查看: 5038|回复: 6
run Calibre PERC 問題
发表于 2018-8-31 11:53:06 | 显示全部楼层 |阅读模式
我用MGC_HOME中share case run PERC 出现以下讯息是什么问题(不管试什么case 都出现)--------------------------------------------------------------------------------
-----                CALIBRE:ERC - INITIALIZATION MODULE                 -----
Performing global initialization ...
Initializing LVS ...
//  Applying licensing policy...
Initializing REPORT ...
--- CALIBRE:ERC INITIALIZATION MODULE COMPLETED.  CPU TIME = 0  REAL TIME = 0  LVHEAP = 1/3/3  MALLOC = 31/31/31  ELAPSED TIME = 1
-----          CALIBRE:ERC  -  EXECUTIVE MODULE                           -----
LVS Netlist Compiler - Errors and Warnings
Error: Subcircuit "PERC__TOP_DUMMY" not found
ERROR: Layout could not be read.
发表于 2021-3-13 19:18:09 | 显示全部楼层
请问解决了吗,我也遇到了layout could not be read的问题,报more than one subcircuit definition found for “CELL”
发表于 2021-3-13 19:20:16 | 显示全部楼层
请问解决了吗?我也遇到了layout could not be read 的问题,报 more than one subcircuit definition found for "CELL NAME",please specify the number of pins. 不知道是什么原因.
发表于 2021-12-1 21:27:44 来自手机 | 显示全部楼层
请问怎么run perc
发表于 2022-8-15 00:42:47 | 显示全部楼层
宝贝,字面意思吧,我觉得ERROR: layout could not be read.在calibre就只有一种意思呀
发表于 2024-1-28 21:11:35 | 显示全部楼层
网表里面cell被调用了,但是没有定义,一般是topcell写错了
发表于 2024-1-28 23:40:44 | 显示全部楼层
thanks
GMT+8, 2025-9-18 22:37 , Processed in 0.014443 second(s), 3 queries , Gzip On, Redis On.
