查看: 2522|回复: 1
[原创] 无线湿温度传感器
发表于 2016-1-14 13:14:10 | 显示全部楼层 |阅读模式
无线温湿度传感的解决方案:
1. 外部仅需要连接温湿度传感器(SI7020,SI7021,HTU20,SHT20) 和 电池 (3-3.6V)
2. 传输距离可以选择:  50米, 和 500米直线两种
3. 传感器,用串口进行各种配置(测温间隔,发送间隔,温度高温门限)
4. 目前有4种板型可供选择,满足客户各种外观需求
5. 静态功耗低至 2.7-6UA, 60S检测一次, 5分钟发一次. 平均功耗小于10UA
6. 实时电池电压检测
  7 发射功率:  500米  20DBM (MAX), 50米 0DBM 符合FCC, CE, SRCC,认证标准
  8 支持在线升级, 串口可以升级最新温度传感的固件来满足市场的变化
  9. 256 通道,同时允许256组产品工作,互不干扰.
  无线温湿度传感器, 广泛用于 粮库, 蔬菜大棚 ,电力监控, 机房监控, 智能家居 等各种环境监控场合.
1. External Connect Sensor Small board and Battery (3-3.6V)
2. Transmit Distance can be chose:  50- 800 Meter
3. The flexible setting Parameter meet the complex environment
4. Four Type's wireless module suit for Case and  cost.
5. Static Power Consumption 2.7-6UA. Average Power consumption is less than 10ua if send sensor data each 60s.
6. Battery Monitor function is Active. RSSI is support in the receive Part.
  7  Output Power:  0-20DBM
  8  Firmware can be updated according to customer requirement.
  9. 256 Channel
Wireless temperature and humidity sensors, widely used in grain, vegetable greenhouses, power monitoring, monitoring room, smart home, a variety
of environmental monitoring applications.
图片2.png                                            图片1.png           无线湿温度传感器.pdf (652.04 KB , 下载次数: 1 )
发表于 2016-1-15 00:27:34 | 显示全部楼层
回复 1# happyyun
   谢谢
GMT+8, 2025-11-4 14:52 , Processed in 0.020472 second(s), 6 queries , Gzip On, Redis On.
