查看: 10523|回复: 31
[资料] PCb王牌设计文档!ultra cad公司经典设计指南及设计注意方向!
发表于 2011-4-2 16:54:13 | 显示全部楼层 |阅读模式
transmission line terminationsIt\'s the End That Counts. .pdf (314.95 KB , 下载次数: 28 ) abbr_4d8c58125a906d4bb007c2fb8237e802.pdf (562.93 KB , 下载次数: 19 ) Loop Areas, Close \'Em Tight! .pdf (22.47 KB , 下载次数: 16 ) wherestheloop.pdf (39.09 KB , 下载次数: 14 )
90 Degree Corners The Final Turn .pdf (72.23 KB , 下载次数: 15 )
What is This Thing Called Current Electrons, Displacement, Light, or What .pdf (50.56 KB , 下载次数: 11 ) What\'s All This Critical Length Stuff, Anyhow.pdf (232.41 KB , 下载次数: 16 )
Bypass Capacitors, an Interview With Todd Hubing.pdf (16.99 KB , 下载次数: 15 )
Controlling Impedances When Nets Branch Out.pdf (538.63 KB , 下载次数: 16 )
crossemianddifferentialz.pdf (87.15 KB , 下载次数: 10 )
crosstalk_coupling.pdf (603.69 KB , 下载次数: 16 )
crosstlk.pdf (45.73 KB , 下载次数: 7 ) Current Carrying Capacity of Vias; Some Conceptual Observations.pdf (184.02 KB , 下载次数: 16 )
differential design rules.pdf (194.8 KB , 下载次数: 17 )
Differential Impedance What\'s the Difference.pdf (17 KB , 下载次数: 8 )
Differential Signals Rules to Live By.pdf (129.13 KB , 下载次数: 14 )
Differential Signals, The Differential Difference.pdf (25.97 KB , 下载次数: 10 )
electromagnetic fields.pdf (256.2 KB , 下载次数: 18 )
Embedded Microstrip .pdf (19.88 KB , 下载次数: 11 )
ESR and Bypass Cap Self-Resonant Behavior, How to Select Bypass Caps.pdf (450.4 KB , 下载次数: 21 )
Gauging Traces .pdf (103.97 KB , 下载次数: 18 )
Ground Bounce, Parts 1 and 2 .pdf (46.88 KB , 下载次数: 20 )
Impedance Terminations What\'s the Value.pdf (13.02 KB , 下载次数: 12 )
mentor crosstalk part1.pdf (102.01 KB , 下载次数: 14 ) mentor crosstalk part 2.pdf (524.95 KB , 下载次数: 14 )
mentor termination placement.pdf (365.53 KB , 下载次数: 15 )
mentor signal timing2.pdf (700.62 KB , 下载次数: 11 ) mentor signal timing1.pdf (880 KB , 下载次数: 16 )
Microstrip Propagation Times; Slower Than We Think..pdf (3.14 MB , 下载次数: 16 ) PCB Impedance ControlFormulas and Resources.pdf (36.48 KB , 下载次数: 14 )
monthquiz.pdf (12.56 KB , 下载次数: 9 )
Slots in Planes Don\'t Use \'Em!.pdf (13.7 KB , 下载次数: 13 ) skin effect.pdf (143.84 KB , 下载次数: 17 )
propagationtime.pdf (26.16 KB , 下载次数: 8 ) Propagation Times and Critical Length How They Interrelate.pdf (209.4 KB , 下载次数: 13 )
Splitting Planes for Speed and Power.pdf (124.68 KB , 下载次数: 28 )
The Effects of Vias on PCB Traces .pdf (107.53 KB , 下载次数: 25 )
transmission line basics.pdf (189.13 KB , 下载次数: 16 )
Lessons Learned Along the Way RFI Control.pdf
154.45 KB, 下载次数: 16 , 下载积分: 资产 -2 信元, 下载支出 2 信元
uccalc_manual.pdf
180.32 KB, 下载次数: 15 , 下载积分: 资产 -2 信元, 下载支出 2 信元
when signal integrity matters.pdf
83.54 KB, 下载次数: 10 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2011-4-6 22:37:33 | 显示全部楼层
楼主啊,能不能整个压缩文件啊!
 楼主| 发表于 2011-4-7 09:28:46 | 显示全部楼层
回复 2# zm218wri
    要不你下了以后传个压缩的包把?
发表于 2011-4-7 15:38:44 | 显示全部楼层
dddddddddddddddddddddddddddddd
 楼主| 发表于 2011-4-7 15:46:19 | 显示全部楼层
回复 4# jodan2012
    请勿灌水!
发表于 2011-4-8 10:43:37 | 显示全部楼层
谢谢,下了慢慢看
 楼主| 发表于 2011-4-8 13:50:25 | 显示全部楼层
回复 6# yamaxiao
    全下了?能不能帮忙打个包。
发表于 2011-4-10 11:24:12 | 显示全部楼层
very good!
 楼主| 发表于 2011-4-11 08:49:27 | 显示全部楼层
回复 8# richard_z8
    NOT AT ALL
发表于 2011-4-15 19:07:33 | 显示全部楼层
楼主好不厚道!
君子爱财,取之有道!
你这完全违背了eetop的精神!
把人家公司挂在网上、类似于datasheet的东西来骗大家!
这是以上所有资料的下载链接:
http://www.ultracad.com/article_outline.htm
大家不要再下了!
GMT+8, 2025-9-18 06:00 , Processed in 0.056237 second(s), 6 queries , Gzip On, Redis On.
