查看: 2790|回复: 4
[原创] 【K70例程】022I2S音频驱动_SGTL5000_SDHC_MQX_K70EKT7
发表于 2014-1-9 18:35:20 | 显示全部楼层 |阅读模式
使用J-LinkV8
MDKKeil版本4.71
调试串口波特率:115200
基于MDKK70-EK_T70硬件平台
关键词: Freescale 飞思卡尔 Kinetis Cortex-M4 K70 MDKK70 核心板 开发板 例程 SGTL5000 SDHC MQX I2S
实验现象:
串口输出:
Setting up time......................[OK]
Initializing audio codec.............[OK]
Creating shell task..................[OK]
Creating SD card task................[OK]
Audio driver demo application
Shell (build: Dec  5 2013)
Copyright (c) 2008 Freescale Semiconductor;
shell>
shell>
  SD card installed to "a:"
shell>help
Available commands:
   cd <directory>
   del <file>
   dir [<filespec>] [<attr>]]
   exit
   help [<command>]
   mkdir <directory>
   ren <oldname> <newname>
   rmdir <directory>
   play <device> <filename>
   record <device> <filename> <format>
shell> dir
A.WAV          441044 12-06-2013 11:35:56      A A.WAV
BB.WAV        4399198 12-06-2013 14:17:12      A BB.WAV
shell> play sai: a:/bb.wav
  Playback information
  Sampling frequency:     22050 Hz
  Bit depth:              16 bits
  Channels:               mono
  Data rate:              44 kbyte/s
  Playing a file...DONE
  Playback stats
  Total interrupts:              549934
  Bytes requested for transmit:  4399154
  Bytes transmitted:             4399154
  Underruns of hardware FIFO:    0
  Software buffer empty:         39
shell>
该K70音频例程基于MQX操作系统,仅支持wav文件播放,文件放置于SD/TF卡中并插到K70EK上,更多信息请参考MQX例程。
 楼主| 发表于 2014-1-9 18:35:48 | 显示全部楼层
 楼主| 发表于 2014-1-9 18:36:28 | 显示全部楼层
022.rar (4.98 MB , 下载次数: 4 )
发表于 2014-6-4 08:33:17 | 显示全部楼层
下下来学习
发表于 2016-9-8 20:50:24 | 显示全部楼层
太好了,谢谢老板啊
GMT+8, 2025-11-4 05:29 , Processed in 0.022354 second(s), 6 queries , Gzip On, Redis On.
