查看: 3609|回复: 2
[求助] 求助:The TCP port number in the license
发表于 2012-10-27 21:49:36 | 显示全部楼层 |阅读模式
21:46:05 (lmgrd)   Please Note:
21:46:05 (lmgrd)
21:46:05 (lmgrd)   This log is intended for debug purposes only.
21:46:05 (lmgrd)   In order to capture accurate license
21:46:05 (lmgrd)   usage data into an organized repository,
21:46:05 (lmgrd)   please enable report logging. Use Acresso Software Inc.'s
21:46:05 (lmgrd)   software license administration  solution,
21:46:05 (lmgrd)   FLEXnet Manager, to  readily gain visibility
21:46:05 (lmgrd)   into license usage data and to create
21:46:05 (lmgrd)   insightful reports on critical information like
21:46:05 (lmgrd)   license availability and usage. FLEXnet Manager
21:46:05 (lmgrd)   can be fully automated to run these reports on
21:46:05 (lmgrd)   schedule and can be used to track license
21:46:05 (lmgrd)   servers and usage across a heterogeneous
21:46:05 (lmgrd)   network of servers including Windows NT, Linux
21:46:05 (lmgrd)   and UNIX. Contact Acresso Software Inc. at
21:46:05 (lmgrd)   www.acresso.com for more details on how to
21:46:05 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
21:46:05 (lmgrd)   for your enterprise.
21:46:05 (lmgrd)
21:46:05 (lmgrd) -----------------------------------------------
21:46:05 (lmgrd)
21:46:05 (lmgrd)
21:46:05 (lmgrd) The TCP port number in the license, 1717, is already in use.
21:46:05 (lmgrd) Possible causes:
21:46:05 (lmgrd)    1) The license server manager (lmgrd) is already running for this license.
21:46:05 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.
21:46:05 (lmgrd)    3) Another process is using this port number (unlikely).
21:46:05 (lmgrd) Solutions:
21:46:05 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this
21:46:05 (lmgrd)       license are not running.
21:46:05 (lmgrd)    2) You may have to wait for the OS to clear this port.
21:46:05 (lmgrd) Retrying for about 5 more minutes
那位大侠知道怎么解决这个问题,不胜感激!
发表于 2013-11-7 15:43:16 | 显示全部楼层
WARNING: 2 license server systems specified in license file.
15:48:38 (lmgrd) (an even number of server systems is probably a mistake.)
15:48:38 (lmgrd) You may have duplicated a SERVER line by mistake
15:48:38 (lmgrd)
15:48:38 (lmgrd) Failed to open the TCP port number in the license.
我也遇到了这个问题,你解决了没呢
 楼主| 发表于 2013-11-7 20:41:42 | 显示全部楼层
回复 2# 767616852
   我的好像当时是重装一次就好了
GMT+8, 2025-9-18 06:09 , Processed in 0.016530 second(s), 5 queries , Gzip On, Redis On.
