楼主: shuisou126
基于PROTEUS的ARM虚拟开发技术(免费的哦)
发表于 2012-3-16 21:35:52 | 显示全部楼层
thank you!!!!!!!!!!
发表于 2012-3-25 10:44:31 | 显示全部楼层
好。感谢你
发表于 2012-12-24 10:22:45 | 显示全部楼层
不错
发表于 2013-7-25 14:44:50 | 显示全部楼层
回复 2# prolity 楼主好人呀呀呀
发表于 2013-11-2 21:12:47 | 显示全部楼层
下载之后怎么感觉有点货不对板呢
发表于 2013-11-7 09:19:49 | 显示全部楼层
希望真的有用  不然真的好多錢!!
发表于 2014-5-11 15:53:25 | 显示全部楼层
回复 1# shuisou126
http://pan.baidu.com/share/link?shareid=2473061172&uk=3205150393
Microcontroller Development Kit - Validation version for MKD-ARM 4.72
  • [ARM Compiler]
    • This version of MDK-ARM contains
      ARM Compiler 5.03u2.
    • All compiler related files are located in
      ..\ARM\ARMCC\
      directory.
    • Details can be found in the
      Compiler specific Release Notes..
[µVision]
  • This MDK-ARM release is delivered with
    µVision V4.72.0.0 IDE.
[uVision Debugger][Middleware]
  • [ARM Middleware]
    • [TCPnet]
      • Added: support for user application notification in
        FTP Server
        service. An optional notification function
        ftp_evt_notify()
        may be used to receive notification of FTP server events, such as: user login, user logout, file upload, file download, etc.
      • Updated: handling of file
        write errors
        and data
        transfer aborts
        in
        FTP Server
        service. If a local file write error occurs, the service aborts file upload operation. Additionally, if the data connection is aborted, the service stops file download operation.
      • Added: support for extended DHCP
        option 42
        (NTP server list) in
        DHCP Client. An additional configuration option
        NTP Servers
        in Net_Config.c is used to enable or disable this option.
      • Added: command
        FTPC_CMD_NLIST
        in
        FTP Client
        service. This command lists only file names, without any additional file information.
      • Added:
        data transfer abort
        functionality in file retrieve operation of
        FTP Client
        service. The FTP client service now aborts data transfer, if a file write error occurs on local system.
      • Corrected: potential dynamic
        memory dead-lock, if
        HTTP server
        is serving large web resources.
    • [USB Device
      and
      USB Host]
      • Examples
        • Added: CDC example for
          Infineon Hexagon Application Kit
          in folder
          ..ARM\Boards\Infineon\Hexagon Application Kit\CPU_45A-V2\RL\USB\Device\CDC_ACM.
[New Supported Devices]
    • Atmel
      SAM4N16B,
      SAM4N16C,
      SAM4N8A,
      SAM4N8B,
      SAM4N8C,
      SAMD20E14,
      SAMD20E15,
      SAMD20E16,
      SAMD20E17,
      SAMD20G14,
      SAMD20G15,
      SAMD20G16,
      SAMD20G17,
      SAMD20G18,
      SAMD20J14,
      SAMD20J15,
      SAMD20J16,
      SAMD20J17, and
      SAMD20J18.
    • Cypress
      CY8C5265AXI-LP056,
      CY8C5265AXI-LP082,
      CY8C5265LTI-LP050,
      CY8C5265LTI-LP058,
      CY8C5266AXI-LP033,
      CY8C5266AXI-LP132,
      CY8C5266LTI-LP029,
      CY8C5266LTI-LP150,
      CY8C5267AXI-LP051,
      CY8C5267LTI-LP089,
      CY8C5268AXI-LP047,
      CY8C5268LTI-LP030,
      CY8C5465AXI-LP043,
      CY8C5465LTI-LP104,
      CY8C5466AXI-LP002,
      CY8C5466AXI-LP107,
      CY8C5466LTI-LP072,
      CY8C5466LTI-LP085,
      CY8C5467AXI-LP108,
      CY8C5467LTI-LP003,
      CY8C5468AXI-LP106,
      CY8C5468LTI-LP026,
      CY8C5666AXI-LP001,
      CY8C5666AXI-LP004,
      CY8C5666LTI-LP005,
      CY8C5667AXI-LP006,
      CY8C5667AXI-LP040,
      CY8C5667LTI-LP008,
      CY8C5667LTI-LP009,
      CY8C5667LTI-LP041,
      CY8C5668AXI-LP010,
      CY8C5668AXI-LP013,
      CY8C5668AXI-LP034,
      CY8C5668LTI-LP014,
      CY8C5866AXI-LP020,
      CY8C5866AXI-LP021,
      CY8C5866LTI-LP022,
      CY8C5867AXI-LP023,
      CY8C5867AXI-LP024,
      CY8C5867LTI-LP025,
      CY8C5867LTI-LP028,
      CY8C5868AXI-LP031,
      CY8C5868AXI-LP032,
      CY8C5868AXI-LP035,
      CY8C5868LTI-LP036,
      CY8C5868LTI-LP038, and
      CY8C5868LTI-LP039.
    • Freescale Semiconductor
      MKE02Z16xxx2,
      MKE02Z32xxx2,
      MKE02Z64xxx2,
      MKE04Z8xxx4,
    • Fujitsu Semiconductor
      MB9AF141L,
      MB9AF141M,
      MB9AF141N,
      MB9AF142L,
      MB9AF142M,
      MB9AF142N,
      MB9AF144L,
      MB9AF144M, and
      MB9AF144N.
    • EnergyMicro
      EFM32WG230F128,
      EFM32WG230F256,
      EFM32WG230F64,
      EFM32WG232F128,
      EFM32WG232F256,
      EFM32WG232F64,
      EFM32WG280F128,
      EFM32WG280F256,
      EFM32WG280F64,
      EFM32WG290F128,
      EFM32WG290F256,
      EFM32WG290F64,
      EFM32WG295F128,
      EFM32WG295F256,
      EFM32WG295F64,
      EFM32WG330F128,
      EFM32WG330F256,
      EFM32WG330F64,
      EFM32WG332F128,
      EFM32WG332F256,
      EFM32WG332F64,
      EFM32WG380F128,
      EFM32WG380F256,
      EFM32WG380F64,
      EFM32WG390F128,
      EFM32WG390F256,
      EFM32WG390F64,
      EFM32WG395F128,
      EFM32WG395F256,
      EFM32WG395F64,
      EFM32WG840F128,
      EFM32WG840F256,
      EFM32WG840F64,
      EFM32WG842F128,
      EFM32WG842F256,
      EFM32WG842F64,
      EFM32WG880F128,
      EFM32WG880F256,
      EFM32WG880F64,
      EFM32WG890F128,
      EFM32WG890F256,
      EFM32WG890F64,
      EFM32WG895F128,
      EFM32WG895F256,
      EFM32WG895F64,
      EFM32WG940F128,
      EFM32WG940F256,
      EFM32WG940F64,
      EFM32WG942F128,
      EFM32WG942F256,
      EFM32WG942F64,
      EFM32WG980F128,
      EFM32WG980F256,
      EFM32WG980F64,
      EFM32WG990F128,
      EFM32WG990F256,
      EFM32WG990F64,
      EFM32WG995F128,
      EFM32WG995F256, and
      EFM32WG995F64.
    • Nuvoton
      M0516LBN,
      M0516ZBN,
      M052LBN,
      M052ZBN,
      M054LBN,
      M054ZBN,
      M058LBN,
      M058SLAN,
      M058SSAN,
      M058SZAN,
      M058ZBN,
      MINI51TAN,
      MINI52TAN,
      MINI54TAN,
      NUC123SC2AN1,
      NUC123LC2AN1,
      NUC123ZC2AN1,
      NUC123SD4AN0,
      NUC123LD4AN0,
      NUC123ZD4AN0,
      NUC140VE3CN,
      NUC140RE3CN,
      NUC140RD2CN,
      NUC140RC1CN,
      NUC140LE3CN,
      NUC140LD2CN,
      NUC140LC1CN,
      NUC130VE3CN,
      NUC130RE3CN,
      NUC130RD2CN,
      NUC130RC1CN,
      NUC130LE3CN,
      NUC130LD2CN,
      NUC130LC1CN,
      NUC120RD2BN,
      NUC120RD1BN,
      NUC120RC1BN,
      NUC120LD2BN,
      NUC120LD1BN,
      NUC120LC1BN,
      NUC100RD2BN,
      NUC100RD1BN,
      NUC100RC1BN,
      NUC100LD2BN,
      NUC100LD1BN,
      NUC100LC1BN,
      NUC220VE3AN,
      NUC220SE3AN,
      NUC220LE3AN,
      NUC220SD2AN,
      NUC220LD2AN,
      NUC220SC2AN,
      NUC220LC2AN,
      NUC200VE3AN,
      NUC200SE3AN,
      NUC200LE3AN,
      NUC200SD2AN,
      NUC200LD2AN,
      NUC200SC2AN,
      NUC200LC2AN,
      NANO100KE3BN,
      NANO100SE3BN,
      NANO100KD3BN,
      NANO100SD3BN,
      NANO100LD3BN,
      NANO100KD2BN,
      NANO100SD2BN,
      NANO100LD2BN,
      NANO100KC2BN,
      NANO100LC2BN,
      NANO100LE3BN,
      NANO100SC2BN,
      NANO110KE3BN,
      NANO110SE3BN,
      NANO110KD3BN,
      NANO110SD3BN,
      NANO110KD2BN,
      NANO110SD2BN,
      NANO110KC2BN,
      NANO110SC2BN,
      NANO120KE3BN,
      NANO120SE3BN,
      NANO120LE3BN,
      NANO120KD3BN,
      NANO120SD3BN,
      NANO120LD3BN,
      NANO120KD2BN,
      NANO120SD2BN,
      NANO120LD2BN,
      NANO120KC2BN,
      NANO120SC2BN,
      NANO120LC2BN,
      NANO130KE3BN,
      NANO130SE3BN,
      NANO130KD3BN,
      NANO130SD3BN,
      NANO130KD2BN,
      NANO130SD2BN,
      NANO130KC2BN,
      NANO130SC2BN,
    • NXP (founded by Philips)
      LPC4310 CM0,
      LPC4320 CM0,
      LPC4330 CM0,
      LPC4350 CM0,
      LPC4353 CM0, and
      LPC4357 CM0.
    • STMicroelectronics
      STM32F429BG,
      STM32F429BI,
      STM32F429IG,
      STM32F429II,
      STM32F429NG,
      STM32F429NI,
      STM32F429VG,
      STM32F429VI,
      STM32F429ZG,
      STM32F429ZI,
      STM32F439BG,
      STM32F439BI,
      STM32F439IG,
      STM32F439II,
      STM32F439NG,
      STM32F439NI,
      STM32F439VG,
      STM32F439VI,
      STM32F439ZG, and
      STM32F439ZI.
    • Texas Instruments
      TM4C1290NCPDT,
      TM4C1290NCZAD,
      TM4C1292NCPDT,
      TM4C1292NCZAD,
      TM4C1294NCPDT,
      TM4C1294NCZAD,
      TM4C129CNCPDT,
      TM4C129CNCZAD,
      TM4C129DNCPDT,
      TM4C129DNCZAD,
      TM4C129ENCPDT,
      TM4C129ENCZAD,
      TM4C129XNCZAD,
      TM4E129BNCZAD,
      TM4E129SNCZAD,
      TM4E129XNCZAD,
      TMPM343F10XBG,
      TMPM343FDXBG, and
      TMPM343FEXBG.
[Device Support]
  • [CMSIS support]
      • Atmel
        • Added: suppport for
          Atmel SAMD20
          devices, in folders
          ..\ARM\INC\Atmel\SAMD20\,
          ..\ARM\Startup\Atmel\SAMD20\, and
          ..\ARM\SFD\Atmel\SAMD20\.
          Atmel SAM4N
          devices, in folders
          ..\ARM\INC\Atmel\SAM4N\,
          ..\ARM\Startup\Atmel\SAM4N\, and
          ..\ARM\SFD\Atmel\SAM4N\.
      • EnergyMicro
          EnergyMicro Wonder Gecko
          devices, in folders
          ..\ARM\INC\EnergyMicro\EFM32WG\,
          ..\ARM\Startup\EnergyMicro\EFM32WG\, and..\ARM\SFD\EnergyMicro\EFM32WG\.
          Kinetis KE02
          devices, in folders
          ..\ARM\INC\Freescale\Kinetis\,
          ..\ARM\Startup\Freescale\Kinetis\, and
          ..\ARM\SFD\Freescale\Kinetis\.
          Kinetis KE04
          devices, in folders
          MB9A140N
          devices, in folders
          ..\ARM\INC\Fujitsu\MB9A140N\,
          ..\ARM\Startup\Fujitsu\MB9A140N\, and
          ..\ARM\SFD\Fujitsu\MB9A140N\.
      • Nuvoton
          NUC123Series
          devices, in folders
          ..\ARM\INC\Nuvoton\NUC123Series\,
          ..\ARM\Startup\Nuvoton\NUC123Series\, and..\ARM\SFD\Nuvoton\NUC123Series\.
          NUC200Series
          devices, in folders
          ..\ARM\INC\Nuvoton\NUC200Series\,
          ..\ARM\Startup\Nuvoton\NUC200Series\, and..\ARM\SFD\Nuvoton\NUC200Series\.
          Nano1xx
          devices, in folders
          ..\ARM\INC\Nuvoton\Nano1xx\,
          ..\ARM\Startup\Nuvoton\Nano1xx\, and
          ..\ARM\SFD\Nuvoton\Nano1xx\.
      • SONiX
          SN32F100
          based devices, in folders
          ..\ARM\INC\SONiX\SN32F100\,
          ..\ARM\Startup\SONiX\SN32F100\, and
          ..\ARM\SFD\SONiX\SN32F100\.
          SN32F110
          ..\ARM\INC\SONiX\SN32F110\,
          ..\ARM\Startup\SONiX\SN32F110\, and
          ..\ARM\SFD\SONiX\SN32F110\.
          STM32F4xx
          ..\ARM\INC\ST\STM32F4xx\,
          ..\ARM\Startup\ST\STM32F4xx\, and
          ..\ARM\SFD\ST\STM32F4xx\.
      • Texas Instruments
          TM4C123
          ..\ARM\INC\TI\TM4C123\,
          ..\ARM\Startup\TI\TM4C123\, and
          ..\ARM\SFD\TI\TM4C123\.
          TM4C129
          ..\ARM\INC\TI\TM4C129\,
          ..\ARM\Startup\TI\TM4C129\, and
          ..\ARM\SFD\TI\TM4C129\.
          TM4E129
          ..\ARM\INC\TI\TM4E129 \,
          ..\ARM\Startup\TI\TM4E129\, and
          ..\ARM\SFD\TI\TM4E129\.
  • [Flash programming]
      • Atmel
        • Added:
          ATSAMD20_16.FLM,
          ATSAMD20_32.FLM,
          ATSAMD20_64.FLM,
          ATSAMD20_128.FLM, and
          ATSAMD20_256.FLM
          flash programming algorithms for
          Atmel ATSAM20D
          based devices in folder
          ..\ARM\Falsh\.
        • Added:
          ATSAM4N_512.FLM
          and
          ATSAM4N_1024.FLM
          Atmel ATSAM4N
          ..\ARM\Falsh\.
        • Added:
          MKE02Zxxx_EE256B.FLM, MKE02Zxxx_P16KB.FLM, MKE02Zxxx_P32KB.FLM,
          and
          MKE02Zxxx_P64KB.FLM
          Kinetis KE02
          ..\ARM\Flash\.
        • Added:
          MKE04Zxxx_P8KB.FLM
          Kinetis KE04
          ..\ARM\Flash\.
      • Nuvoton
        • Added:
          NUC2xx_CFG.FLM, NUC2xx_AP_128.FLM, NUC2xx_AP_64.FLM, NUC2xx_AP_32.FLM, NUC2xx_LD_4.FLM, and NUC2xx_DAT.FLM
          flash programming algorithms forNUC200Series
          devices in folder
          ..\ARM\Flash\.
        • Added:
          Nano100_CFG.FLM, Nano100_AP_123.FLM, Nano100_DAT.FLM, Nano100_AP_64.FLM, Nano100_LD_4.FLM, and Nano100_AP_32.FLM
          Nano1xx
          ..\ARM\Flash\.
      • SONiX
        • Added:
          SN32F100_64.FLM
          and
          SN32F110_64.FLM
          SN32F100
          and
          SN32F110
          ..\ARM\Flash\.
[Board Support]
  • Atmel
    • Added: Blinky and RTX_Blinky examples for
      SAMD20-XPRO
      board, based on
      SAMD20J18
      device.
  • SONiX
    • Added: Hello example for
      SN32F100_Starter_Kit
      board, based on
      SN32F109
      device.
      STM324x9I-EVAL
      evaluation board, based on
      STM32F439NI
      device.
    • Added: Blinky, RTX_Blinky, and Blinky_ULp for
      STM32437I-EVAL
      STM32F437II
      device.
[Target debugging]
  • Updated: support for
    NULink
    debugger from
    Nuvoton. The
    Nu_Link.dll
    driver dll in folder
    ..\ARM\NULInk\
    has been updated to version
    1.2.1.0.
  • Updated: debug driver lmidk-agdi.dll for TI Stellaris In-Ciruit debug interface to version 211.0.0.0 in folder
    ..\ARM\BIN\.
Microcontroller Development Kit - Version 4.71a
  • [uVision Debugger]
    • Corrected: Missing
      RTX views
      for
      Cortex-M
      targets.
  • [New Supported Devices]
    • SONiX
      SN32F107,
      SN32F108,
      SN32F109,
      SN32F117,
      SN32F118, and
      SN32F119.
发表于 2014-5-27 14:26:32 | 显示全部楼层
东西是好,能否打成一个包?
发表于 2015-6-2 16:47:49 | 显示全部楼层
看看 看看
发表于 2015-9-10 12:06:19 | 显示全部楼层
xie xie...
GMT+8, 2025-11-3 05:06 , Processed in 0.023833 second(s), 4 queries , Gzip On, Redis On.
