查看: 57470|回复: 163
cadence 软件ICADV/SSV/INNOVUS 最新版20210328
发表于 2021-3-28 11:31:00 | 显示全部楼层 |阅读模式
cadence 最新版软件,其中ICADV 包含hotfix 版本,
ICADV 启动virtuoso 闪退,原因已经找到,谢谢大家
使用的是1patch V0.3,http://bbs.eetop.cn/thread-896342-1-1.html
Centos 7.9
发表于 2021-3-28 11:54:26 | 显示全部楼层
ICADV201 我用着也是莫名崩,系统是centos6.7,ICADV18与IC6.18.500也没有这个问题
发表于 2021-3-28 12:30:04 | 显示全部楼层
看看,谢谢
发表于 2021-3-28 12:35:31 | 显示全部楼层
thanks...
发表于 2021-3-28 16:36:19 | 显示全部楼层
软件还有别用太新了,IC设计稳定至上……
下面这些信息可能对你有帮助……
In line with base releases and ISRs of other Cadence products, the ICADVM20.1 ISR17 and IC6.1.8 ISR17 releases now require FlexNet license server version v11.16.4.0 or higher. From these releases forward, you will no longer be able to run the software using older FlexNet versions. To upgrade your license server, you must download and install the latest Cadence Lic+Config_Utils release for Linux platforms (LCU04.30.000 and later). For more information, see the announcement on Cadence Downloads.
In the ICADVM20.1 base and IC6.1.8 ISR14 releases, X virtual framebuffer (Xvfb) replaced cdsXvnc as the default display server for Virtuoso running in non-graphics mode. Starting from ISR17, cdsXvnc is no longer shipped with the Virtuoso Custom IC design platform. You must now download Xvfb.rpm and install Xvfb in /usr/bin. After installation, this change will be transparent to the users. Before running simulations from the Virtuoso ADE product suite, ensure that Xvfb is installed on all computers where the netlisting jobs, such as ICRP or the netlisting process in LSCS, are running.
发表于 2021-3-28 16:37:41 | 显示全部楼层
参考链接:(有访问权限的可以去仔细看看)
https://community.cadence.com/ca ... isr17-now-available
发表于 2021-3-28 17:56:44 | 显示全部楼层
rhel 8.x
 楼主| 发表于 2021-3-28 18:17:56 | 显示全部楼层
下面这些信息可能对你有帮助……
In line with base releases and ...
感谢,
ICADV 软件自带lmgrd 版本太低,我重新下载了最新版的Lic+config_Utils ,发现版本也不够
又升级了hot fix 到最新版
然后再用1patch 重新path Lic+config_Utils
这里还出现了一个小插曲,我OA_HOME 路径指向了INNOVUS ,这里面的oa 是不如ICADV 版本高,导致起不来
重新设置OA 路径启动license
已经成功启动virtuoso ,没有问题
 楼主| 发表于 2021-3-28 18:19:51 | 显示全部楼层
candence 官网暂时不建议用redhat 8 ,如附件
Cadence_Platform_Support_Plan.pdf
77.7 KB, 下载次数: 236 , 下载积分: 资产 -2 信元, 下载支出 2 信元
platform.pdf
105.45 KB, 下载次数: 203 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2021-3-28 18:26:56 | 显示全部楼层
个人觉得?美关系,系统稳定最重要
rhel7.9 也快到服务期头了
8.x速度好些,感觉啊
GMT+8, 2025-10-15 08:54 , Processed in 0.017586 second(s), 4 queries , Gzip On, Redis On.
