12:53 (snpslmd) (@snpslmd-SLOG@) Is FlexNet Licensing Service installed and compatible: No
23:12:53 (snpslmd) (@snpslmd-SLOG@) FlexNet Licensing Service Version: -NA-
23:12:53 (snpslmd) (@snpslmd-SLOG@) Is TS accessed: No
23:12:53 (snpslmd) (@snpslmd-SLOG@) TS access time: -NA-
23:12:53 (snpslmd) (@snpslmd-SLOG@) Number of VD restarts since LS startup: 0
23:12:53 (snpslmd) (@snpslmd-SLOG@) === Network Info ===
23:12:53 (snpslmd) (@snpslmd-SLOG@) Listening port: 43725
23:12:53 (snpslmd) (@snpslmd-SLOG@) Daemon select timeout (in seconds): 1
23:12:53 (snpslmd) (@snpslmd-SLOG@) === Host Info ===
23:12:53 (snpslmd) (@snpslmd-SLOG@) Host used in license file: abdelazeem
23:12:53 (snpslmd) (@snpslmd-SLOG@) HostID node-locked in license file: 000c294d9fe9
23:12:53 (snpslmd) (@snpslmd-SLOG@) HostID of the License Server: 000c294d9fe9
23:12:53 (snpslmd) (@snpslmd-SLOG@) Running on Hypervisor: Unknown Hypervisor
 楼主| 发表于 2024-7-30 04:29:35 | 显示全部楼层
I have already managed to verify the licenses, but when I invoke fc_shell, I encountered the following message:
and also this log file
07/29/2024 23:39:33 (snpslmd) ---------------------------------------- -----------------------------
07/29/2024 23:39:33 (snpslmd) Checking the integrity of the license file. ..
07/29/2024 23:39:33 (snpslmd) The SSS features are garbled.
07/29/2024 23:39:33 (snpslmd) All revenue keys ("SN=RK:..." on feature line ) have been excluded.
07/29/2024 23:39:33 (snpslmd) -------------------------------- ----------------------------------
07/29/2024 23:39:41 (snpslmd) INFO: Server WAN NC data enabled
23:39:43 (snpslmd) Changing message security level from -1 to 0
23:39:43 (snpslmd) SLOG: Statistics Log Frequency is 240 minute(s).
23:39:43 (snpslmd) SLOG: TS update poll interval is 0. TS update is detected by midnight reread only.
23:39 :43 (snpslmd) SLOG: Activation borrow reclaim percentage is 0.
23:39:43 (snpslmd) (@snpslmd-SLOG@) ===================== ==========================
23:39:43 (snpslmd) (@snpslmd-SLOG@) === Vendor Daemon ===
23 :39:43 (snpslmd) (@snpslmd-SLOG@) Vendor daemon: snpslmd
23:39:43 (snpslmd) (@snpslmd-SLOG@) Start-Date: Mon Jul 29 2024 23:39:43 EEST
23:39:43 (snpslmd) (@snpslmd-SLOG@) PID: 9276
23:39:43 (snpslmd) (@snpslmd-SLOG@) VD Version: v11.19.6.0 build 293152 x64_linux ( build 293152 (ipv6))
23: 39:43 (snpslmd) (@snpslmd-SLOG@) === Startup/Restart Info ===
23:39:43 (snpslmd) (@snpslmd-SLOG@) Options file used: None
23:39:43 (snpslmd) (@snpslmd-SLOG@) Is vendor daemon a CVD: Yes 23:39:43
(snpslmd) (@snpslmd-SLOG @) Is FlexNet Licensing Service installed and compatible: No
23:39:43 (snpslmd) (@snpslmd-SLOG@) FlexNet Licensing Service Version: -NA-
23:39:43 (snpslmd) (@snpslmd-SLOG@) Is TS accessed: No
23:39:43 (snpslmd) (@snpslmd-SLOG@) TS accessed: -NA-
23:39:43 (snpslmd) (@snpslmd-SLOG@) Number of VD restarts since LS startup: 0
23:39:43 (snpslmd) (@snpslmd-SLOG@) === Network Info ===
23:39 :43 (snpslmd) (@snpslmd-SLOG@) Listening port: 54039
23:39:43 (snpslmd) (@snpslmd-SLOG@) Daemon select timeout (in seconds): 1
23:39:43 (snpslmd) (@ snpslmd-SLOG@)
23:39:43 (snpslmd) (@snpslmd-SLOG@) === Host Info ===
23:39:43 (snpslmd) (@snpslmd-SLOG@) Host used in license file: abdelazeem
23:39:43 (snpslmd) (@snpslmd-SLOG@) HostID node-locked in license file: 000c294d9fe9
23:39:43 (snpslmd) (@snpslmd-SLOG@) HostID of the License Server : 000c294d9fe9
23:39:43 (snpslmd) (@snpslmd-SLOG@) Running on Hypervisor: Unknown Hypervisor
23:39:43 (snpslmd) (@snpslmd-SLOG@) ============ ===================================
23:39:43 (snpslmd) Ecomms: Encrypted Communication disabled
23:39:43 (snpslmd) TCP_NODELAY NOT enabled
23:39:43 (snpslmd) Listener Thread: running
GMT+8, 2025-11-3 05:11 , Processed in 0.021582 second(s), 5 queries , Gzip On, Redis On.
