楼主: zhuyuefeng2009
[求助] 单片机的中断是怎么实现的呢?硬件做死的?
发表于 2013-9-26 16:56:19 | 显示全部楼层
硬件实现的吧,指令流水线设计那里设计好的。
发表于 2013-9-28 18:11:15 | 显示全部楼层
中断向量表只是一个映射的列表
发表于 2013-10-27 12:07:21 | 显示全部楼层
硬件实现,软件去应用
发表于 2013-12-8 15:05:25 | 显示全部楼层
单片机硬件的功能
发表于 2013-12-13 22:09:30 | 显示全部楼层
与功能寄存器有关,不过可以用软件实现
发表于 2013-12-15 02:24:56 | 显示全部楼层
环境保护以后PC(PROGRAM COUNTER)转向中断向量指向的入口
发表于 2014-3-11 16:36:02 | 显示全部楼层
You can jump to some different memory from predefined interrupt address. This is a general practice. In case of 8051 you can write 8 bytes of code in between 2 ISR vector location. If your code is large then you can have LCALL instruction. Write ISR handler to new location. You can change priority of interrupt. Startup code initializes memory and some cpu related registers and stack pointer
发表于 2014-3-14 09:56:27 | 显示全部楼层
回复 17# kirannevaskar
That's make sense , but I have another quetions.   A simple question , that if pc and stack share the register in the R-8051, then after the interrupt how could the PC go back to position ,I mean a general idea, not too much detail, when I read the VHDL code of a R-8051code but confusing with this, where it maybe concern ? in the ITR part, or RAM&SFR&MEM Ctrl part?
发表于 2014-3-14 16:07:42 | 显示全部楼层
硬件实现的,软件可配置
发表于 2014-3-21 02:41:57 | 显示全部楼层
了解下CPU是怎么执行指令的,就可以了解程序如何被中断。
GMT+8, 2025-9-18 23:29 , Processed in 0.020451 second(s), 5 queries , Gzip On, Redis On.
