查看: 13007|回复: 52
关于mismatch的两篇文章
发表于 2008-1-22 11:16:17 | 显示全部楼层 |阅读模式
两篇关于MOS Mismatch的文章
IEDM_match.pdf
145.27 KB, 下载次数: 410 , 下载积分: 资产 -2 信元, 下载支出 2 信元
mismatch-analog.pdf
606.99 KB, 下载次数: 813 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-1-22 15:30:55 | 显示全部楼层
goood
3q3q3q
发表于 2008-1-22 15:31:50 | 显示全部楼层
ting
tingting
发表于 2008-1-22 17:11:55 | 显示全部楼层
好东西 谢谢!!!
发表于 2008-1-22 17:25:34 | 显示全部楼层
thank you
发表于 2008-1-22 17:36:02 | 显示全部楼层
好东西 谢谢!!!
发表于 2008-1-23 21:44:55 | 显示全部楼层
Understanding MOSFET Mismatch
for Analog Design
Patrick G. Drennan, Member, IEEE, and Colin C. McAndrew, Senior Member, IEEE
发表于 2008-1-23 21:45:53 | 显示全部楼层
CONCLUSION
Accurate mismatch modeling is needed to avoid parametric
yield loss and overdesign. The common approach to MOSFET
mismatch modeling, based on and , leads to inaccurate predictions
over geometry and bias. Mismatch modeling based on
physical process parameters is significantly more accurate.
In addition, because the approach is based on physical
uncorrelated process parameters, the characterization procedure
identifies the parameters that have the greatest contribution
to mismatch. This helps process technologists identify key
areas to work on when trying to optimize a process for best
mismatch.
发表于 2008-3-3 15:18:50 | 显示全部楼层
谢谢!
楼主辛苦了。
发表于 2008-3-8 12:35:29 | 显示全部楼层
thanks for sharing!
GMT+8, 2025-11-2 15:20 , Processed in 0.247155 second(s), 6 queries , Gzip On, Redis On.
