查看: 13291|回复: 54
Synopsys License Error
发表于 2024-7-27 07:30:07 | 显示全部楼层 |阅读模式
After installing the synopsys software crack in the virtual machine centos7, it always fails. Please help...
> ../../linux64/bin/sssverify Synopsys.dat
Integrity check report for license file "Synopsys.dat".
Report generated on 27-Jul-2024 (SCL_2023.09)
Checking the integrity of the license file...
The SSS features are garbled.
All revenue keys ("SN=RK:..." on feature line) have been excluded.
Siteid: <No Site Id>, Server Hostid: 000c294d9fe9, Issued on: N/A
License file integrity check FAILED!
This is an INVALID license file. You SHOULD NOT use this license file.
Please use the license file as received from Synopsys, Inc.
MY License:
SERVER abdelazeem 000c294d9fe9 27050
DAEMON snpslmd /home/synopsys/scl/2023.09/linux64/bin/snpslmd
INCREMENT SSS snpslmd 1.0 12-dec-2030 1 CFA8ED0B4F3B2EBCE4AA \
VENDOR_STRING="47C53 9779B 422E1 B8DE3 5A1CB 1D261 CCF5C 69810 \
25AC1 9D0" ISSUER="Synopsys, Inc. [1/8/2014 0:43:49 26356 3.16.2]" \
NOTICE="[DO NOT DELETE/MODIFY SSS OR ANY OTHER KEYS IN THIS FILE]" \
SN=RK:0:0:1 SIGN="0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD EEEE FFFF 0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD"
INCREMENT 3D snpslmd 2030.12 30-dec-2030 99 \
VENDOR_STRING=^1+S&PID=06417599& SUPERSEDE ISSUED=01-apr-2004 ck=78 \
SN=RK:2671-0:167603:0 START=01-apr-2004 AUTH={ snpslmd=( \
LK=4F18BD0BC90A5633A6CC SIGN="0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD EEEE FFFF 0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD") }
INCREMENT 3P snpslmd 2030.12 30-dec-2030 99 \
VENDOR_STRING=^1+S&PID=06417599& SUPERSEDE ISSUED=01-apr-2004 ck=67 \
LK=9FD8BD4B8517E6A37B84 SIGN="0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD EEEE FFFF 0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD") }
INCREMENT 8alaxy-Zroute snpslmd 2030.12 30-dec-2030 99 \
VENDOR_STRING=^1+S&PID=06417599& SUPERSEDE ISSUED=01-apr-2004 ck=64 \
LK=5F78FDBB7A10CA57D3F6 SIGN="0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD EEEE FFFF 0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD") }
INCREMENT A3200DX snpslmd 2030.12 30-dec-2030 99 \
LK=5F487D4B85BCE9F640DB SIGN="0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD EEEE FFFF 0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD") }
INCREMENT A42MX snpslmd 2030.12 30-dec-2030 99 \
VENDOR_STRING=^1+S&PID=06417599& SUPERSEDE ISSUED=01-apr-2004 ck=73 \
LK=EFC8CD3B23D1B6F049D9 SIGN="0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD EEEE FFFF 0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD") }
INCREMENT A500K snpslmd 2030.12 30-dec-2030 99 \
VENDOR_STRING=^1+S&PID=06417599& SUPERSEDE ISSUED=01-apr-2004 \
ck=136 SN=RK:2671-0:167603:0 START=01-apr-2004 AUTH={ snpslmd=( \
LK=CF487D8B4E3EC32F72A6 SIGN="0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD EEEE FFFF 0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD") }
INCREMENT A54SX snpslmd 2030.12 30-dec-2030 99 \
VENDOR_STRING=^1+S&PID=06417599& SUPERSEDE ISSUED=01-apr-2004 ck=49 \
LK=FF386D2B25C2601F1046 SIGN="0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD EEEE FFFF 0000 1111 2222 3333 4444 5555 6666 7777 8888 9999 AAAA BBBB CCCC DDDD") }
 楼主| 发表于 2024-7-27 08:01:36 | 显示全部楼层
also when I do lmstat i got the following
lmstat
lmstat - Copyright (c) 1989-2023 Flexera. All Rights Reserved.
Flexible License Manager status on Sat 7/27/2024 02:57
License server status: 27050@eda
    License file(s) on eda: /home/synopsys/scl/2023.09/admin/license/Synopsys.dat:
eda: license server UP (MASTER) v11.19.4
Vendor daemon status (on eda):
   snpslmd: No socket connection to license server manager. (-7,10015)
发表于 2024-7-27 10:10:35 | 显示全部楼层
The integrity of the SSS feature was checked failed!
发表于 2024-7-27 11:22:11 | 显示全部楼层
You are missing "USE_SERVER" below "DAEMON " line.
Therfore .... Try below again
USE_SERVER
发表于 2024-7-27 11:23:42 | 显示全部楼层
You are missing  the  "USE_SERVER" line....
发表于 2024-7-27 15:21:45 | 显示全部楼层
估计所有用SCL_Keygen生成的都不带 "USE_SERVER",根本就不是这问题。
发表于 2024-7-27 16:58:24 | 显示全部楼层
Lic file ...
But your report is
eda != abdelazeem   ::  -> why ?????
Try again below
lmstat -a -c  27050@abdelazeem
 楼主| 发表于 2024-7-27 19:23:01 | 显示全部楼层
joshua2784920 发表于 2024-7-27 16:58
Lic file ...
Actually, sssverify itself fails
 楼主| 发表于 2024-7-27 19:25:35 | 显示全部楼层
yes, Do you have any idea?
 楼主| 发表于 2024-7-27 19:29:43 | 显示全部楼层
yes, Do you have any idea why?
GMT+8, 2025-11-3 05:13 , Processed in 0.212470 second(s), 3 queries , Gzip On, Redis On.
