在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
返回列表 发新帖
楼主: sean_4413
hspice 模型文件中迁移率u0 的求取
发表于 2009-3-7 14:58:01 | 显示全部楼层
My professor (a TI senior guy) gave us his routine design processes.  The very first step is to determine the characteristics of the device of interest.  The u0(k'), lambda, and vth are related to specific device dimensions.  You can choose a short and a long channel lengths as typical design
parameters.  Run simulation, read operating point data, and calculate needed values.  The accuracy is quite good.  The error between my theoretical estimation and the simulation is less than 5%.
 楼主| 发表于 2009-3-7 23:25:23 | 显示全部楼层
原帖由 pipida 于 2009-3-7 14:58 发表
My professor (a TI senior guy) gave us his routine design processes.  The very first step is to determine the characteristics of the device of interest.  The u0(k'), lambda, and vth are related to spe ...
谢谢,我试试看!以后还请大哥多多赐教!
发表于 2009-6-12 20:54:35 | 显示全部楼层
因为U0的单位,要明白单位啊
SPICE里的值应该*E-4
发表于 2009-6-12 23:10:56 | 显示全部楼层
模型里面有的
发表于 2009-6-13 00:00:44 | 显示全部楼层
在1um以下的沟道短沟道效应明显加大,我们以前用的公式都是沟道较长时的近似公式,短沟道时公式不再成立,要计算时需要加上其它参数及高次项,手算很复杂
发表于 2012-3-13 22:46:43 | 显示全部楼层
不好意思问一下那.35的栅氧厚度大概多少呢?回复 3# tjumicrosoft
发表于 2012-3-19 20:23:49 | 显示全部楼层
U0可以通过仿真得到。
发表于 2014-11-1 14:38:49 | 显示全部楼层
回复 1# sean_4413
   学习学习,,,顶起
小黑屋| 手机版| 关于我们| 联系我们| 在线咨询| 隐私声明| EETOP 创芯网
GMT+8, 2024-9-30 01:30 , Processed in 0.019576 second(s), 8 queries , Gzip On, Redis On.
