查看: 2351|回复: 1
[求助] 请问:cadence specture仿真时这种报错怎么处理?
发表于 2022-5-28 23:44:53 | 显示全部楼层 |阅读模式
Warning from spectre.
    WARNING (CMI-2666): M85: Parasitic resistor `rs' of the device was smaller than `1.000000e-03'. To prevent possible convergence problem, add a larger global option `Minr' to eliminate the small resistor.
    WARNING (CMI-2666): M85: Parasitic resistor `rd' of the device was smaller than `1.000000e-03'. To prevent possible convergence problem, add a larger global option `Minr' to eliminate the small resistor.
    WARNING (CMI-2666): M71: Parasitic resistor `rs' of the device was smaller than `1.000000e-03'. To prevent possible convergence problem, add a larger global option `Minr' to eliminate the small resistor.
    WARNING (CMI-2666): M71: Parasitic resistor `rd' of the device was smaller than `1.000000e-03'. To prevent possible convergence problem, add a larger global option `Minr' to eliminate the small resistor.
    WARNING (CMI-2666): M70: Parasitic resistor `rs' of the device was smaller than `1.000000e-03'. To prevent possible convergence problem, add a larger global option `Minr' to eliminate the small resistor.
        Further occurrences of this warning will be suppressed.
发表于 2023-5-23 11:15:43 | 显示全部楼层
同样的问题 请问楼主解决了吗
GMT+8, 2025-9-16 22:22 , Processed in 0.011873 second(s), 5 queries , Gzip On, Redis On.
