查看: 3739|回复: 2
[求助] 关于library builder 问题,生成不了元件库
发表于 2017-3-30 16:27:17 | 显示全部楼层 |阅读模式
Location:d:\Users\Administrator\AppData\Roaming\SPB_Data\cdssetup\OrCAD_Capture/16.6.0/Capture.ini
ERROR(SPSMI-1): Unable to parse the XML file D:\Documents/11.xml at line 5 at
col 98 because of Attribute 'pcbFootprint' is not declared for element 'Defn'.
Ensure that the installation has been done properly.
大神求解答!
发表于 2017-4-20 10:25:58 | 显示全部楼层
回复 1# 王鑫臣
E:\DXP\cadence\orCADLibraryBuilder\expert\symbol/AD8599.xml at line 5 at col
100 because of Attribute 'pcbFootprint' is not declared for element 'Defn'.
   我这也有同样的问题,你的解决了吗?
 楼主| 发表于 2017-4-20 15:14:21 | 显示全部楼层
回复 2# 岩帅
    还没有,找了很多资料,并没有办法解决。
GMT+8, 2025-11-7 03:39 , Processed in 0.012472 second(s), 5 queries , Gzip On, Redis On.
