查看: 67140|回复: 53
[原创] 802.3-2018 - IEEE Standard for Ethernet
发表于 2020-5-27 09:06:33 | 显示全部楼层 |阅读模式
Abstract:                                        Ethernet local area network operation is specified for selected speeds of operation from 1 Mb/s to 400 Gb/s using a common media access control (MAC) specification and management information base (MIB). The Carrier Sense Multiple Access with Collision Detection (CSMA/CD) MAC protocol specifies shared medium (half duplex) operation, as well as full duplex operation. Speed specific Media Independent Interfaces (MIIs) allow use of selected Physical Layer devices (PHY) for operation over coaxial, twisted pair or fiber optic cables, or electrical backplanes. System considerations for multisegment shared access networks describe the use of Repeaters that are defined for operational speeds up to 1000 Mb/s. Local Area Network (LAN) operation is supported at all speeds. Other specified capabilities include: various PHY types for access networks, PHYs suitable for metropolitan area network applications, and the provision of power over selected twisted pair PHY types.(The PDF of this standard is ...
        Scope:                                        This standard defines Ethernet local area, access and metropolitan area networks. Ethernet is specified at selected speeds of operation; and uses a common media access control (MAC) specification and management information base (MIB). The Carrier Sense Multiple Access with Collision Detection (CSMA/CD) MAC protocol specifies shared medium (half duplex) operation, as well as full duplex operation. Speed specific Media Independent Interfaces (MIIs) provide an architectural and optional implementation interface to selected Physical Layer entities (PHY). The Physical Layer encodes frames for transmission and decodes received frames with the modulation specified for the speed of operation, transmission medium and supported link length. Other specified capabilities include: control and management protocols, and the provision of power over selected twisted pair PHY types.
        [size=0.85em][url=](View more)[/url]
        Date of Publication:                                         31 Aug. 2018
        Electronic ISBN: 978-1-5044-5090-4
        DOI:                                         10.1109/IEEESTD.2018.8457469
        ICS Code:        35.100.10 35.110 - Physical layer      Networking
        Persistent Link:                                         https://ieeexplore.ieee.org/servlet/opac?punumber=8457467
                                        More »
        Publisher:                                        IEEE
IEEE_Std_802.3-2018-002.7z
6.41 MB, 下载次数: 443 , 下载积分: 资产 -3 信元, 下载支出 3 信元
压缩包2
IEEE_Std_802.3-2018-001.7z
30 MB, 下载次数: 518 , 下载积分: 资产 -9 信元, 下载支出 9 信元
压缩包1
发表于 2020-5-27 09:52:56 | 显示全部楼层
谢谢分享!
发表于 2020-5-27 09:56:48 | 显示全部楼层
当年做网络芯片的时候,还专门看的802。3
发表于 2020-6-5 12:21:52 | 显示全部楼层
下载下来解压不了是啥情况??
 楼主| 发表于 2020-6-11 11:01:39 | 显示全部楼层
lvhualei911 发表于 2020-6-5 12:21
下载下来解压不了是啥情况??
用7zip解压,谢谢!
发表于 2020-6-14 23:59:12 | 显示全部楼层
7Z  也打不开,提示文件有错误
发表于 2020-6-15 00:57:14 | 显示全部楼层
谢谢分享
发表于 2020-6-15 08:17:55 | 显示全部楼层
GOOD
发表于 2020-6-15 09:17:00 | 显示全部楼层
7zip也打不开
发表于 2020-7-8 09:48:09 | 显示全部楼层
Thanks.......
GMT+8, 2025-9-28 02:10 , Processed in 0.021412 second(s), 4 queries , Gzip On, Redis On.
