查看: 5234|回复: 4
[求助] 请教一个cadence 16.5中原理图生产网表的问题
发表于 2013-7-7 20:44:51 | 显示全部楼层 |阅读模式
#1   ERROR(SPCOPK-1051): Cannot find the physical part DB9 for
        Schematic instance: @1111_LIB.34(SCH_1)AGE1_I32@SCHLIB.DB9(CHIPS)
        Physical Path: @\1111_lib\.\34\(sch_1):page1_i32@schlib.db9(chips)
        The chips.prt file might have been accidentally edited, or the PACK_TY~
PE property might be missing from the ptf file or the schematic.
        Ensure that a physical part corresponding to the instance used in the ~
schematic exists and the PACK_TYPE property is defined in the schematic or the~
part table file.
#2   ERROR(SPCOPK-1052): No ppt part selected because the instance has no phy~
sical part.
我仔细检查了下,它的part这些都有,不晓得什么原因出的错,知道的告知一下,谢谢
发表于 2013-7-8 13:40:15 | 显示全部楼层
表示不懂!
发表于 2013-7-8 20:23:44 | 显示全部楼层
帮顶一个!
 楼主| 发表于 2013-7-17 00:22:57 | 显示全部楼层
因为一个symbol代表了多个pad,而我调用的一个有问题,重新做一个就对了
发表于 2013-7-19 15:41:02 | 显示全部楼层
正在学习,过来mark一下
GMT+8, 2025-9-17 23:15 , Processed in 1.895952 second(s), 6 queries , Gzip On, Redis On.
