查看: 12824|回复: 38
[原创] The Scientist and Engineer's Guide to Digital Signal Processing
发表于 2013-5-6 12:13:15 | 显示全部楼层 |阅读模式
FOUNDATIONS
Chapter 1 - The Breadth and Depth of DSP
The Roots of DSP
Telecommunications
Audio Processing
Echo Location
Image Processing
Chapter 2 - Statistics, Probability and Noise
Signal and Graph Terminology
Mean and Standard Deviation
Signal vs. Underlying Process
The Histogram, Pmf and Pdf
The Normal Distribution
Digital Noise Generation
Precision and Accuracy
Chapter 3 - ADC and DAC
Quantization
The Sampling Theorem
Digital-to-Analog Conversion
Analog Filters for Data Conversion
Selecting The Antialias Filter
Multirate Data Conversion
Single Bit Data Conversion
Chapter 4 - DSP Software
Computer Numbers
Fixed Point (Integers)
Floating Point (Real Numbers)
Number Precision
Execution Speed: Program Language
Execution Speed: Hardware
Execution Speed: Programming Tips
FUNDAMENTALS
Chapter 5 - Linear Systems
Signals and Systems
Requirements for Linearity
Static Linearity and Sinusoidal Fidelity
Examples of Linear and Nonlinear Systems
Special Properties of Linearity
Superposition: the Foundation of DSP
Common Decompositions
Alternatives to Linearity
Chapter 6 - Convolution
The Delta Function and Impulse Response
Convolution
The Input Side Algorithm
The Output Side Algorithm
The Sum of Weighted Inputs
Chapter 7 - Properties of Convolution
Common Impulse Responses
Mathematical Properties
Correlation
Speed
Chapter 8 - The Discrete Fourier Transform
The Family of Fourier Transform
Notation and Format of the Real DFT
The Frequency Domain's Independent Variable
DFT Basis Functions
Synthesis, Calculating the Inverse DFT
Analysis, Calculating the DFT
Duality
Polar Notation
Polar Nuisances
Chapter 9 - Applications of the DFT
Spectral Analysis of Signals
Frequency Response of Systems
Convolution via the Frequency Domain
Chapter 10 - Fourier Transform Properties
Linearity of the Fourier Transform
Characteristics of the Phase
Periodic Nature of the DFT
Compression and Expansion, Multirate methods
Multiplying Signals (Amplitude Modulation)
The Discrete Time Fourier Transform
Parseval's Relation
Chapter 11 - Fourier Transform Pairs
Delta Function Pairs
The Sinc Function
Other Transform Pairs
Gibbs Effect
Harmonics
Chirp Signals
Chapter 12 - The Fast Fourier Transform
Real DFT Using the Complex DFT
How the FFT works
FFT Programs
Speed and Precision Comparisons
Further Speed Increases
Chapter 13 - Continuous Signal Processing
The Delta Function
Convolution
The Fourier Transform
The Fourier Series
DIGITAL FILTERS
Chapter 14 - Introduction to Digital Filters
Filter Basics
How Information is Represented in Signals
Time Domain Parameters
Frequency Domain Parameters
High-Pass, Band-Pass and Band-Reject Filters
Filter Classification
Chapter 15 - Moving Average Filters
Implementation by Convolution
Noise Reduction vs. Step Response
Frequency Response
Relatives of the Moving Average Filter
Recursive Implementation
Chapter 16 - Windowed-Sinc Filters
Strategy of the Windowed-Sinc
Designing the Filter
Examples of Windowed-Sinc Filters
Pushing it to the Limit
Chapter 17 - Custom Filters
Arbitrary Frequency Response
Deconvolution
Optimal Filters
Chapter 18 - FFT Convolution
The Overlap-Add Method
FFT Convolution
Speed Improvements
Chapter 19 - Recursive Filters
The Recursive Method
Single Pole Recursive Filters
Narrow-band Filters
Phase Response
Using Integers
Chapter 20 - Chebyshev Filters
The Chebyshev and Butterworth Responses
Step Response Overshoot
Stability
Chapter 21 - Filter Comparison
Match #1: Analog vs. Digital Filters
Match #2: Windowed-Sinc vs. Chebyshev
Match #3: Moving Average vs. Single Pole
APPLICATIONS
Chapter 22 - Audio Processing
Human Hearing
Timbre
Sound Quality vs. Data Rate
High Fidelity Audio
Companding
Speech Synthesis and Recognition
Nonlinear Audio Processing
Chapter 23 - Image Formation & Display
Digital Image Structure
Cameras and Eyes
Television Video Signals
Other Image Acquisition and Display
Brightness and Contrast Adjustments
Grayscale Transforms
Warping
Chapter 24 - Linear Image Processing
Convolution
3x3 Edge Modification
Convolution by Separability
Example of a Large PSF: Illumination Flattening
Fourier Image Analysis
FFT Convolution
A Closer Look at Image Convolution
Chapter 25 - Special Imaging Techniques
Spatial Resolution
Sample Spacing and Sampling Aperture
Signal-to-Noise Ratio
Morphological Image Processing
Computed Tomography
Chapter 26 - Neural Networks (and more!)
Target Detection
Neural Network Architecture
Why Does it Work?
Training the Neural Network
Evaluating the Results
Recursive Filter Design
Chapter 27 - Data Compression
Data Compression Strategies
Run-Length Encoding
Huffman Encoding
Delta Encoding
LZW Compression
JPEG (Transform Compression)
MPEG
Chapter 28 - Digital Signal Processors
How DSPs are Different from Other Microprocessors
Circular Buffering
Architecture of the Digital Signal Processor
Fixed versus Floating Point
C versus Assembly
How Fast are DSPs?
The Digital Signal Processor Market
Chapter 29 - Getting Started with DSPs
The ADSP-2106x family
The SHARC EZ-KIT Lite
Design Example: An FIR Audio Filter
Analog Measurements on a DSP System
Another Look at Fixed versus Floating Point
Advanced Software Tools
COMPLEX TECHNIQUES
Chapter 30 - Complex Numbers
The Complex Number System
Polar Notation
Using Complex Numbers by Substitution
Complex Representation of Sinusoids
Complex Representation of Systems
Electrical Circuit Analysis
Chapter 31 - The Complex Fourier Transform
The Real DFT
Mathematical Equivalence
The Complex DFT
The Family of Fourier Transforms
Why the Complex Fourier Transform is Used
Chapter 32 - The Laplace Transform
The Nature of the s-Domain
Strategy of the Laplace Transform
Analysis of Electric Circuits
The Importance of Poles and Zeros
Filter Design in the s-Domain
Chapter 33 - The z-Transform
The Nature of the z-Domain
Analysis of Recursive Systems
Cascade and Parallel Stages
Spectral Inversion
Gain Changes
Chebyshev-Butterworth Filter Design
The Best and Worst of DSP
Chapter 34 - Explaining Benford's Law
Frank Benford's Discovery
Homomorphic Processing
The Ones Scaling Test
Writing Benford's Law as a Convolution
Solving in the Frequency Domain
Solving Mystery #1
Solving Mystery #2
More on Following Benford's law
Analysis of the Log-Normal Distribution
The Power of Signal Processing
The Scientist and Engineer's Guide to Digital Signal Processing.zip
10.31 MB, 下载次数: 954 , 下载积分: 资产 -4 信元, 下载支出 4 信元
发表于 2013-9-26 09:37:07 | 显示全部楼层
good good good
发表于 2013-10-18 10:01:31 | 显示全部楼层
good good good
发表于 2014-8-6 16:19:02 | 显示全部楼层
这本书不错,知道研读一下
发表于 2014-8-15 17:16:13 | 显示全部楼层
好东东,谢了
发表于 2014-8-20 21:22:05 | 显示全部楼层
听说很不错,下载研究一下。
发表于 2014-8-20 21:54:40 | 显示全部楼层
DSP的书,是通用的设计理论,貌似没有针对特定器件讲,挺好的
发表于 2014-10-4 23:45:11 | 显示全部楼层
谢谢分享
发表于 2015-2-12 10:59:06 | 显示全部楼层
can be download from internet or not ? Any way thanks
发表于 2015-3-20 22:55:10 | 显示全部楼层
此书不错
GMT+8, 2025-10-1 02:43 , Processed in 0.020897 second(s), 4 queries , Gzip On, Redis On.
