Hi all,
Here is a nice collection of Interview questions with reponses:
CMOS interview questions.
1/ What is latch up?
Latch-up pertains to a failure mechanism wherein a parasitic thyristor(such as a parasitic silicon controlled rectifier, or SCR) isinadvertently created within a circuit, causing a high amount ofcurrent to continuously flow through it once it is accidentallytriggered or turned on. Depending on the circuits involved, the amountof current flow produced by this mechanism can be large enough toresult in permanent destruction of the device due to electricaloverstress (EOS)
2)Why is NAND gate preferred over NOR gate for fabrication?
NAND is a better gate for design than NOR because at the transistorlevel the mobility of electrons is normally three times that of holescompared to NOR and thus the NAND is a faster gate.
Additionally, the gate-leakage in NAND structures is much lower.If you consider t_phl and t_plh delays you will find that it is moresymmetric in case of NAND ( the delay profile), but for NOR, one delayis much higher than the other(obviously t_plh is higher since thehigher resistance p mos's are in series connection which againincreases the resistance).
3)What is Noise Margin? Explain the procedure to determine Noise Margin
The minimum amount of noise that can be allowed on the input stage for which the output will not be effected.
4)Explain sizing of the inverter?
In order to drive the desired load capacitance we have to increasethe size (width) of the inverters to get an optimized performance.
5) How do you size NMOS and PMOS transistors to increase the threshold voltage?
6) What is Noise Margin? Explain the procedure to determine Noise Margin?
7) What happens to delay if you increase load capacitance?
delay increases.
8)What happens to delay if we include a resistance at the output of a CMOS circuit?
Increases. (RC delay)
9)What are the limitations in increasing the power supply to reduce delay?
The delay can be reduced by increasing the power supply but if wedo so the heating effect comes because of excessive power, tocompensate this we have to increase the die size which is notpractical.
10)How does Resistance of the metal lines vary with increasing thickness and increasing length?
R = ( *l) / A.
11)For CMOS logic, give the various techniques you know to minimize power consumption?
Power dissipation=CV2f ,from this minimize the load capacitance, dc voltage and the operating frequency.
12) What is Charge Sharing? Explain the Charge Sharing problem while sampling data from a Bus?
In the serially connected NMOS logic the input capacitance of eachgate shares the charge with the load capacitance by which the logicallevels drastically mismatched than that of the desired once. Toeliminate this load capacitance must be very high compared to the inputcapacitance of the gates (approximately 10 times).
13)Why do we gradually increase the size of inverters in bufferdesign? Why not give the output of a circuit to one large inverter?
Because it can not drive the output load straight away, so we gradually increase the size to get an optimized performance.
14)What is Latch Up? Explain Latch Up with cross section of a CMOS Inverter. How do you avoid Latch Up?
Latch-up is a condition in which the parasitic components give riseto the Establishment of low resistance conducting path between VDD andVSS with Disastrous results.
15) Give the expression for CMOS switching power dissipation?
CV2
16) What is Body Effect?
In general multiple MOS devices are made on a common substrate. Asa result, the substrate voltage of all devices is normally equal.However while connecting the devices serially this may result in anincrease in source-to-substrate voltage as we proceed vertically alongthe series chain (Vsb1=0, Vsb2 0).Which results Vth2>Vth1.
17) Why is the substrate in NMOS connected to Ground and in PMOS to VDD?
we try to reverse bias not the channel and the substrate but we tryto maintain the drain,source junctions reverse biased with respect tothe substrate so that we dont loose our current into the substrate.
18) What is the fundamental difference between a MOSFET and BJT ?
In MOSFET, current flow is either due to electrons(n-channel MOS)or due to holes(p-channel MOS) - In BJT, we see current due to both thecarriers.. electrons and holes. BJT is a current controlled device andMOSFET is a voltage controlled device.
19)Which transistor has higher gain. BJT or MOS and why?
BJT has higher gain because it has higher transconductance.This isbecause the current in BJT is exponentially dependent on input where asin MOSFET it is square law.
20)Why do we gradually increase the size of inverters in bufferdesign when trying to drive a high capacitive load? Why not give theoutput of a circuit to one large inverter?
We cannot use a big inverter to drive a large output capacitancebecause, who will drive the big inverter? The signal that has to drivethe output cap will now see a larger gate capacitance of the BIGinverter.So this results in slow raise or fall times .A unit invertercan drive approximately an inverter thats 4 times bigger in size. Sosay we need to drive a cap of 64 unit inverter then we try to keep thesizing like say 1,4,16,64 so that each inverter sees a same ratio ofoutput to input cap. This is the prime reason behind going forprogressive sizing.
21)In CMOS technology, in digital design, why do we design the sizeof pmos to be higher than the nmos.What determines the size of pmos wrtnmos. Though this is a simple question try to list all the reasonspossible?
In PMOS the carriers are holes whose mobility is less[ aprrox half] than the electrons, the carriers in NMOS. That means PMOS is slowerthan an NMOS. In CMOS technology, nmos helps in pulling down the outputto ground ann PMOS helps in pulling up the output to Vdd. If the sizesof PMOS and NMOS are the same, then PMOS takes long time to charge upthe output node. If we have a larger PMOS than there will be morecarriers to charge the node quickly and overcome the slow nature ofPMOS . Basically we do all this to get equal rise and fall times forthe output node.
22)Why PMOS and NMOS are sized equally in a Transmission Gates?
In Transmission Gate, PMOS and NMOS aid each other rather competingwith each other. That's the reason why we need not size them like inCMOS. In CMOS design we have NMOS and PMOS competing which is thereason we try to size them proportional to their mobility.
23)All of us know how an inverter works. What happens when the PMOS and NMOS are interchanged with one another in an inverter?
I have seen similar Qs in some of the discussions. If the source& drain also connected properly...it acts as a buffer. But supposeinput is logic 1 O/P will be degraded 1 Similarly degraded 0;
24)A good question on layouts. Give 5 important Design techniques you would follow when doing a Layout for Digital Circuits?
a)In digital design, decide the height of standard cells you wantto layout.It depends upon how big your transistors will be.Havereasonable width for VDD and GND metal paths.Maintaining uniform Heightfor all the cell is very important since this will help you use placeroute tool easily and also incase you want to do manual connection ofall the blocks it saves on lot of area.
b)Use one metal in one direction only, This does not apply formetal 1. Say you are using metal 2 to do horizontal connections, thenuse metal 3 for vertical connections, metal4 for horizontal, metal 5vertical etc...
c)Place as many substrate contact as possible in the empty spaces of the layout.
d)Do not use poly over long distances as it has huge resistances unless you have no other choice.
e)Use fingered transistors as and when you feel necessary.
f)Try maintaining symmetry in your design. Try to get the design in BIT Sliced manner.
25)What is metastability? When/why it will occur?Different ways to avoid this?
Metastable state: A un-known state in between the two logical knownstates.This will happen if the O/P cap is not allowed tocharge/discharge fully to the required logical levels.
One of the cases is: If there is a setup time violation,metastability will occur,To avoid this, a series of FFs is used(normally 2 or 3) which will remove the intermediate states.
26)Let A and B be two inputs of the NAND gate. Say signal A arrivesat the NAND gate later than signal B. To optimize delay of the twoseries NMOS inputs A and B which one would you place near to theoutput?
The late coming signals are to be placed closer to the output node ie A should go to the nmos that is closer to the output.
Digital design interview questions & answers.
1) Explain about setup time and hold time, what will happen ifthere is setup time and hold tine violation, how to overcome this?
Set up time is the amount of time before the clock edge that theinput signal needs to be stable to guarantee it is accepted properly onthe clock edge.
Hold time is the amount of time after the clock edge that sameinput signal has to be held before changing it to make sure it issensed properly at the clock edge.
Whenever there are setup and hold time violations in anyflip-flop, it enters a state where its output is unpredictable: thisstate is known as metastable state (quasi stable state); at the end ofmetastable state, the flip-flop settles down to either '1' or '0'. Thiswhole process is known as metastability
2) What is skew, what are problems associated with it and how to minimize it?
In circuit design, clock skew is a phenomenon in synchronouscircuits in which the clock signal (sent from the clock circuit)arrives at different components at different times.
This is typically due to two causes. The first is a material flaw,which causes a signal to travel faster or slower than expected. Thesecond is distance: if the signal has to travel the entire length of acircuit, it will likely (depending on the circuit's size) arrive atdifferent parts of the circuit at different times. Clock skew can causeharm in two ways. Suppose that a logic path travels throughcombinational logic from a source flip-flop to a destination flip-flop.If the destination flip-flop receives the clock tick later than thesource flip-flop, and if the logic path delay is short enough, then thedata signal might arrive at the destination flip-flop before the clocktick, destroying there the previous data that should have been clockedthrough. This is called a hold violation because the previous data isnot held long enough at the destination flip-flop to be properlyclocked through. If the destination flip-flop receives the clock tickearlier than the source flip-flop, then the data signal has that muchless time to reach the destination flip-flop before the next clocktick. If it fails to do so, a setup violation occurs, so-called becausethe new data was not set up and stable before the next clock tickarrived. A hold violation is more serious than a setup violationbecause it cannot be fixed by increasing the clock period.
Clock skew, if done right, can also benefit a circuit. It can beintentionally introduced to decrease the clock period at which thecircuit will operate correctly, and/or to increase the setup or holdsafety margins. The optimal set of clock delays is determined by alinear program, in which a setup and a hold constraint appears for eachlogic path. In this linear program, zero clock skew is merely afeasible point.
Clock skew can be minimized by proper routing of clock signal(clock distribution tree) or putting variable delay buffer so that allclock inputs arrive at the same time
3) What is slack?
'Slack' is the amount of time you have that is measured from whenan event 'actually happens' and when it 'must happen'.. The term'actually happens' can also be taken as being a predicted time for whenthe event will 'actually happen'.
When something 'must happen' can also be called a 'deadline' soanother definition of slack would be the time from when something'actually happens' (call this Tact) until the deadline (call thisTdead).
Slack = Tdead - Tact.
Negative slack implies that the 'actually happen' time is laterthan the 'deadline' time...in other words it's too late and a timingviolation....you have a timing problem that needs some attention.
4) What is glitch? What causes it (explain with waveform)? How to overcome it?
The following figure shows a synchronous alternative to the gatedclock using a data path. The flip-flop is clocked at every clock cycleand the data path is controlled by an enable. When the enable is Low,the multiplexer feeds the output of the register back on itself. Whenthe enable is High, new data is fed to the flip-flop and the registerchanges its state
5) Given only two xor gates one must function as buffer and another as inverter?
Tie one of xor gates input to 1 it will act as inverter.
Tie one of xor gates input to 0 it will act as buffer.
6) What is difference between latch and flipflop?
The main difference between latch and FF is that latches are levelsensitive while FF are edge sensitive. They both require the use ofclock signal and are used in sequential logic. For a latch, the outputtracks the input when the clock signal is high, so as long as the clockis logic 1, the output can change if the input also changes. FF on theother hand, will store the input only when there is a rising/fallingedge of the clock.
7) Build a 4:1 mux using only 2:1 mux?
Difference between heap and stack?
The Stack is more or less responsible for keeping track of what'sexecuting in our code (or what's been "called"). The Heap is more orless responsible for keeping track of our objects (our data, well...most of it - we'll get to that later.).
Think of the Stack as a series of boxes stacked one on top of thenext. We keep track of what's going on in our application by stackinganother box on top every time we call a method (called a Frame). We canonly use what's in the top box on the stack. When we're done with thetop box (the method is done executing) we throw it away and proceed touse the stuff in the previous box on the top of the stack. The Heap issimilar except that its purpose is to hold information (not keep trackof execution most of the time) so anything in our Heap can be accessedat any time. With the Heap, there are no constraints as to what can beaccessed like in the stack. The Heap is like the heap of clean laundryon our bed that we have not taken the time to put away yet - we cangrab what we need quickly. The Stack is like the stack of shoe boxes inthe closet where we have to take off the top one to get to the oneunderneath it.
9) Difference between mealy and moore state machine?
A) Mealy and Moore models are the basic models of state machines. Astate machine which uses only Entry Actions, so that its output dependson the state, is called a Moore model. A state machine which uses onlyInput Actions, so that the output depends on the state and also oninputs, is called a Mealy model. The models selected will influence adesign but there are no general indications as to which model isbetter. Choice of a model depends on the application, execution means(for instance, hardware systems are usually best realized as Mooremodels) and personal preferences of a designer or programmer
B) Mealy machine has outputs that depend on the state and input (thus, the FSM has the output written on edges)
Moore machine has outputs that depend on state only (thus, the FSM has the output written in the state itself.
Adv and Disadv
In Mealy as the output variable is a function both input and state,changes of state of the state variables will be delayed with respect tochanges of signal level in the input variables, there are possibilitiesof glitches appearing in the output variables. Moore overcomes glitchesas output dependent on only states and not the input signal level.
All of the concepts can be applied to Moore-model state machinesbecause any Moore state machine can be implemented as a Mealy statemachine, although the converse is not true.
Moore machine: the outputs are properties of states themselves...which means that you get the output after the machine reaches aparticular state, or to get some output your machine has to be taken toa state which provides you the output.The outputs are held until you goto some other state Mealy machine:
Mealy machines give you outputs instantly, that is immediatelyupon receiving input, but the output is not held after that clockcycle.
10) Difference between onehot and binary encoding?
Common classifications used to describe the state encoding of an FSM are Binary (or highly encoded) and One hot.
A binary-encoded FSM design only requires as many flip-flops as areneeded to uniquely encode the number of states in the state machine.The actual number of flip-flops required is equal to the ceiling of thelog-base-2 of the number of states in the FSM.
A onehot FSM design requires a flip-flop for each state in thedesign and only one flip-flop (the flip-flop representing the currentor "hot" state) is set at a time in a one hot FSM design. For a statemachine with 9- 16 states, a binary FSM only requires 4 flip-flopswhile a onehot FSM requires a flip-flop for each state in the design
FPGA vendors frequently recommend using a onehot state encodingstyle because flip-flops are plentiful in an FPGA and the combinationallogic required to implement a onehot FSM design is typically smallerthan most binary encoding styles. Since FPGA performance is typicallyrelated to the combinational logic size of the FPGA design, onehot FSMstypically run faster than a binary encoded FSM with largercombinational logic blocks
11) What are different ways to synchronize between two clock domains?
12) How to calculate maximum operating frequency?
13) How to find out longest path?
You can find answer to this in timing.ppt of presentations section on this site
14) Draw the state diagram to output a "1" for one cycle if thesequence "0110" shows up (the leading 0s cannot be used in more thanone sequence)?
15)How to achieve 180 deree exact phase shift?
Never tell using inverter
a) dcm's an inbuilt resource in most of fpga can be configured to get 180 degree phase shift.
b) Bufgds that is differential signaling buffers which are also inbuilt resource of most of FPGA can be used.
16) What is significance of ras and cas in SDRAM?
SDRAM receives its address command in two address words.
It uses a multiplex scheme to save input pins. The first addressword is latched into the DRAM chip with the row address strobe (RAS).
Following the RAS command is the column address strobe (CAS) for latching the second address word.
Shortly after the RAS and CAS strobes, the stored data is valid for reading.
17) Tell some of applications of buffer?
a)They are used to introduce small delays
b)They are used to eliminate cross talk caused due to inter electrode capacitance due to close routing.
c)They are used to support high fanout,eg:bufg
1 Implement an AND gate using mux?
This is the basic question that many interviewers ask. for andgate, give one input as select line,incase if u r giving b as selectline, connect one input to logic '0' and other input to a.
19) What will happen if contents of register are shifter left, right?
It is well known that in left shift all bits will be shifted leftand LSB will be appended with 0 and in right shift all bits will beshifted right and MSB will be appended with 0 this is a straightforwardanswer
What is expected is in a left shift value gets Multiplied by 2eg:consider 0000_1110=14 a left shift will make it 0001_110=28, it thesame fashion right shift will Divide the value by 2.
20)Given the following fifo and rules, how deep does the FIFO need to be to prevent underflow or overflow?
RULES:
1) frequency(clk_A) = frequency(clk_B) / 4
2) period(en_B) = period(clk_A) * 100
3) duty_cycle(en_B) = 25%
Assume clk_B = 100MHz (10ns)
From (1), clk_A = 25MHz (40ns)
From (2), period(en_B) = 40ns * 400 = 4000ns, but we only output for
1000ns,due to (3), so 3000ns of the enable we are doing no output work. Therefore, FIFO size = 3000ns/40ns = 75 entries
21) Design a four-input NAND gate using only two-input NAND gates.
A:Basically, you can tie the inputs of a NAND gate together to get an inverter, so...
22)Difference between Synchronous and Asynchronous reset.?
Synchronous reset logic will synthesize to smaller flip-flops,particularly if the reset is gated with the logic generating thed-input. But in such a case, the combinational logic gate count grows,so the overall gate count savings may not be that significant.
The clock works as a filter for small reset glitches; however, ifthese glitches occur near the active clock edge, the Flip-flop could gometastable. In some designs, the reset must be generated by a set ofinternal conditions. A synchronous reset is recommended for these typesof designs because it will filter the logic equation glitches betweenclock.
Disadvantages of synchronous reset:
Problem with synchronous resets is that the synthesis tool cannoteasily distinguish the reset signal from any other data signal.
Synchronous resets may need a pulse stretcher to guarantee a resetpulse width wide enough to ensure reset is present during an activeedge of the clock[ if you have a gated clock to save power, the clockmay be disabled coincident with the assertion of reset. Only anasynchronous reset will work in this situation, as the reset might beremoved prior to the resumption of the clock.
Designs that are pushing the limit for data path timing, can notafford to have added gates and additional net delays in the data pathdue to logic inserted to handle synchronous resets.
Asynchronous reset :
The biggest problem with asynchronous resets is the reset release,also called reset removal. Using an asynchronous reset, the designer isguaranteed not to have the reset added to the data path. Anotheradvantage favoring asynchronous resets is that the circuit can be resetwith or without a clock present.
Disadvantages of asynchronous reset: ensure that the release ofthe reset can occur within one clock period. if the release of thereset occurred on or near a clock edge such that the flip-flops wentmetastable.
23) Why are most interrupts active low?
This answers why most signals are active low
If you consider the transistor level of a module, active low meansthe capacitor in the output terminal gets charged or discharged basedon low to high and high to low transition respectively. when it goesfrom high to low it depends on the pull down resistor that pulls itdown and it is relatively easy for the output capacitance to dischargerather than charging. hence people prefer using active low signals.
24)Give two ways of converting a two input NAND gate to an inverter?
(a) short the 2 inputs of the nand gate and apply the single input to it.
(b) Connect the output to one of the input and the other to the input signal.
25) What are set up time & hold time constraints? What do theysignify? Which one is critical for estimating maximum clock frequencyof a circuit?
set up time: - the amount of time the data should be stable beforethe application of the clock signal, where as the hold time is theamount of time the data should be stable after the application of theclock. Setup time signifies maximum delay constraints; hold time is forminimum delay constraints. Setup time is critical for establishing themaximum clock frequency.
26) Differences between D-Latch and D flip-flop?
D-latch is level sensitive where as flip-flop is edge sensitive. Flip-flops are made up of latches.
27) What is a multiplexer?
Is combinational circuit that selects binary information from oneof many input lines and directs it to a single output line. (2n=>n).
28)How can you convert an SR Flip-flop to a JK Flip-flop?
By giving the feed back we can convert, i.e !Q=>S and Q=>R.Hence the S and R inputs will act as J and K respectively.
29)How can you convert the JK Flip-flop to a D Flip-flop?
By connecting the J input to the K through the inverter.
30)What is Race-around problem?How can you rectify it?
The clock pulse that remains in the 1 state while both J and K areequal to 1 will cause the output to complement again and repeatcomplementing until the pulse goes back to 0, this is called the racearound problem.To avoid this undesirable operation, the clock pulsemust have a time duration that is shorter than the propagation delaytime of the F-F, this is restrictive so the alternative is master-slaveor edge-triggered construction.
31)How do you detect if two 8-bit signals are same?
XOR each bits of A with B (for e.g. A[0] xor B[0] ) and so on.theo/p of 8 xor gates are then given as i/p to an 8-i/p nor gate. if o/pis 1 then A=B.
32)7 bit ring counter's initial state is 0100010. After how many clock cycles will it return to the initial state?
6 cycles
33) Convert D-FF into divide by 2. (not latch) What is the maxclock frequency the circuit can handle, given the followinginformation?
T_setup= 6nS T_hold = 2nS T_propagation = 10nS
Circuit: Connect Qbar to D and apply the clk at clk of DFF and takethe O/P at Q. It gives freq/2. Max. Freq of operation: 1/ (propagationdelay+setup time) = 1/16ns = 62.5 MHz
34)Guys this is the basic question asked most frequently. Designall the basic gates(NOT,AND,OR,NAND,NOR,XOR,XNOR) using 2:1Multiplexer?
Using 2:1 Mux, (2 inputs, 1 output and a select line)
(a) NOT
Give the input at the select line and connect I0 to 1 & I1 to 0. So if A is 1, we will get I1 that is 0 at the O/P.
(b) AND
Give input A at the select line and 0 to I0 and B to I1. O/p is A & B
(c) OR
Give input A at the select line and 1 to I1 and B to I0. O/p will be A | B
(d) NAND
AND + NOT implementations together
(e) NOR
OR + NOT implementations together
(f) XOR
A at the select line B at I0 and ~B at I1. ~B can be obtained from (a) (g) XNOR
A at the select line B at I1 and ~B at I0
35)N number of XNOR gates are connected in series such that the Ninputs (A0,A1,A2......) are given in the following way: A0 & A1 tofirst XNOR gate and A2 & O/P of First XNOR to second XNOR gate andso on..... Nth XNOR gates output is final output. How does this circuitwork? Explain in detail?
If N=Odd, the circuit acts as even parity detector, ie the outputwill 1 if there are even number of 1's in the N input...This could alsobe called as odd parity generator since with this additional 1 asoutput the total number of 1's will be ODD.
If N=Even, just the opposite, it will be Odd parity detector or Even Parity Generator.
36)An assembly line has 3 fail safe sensors and one emergencyshutdown switch.The line should keep moving unless any of the followingconditions arise:
(i) If the emergency switch is pressed
(ii) If the senor1 and sensor2 are activated at the same time.
(iii) If sensor 2 and sensor3 are activated at the same time.
(iv) If all the sensors are activated at the same time
Suppose a combinational circuit for above case is to be implementedonly with NAND Gates. How many minimum number of 2 input NAND gates arerequired?
No of 2-input NAND Gates required = 6 You can try the whole implementation.
37)Design a circuit that calculates the square of a number? Itshould not use any multiplier circuits. It should use Multiplexers andother logic?
This is interesting....
1^2=0+1=1
2^2=1+3=4
3^2=4+5=9
4^2=9+7=16
5^2=16+9=25
and so on
See a pattern yet?To get the next square, all you have to do is addthe next odd number to the previous square that you found.See how1,3,5,7 and finally 9 are added.Wouldn't this be a possible solution toyour question since it only will use a counter,multiplexer and a coupleof adders?It seems it would take n clock cycles to calculate square ofn.
3 How will you implement a Full subtractor from a Full adder?
all the bits of subtrahend should be connected to the xor gate.Other input to the xor being one.The input carry bit to the full addershould be made 1. Then the full adder works like a full subtractor
39)A very good interview question... What is difference betweensetup and hold time. The interviewer was looking for one specificreason , and its really a good answer too..The hint is hold timedoesn't depend on clock, why is it so...?
Setup violations are related to two edges of clock, i mean you canvary the clock frequency to correct setup violation. But for hold time,you are only concerned with one edge and does not basically depend onclock frequency.
40)In a 3-bit Johnson's counter what are the unused states?
2(power n)-2n is the one used to find the unused states in johnson counter.
So for a 3-bit counter it is 8-6=2.Unused states=2. the two unused states are 010 and 101
41)The question is to design minimal hardware system, whichencrypts 8-bit parallel data. A synchronized clock is provided to thissystem as well. The output encrypted data should be at the same rate asthe input data but no necessarily with the same phase.
The encryption system is centered around a memory device thatperform a LUT (Look-Up Table) conversion. This memory functionality canbe achieved by using a PROM, EPROM, FLASH and etc. The device containsan encryption code, which may be burned into the device with anexternal programmer. In encryption operation, the data_in is an addresspointer into a memory cell and the combinatorial logic generates thecontrol signals. This creates a read access from the memory. Then thememory device goes to the appropriate address and outputs the associatedata. This data represent the data_in after encryption. 41) What is anLFSR .List a few of its industry applications.?
LFSR is a linear feedback shift register where the input bit isdriven by a linear function of the overall shift register value. comingto industrial applications, as far as I know, it is used for encryptionand decryption and in BIST(built-in-self-test) based applications..
42)what is false path?how it determine in ckt? what the effect of false path in ckt?
By timing all the paths in the circuit the timing analyzer candetermine all the critical paths in the circuit. However, the circuitmay have false paths, which are the paths in the circuit which arenever exercised during normal circuit operation for any set of inputs.
An example of a false path is shown in figure below. The pathgoing from the input A of the first MUX through the combinational logicout through the B input of the second MUS is a false path. This pathcan never be activated since if the A input of the first MUX isactivated, then Sel line will also select the A input of the secondMUX.
STA (Static Timing Analysis) tools are able to identify simplefalse paths; however they are not able to identify all the false pathsand sometimes report false paths as critical paths. Removal of falsepaths makes circuit testable and its timing performance predictable(sometimes faster)
43)Consider two similar processors, one with a clock skew of 100psand other with a clock skew of 50ps. Which one is likely to have morepower? Why?
Clock skew of 50ps is more likely to have clock power. This isbecause it is likely that low-skew processor has better designed clocktree with more powerful and number of buffers and overheads to makeskew better.
44)What are multi-cycle paths?
Multi-cycle paths are paths between registers that take more than one clock cycle to become stable.
For ex. Analyzing the design shown in fig below shows that theoutput SIN/COS requires 4 clock-cycles after the input ANGLE is latchedin. This means that the combinatorial block (the Unrolled Cordic) cantake up to 4 clock periods (25MHz) to propagate its result. Place andRoute tools are capable of fixing multi-cycle paths problem.
45)You have two counters counting upto 16, built from negedge DFF ,First circuit is synchronous and second is "ripple" (cascading), Whichcircuit has a less propagation delay? Why?
The synchronous counter will have lesser delay as the input toeach flop is readily available before the clock edge. Whereas thecascade counter will take long time as the output of one flop is usedas clock to the other. So the delay will be propagating. For Eg: 16state counter = 4 bit counter = 4 Flip flops Let 10ns be the delay ofeach flop The worst case delay of ripple counter = 10 * 4 = 40ns Thedelay of synchronous counter = 10ns only.(Delay of 1 flop)
46) what is difference between RAM and FIFO?
FIFO does not have address lines
Ram is used for storage purpose where as fifo is used forsynchronization purpose i.e. when two peripherals are working indifferent clock domains then we will go for fifo.
47)The circle can rotate clockwise and back. Use minimum hardware to build a circuit to indicate the direction of rotating.?
2 sensors are required to find out the direction of rotating. Theyare placed like at the drawing. One of them is connected to the datainput of D flip-flop,and a second one - to the clock input. If thecircle rotates the way clock sensor sees the light first while D input(second sensor) is zero - the output of the flip-flop equals zero, andif D input sensor "fires" first - the output of the flip-flop becomeshigh.
4 Draw timing diagrams for following circuit.?
49)Implement the following circuits:
(a) 3 input NAND gate using min no of 2 input NAND Gates
(b) 3 input NOR gate using min no of 2 inpur NOR Gates
(c) 3 input XNOR gate using min no of 2 inpur XNOR Gates
Assuming 3 inputs A,B,C?
3 input NAND:
Connect :
a) A and B to the first NAND gate
b) Output of first Nand gate is given to the two inputs of thesecond NAND gate (this basically realizes the inverter functionality)
c) Output of second NAND gate is given to the input of the third NAND gate, whose other input is C
((A NAND B) NAND (A NAND B)) NAND C Thus, can be implemented using'3' 2-input NAND gates. I guess this is the minimum number of gatesthat need to be used.
3 input NOR:
Same as above just interchange NAND with NOR ((A NOR B) NOR (A NOR B)) NOR C
3 input XNOR:
Same as above except the inputs for the second XNOR gate, Output ofthe first XNOR gate is one of the inputs and connect the second inputto ground or logical '0'
((A XNOR B) XNOR 0)) XNOR C
50) Is it possible to reduce clock skew to zero? Explain your answer ?
Even though there are clock layout strategies (H-tree) that can intheory reduce clock skew to zero by having the same path length fromeach flip-flop from the pll,process variations in R and C across the chip will cause clock skew aswell as a pure H-Tree scheme is not practical (consumes too much area).
51)Design a FSM (Finite State Machine) to detect a sequence 10110?
52)Convert D-FF into divide by 2. (not latch)? What is the max clock frequency of the circuit , given the following information?
T_setup= 6nS
T_hold = 2nS
Circuit:
Connect Qbar to D and apply the clk at clk of DFF and take the O/P at Q. It gives freq/2.
1/ (propagation delay+setup time) = 1/16ns = 62.5 MHz
53)Give the circuit to extend the falling edge of the input by 2 clock pulses?The waveforms are shown in the following figure.
54) For the Circuit Shown below, What is the Maximum Frequency ofOperation?Are there any hold time violations for FF2? If yes, how doyou modify the circuit to avoid them?
The minumum time period = 3+2+(1+1+1) = 8ns Maximum Frequency = 1/8n= 125MHz.
And there is a hold time violation in the circuit,because offeedback, if you observe, tcq2+AND gate delay is less than thold2,Toavoid this we need to use even number of inverters(buffers). Here weneed to use 2 inverters each with a delay of 1ns. then the hold timevalue exactly meets.
55)Design a D-latch using (a) using 2:1 Mux (b) from S-R Latch ?
56)How to implement a Master Slave flip flop using a 2 to 1 mux?
57)how many 2 input xor's are needed to inplement 16 input parity generator ?
It is always n-1 Where n is number of inputs.So 16 input parity generator will require 15 two input xor's .
58)Design a circuit for finding the 9's compliment of a BCD number using 4-bit binary adder and some external logic gates?
9's compliment is nothing but subracting the given no from 9.Sousing a 4 bit binary adder we can just subract the given binary no from1001(i.e. 9).Here we can use the 2's compliment method addition.
59) what is Difference between writeback and write through cache?
A caching method in which modifications to data in the cache aren'tcopied to the cache source until absolutely necessary. Write-backcaching is available on many microprocessors , including all Intelprocessors since the 80486. With these microprocessors, datamodifications to data stored in the L1 cache aren't copied to mainmemory until absolutely necessary. In contrast, a write-through cacheperforms all write operations in parallel -- data is written to mainmemory and the L1 cache simultaneously. Write-back caching yieldssomewhat better performance than write-through caching because itreduces the number of write operations to main memory. With thisperformance improvement comes a slight risk that data may be lost ifthe system crashes.
A write-back cache is also called a copy-back cache.
60)Difference between Synchronous,Asynchronous & Isynchronous communication?
Sending data encoded into your signal requires that the sender andreceiver are both using the same enconding/decoding method, and knowwhere to look in the signal to find data. Asynchronous systems do notsend separate information to indicate the encoding or clockinginformation. The receiver must decide the clocking of the signal onit's own. This means that the receiver must decide where to look in thesignal stream to find ones and zeroes, and decide for itself where eachindividual bit stops and starts. This information is not in the data inthe signal sent from transmitting unit.
Synchronous systems negotiate the connection at the data-linklevel before communication begins. Basic synchronous systems willsynchronize two clocks before transmission, and reset their numericcounters for errors etc. More advanced systems may negotiate thingslike error correction and compression.
Time-dependent. it refers to processes where data must bedelivered within certain time constraints. For example, Multimediastream require an isochronous transport mechanism to ensure that datais delivered as fast as it is displayed and to ensure that the audio issynchronized with the video.
61) What are different ways Multiply & Divide?
Set quotient to zero
Repeat while dividend is greater than or equal to divisor
Subtract divisor from dividend
Add 1 to quotient
End of repeat block
quotient is correct, dividend is remainder
STOP
Binary Division by Shift and Subtract
Basically the reverse of the mutliply by shift and add.
Set quotient to 0
Align leftmost digits in dividend and divisor
Repeat
If that portion of the dividend above the divisor is greater than or equal to the divisor
Then subtract divisor from that portion of the dividend and
Concatentate 1 to the right hand end of the quotient
Else concatentate 0 to the right hand end of the quotient
Shift the divisor one place right
Until dividend is less than the divisor
STOP
Binary Multiply - Repeated Shift and Add
Repeated shift and add - starting with a result of 0, shift thesecond multiplicand to correspond with each 1 in the first multiplicandand add to the result. Shifting each position left is equivalent tomultiplying by 2, just as in decimal representation a shift left isequivalent to multiplying by 10.
Set result to 0
Repeat
Shift 2nd multiplicand left until rightmost digit is lined up with leftmost 1 in first multiplicand
Add 2nd multiplicand in that position to result
Remove that 1 from 1st multiplicand
Until 1st multiplicand is zero
Result is correct
STOP
62)What is a SoC (System On Chip), ASIC, "full custom chip", and an FPGA?
There are no precise definitions. Here is my sense of it all.First, 15 years ago, people were unclear on exactly what VLSI meant.Was it 50000 gates? 100000 gates? was is just anything bigger than LSI?My professor simply told me that; VLSI is a level of complexity andintegration in a chip that demands Electronic Design Automation toolsin order to succeed. In other words, big enough that manually drawinglots of little blue, red and green lines is too much for a human toreasonably do. I think that, likewise, SoC is that level of integrationonto a chip that demands more expertise beyond traditional skills ofelectronics. In other words, pulling off a SoC demands Hardware,Software, and Systems Engineering talent. So, trivially, SoCsaggressively combine HW/SW on a single chip. Maybe more pragmatically,SoC just means that ASIC and Software folks are learning a little bitmore about each other's techniques and tools than they did before. Twoother interpretations of SoC are 1) a chip that integrates various IP(Intellectual Property) blocks on it and is thus highly centered withissues like Reuse, and 2) a chip integrating multiple classes ofelectronic circuitry such as Digital CMOS, mixed-signal digital andAnalog (e.g. sensors, modulators, A/Ds), DRAM memory, high voltagepower, etc.
ASIC stands for "Application Specific Integrated Circuit". A chipdesigned for a specific application. Usually, I think people associateASICs with the Standard Cell design methodology. Standard Cell designand the typical "ASIC flow" usually means that designers are usingHardware Description Languages, Synthesis and a library of primitivecells (e.g. libraries containing AND, NAND, OR, NOR, NOT, FLIP-FLOP,LATCH, ADDER, BUFFER, PAD cells that are wired together (real librariesare not this simple, but you get the idea..). Design usually is NOTdone at a transistor level. There is a high reliance on automated toolsbecause the assumption is that the chip is being made for a SPECIFICAPPLICATION where time is of the essence. But, the chip is manufacturedfrom scratch in that no pre-made circuitry is being programmed orreused. ASIC designer may, or may not, even be aware of the locationsof various pieces of circuitry on the chip since the tools do much ofthe construction, placement and wiring of all the little pieces.
Full Custom, in contrast to ASIC (or Standard Cell), means thatevery geometric feature going onto the chip being designed (think ofthose pretty chip pictures we have all seen) is controlled, more orless, by the human design. Automated tools are certainly used to wireup different parts of the circuit and maybe even manipulate (repeat,rotate, etc.) sections of the chip. But, the human designer is activelyengaged with the physical features of the circuitry. Higher humancrafting and less reliance on standard cells takes more time andimplies higher NRE costs, but lowers RE costs for standard parts likememories, processors, uarts, etc.
FPGAs, or Field Programmable Gate Arrays are completely designedchips that designers load a programming pattern into to achieve aspecific digital function. A bit pattern (almost like a softwareprogram) is loaded into the already manufactured device whichessentially interconnects lots of available gates to meet the designerspurposes. FPGAs are sometimes thought of as a "Sea of Gates" where thedesigner specifies how they are connected. FPGA designers often usemany of the same tools that ASIC designers use, even though the FPGA isinherently more flexible. All these things can be intermixed in hybridsorts of ways. For example, FPGAs are now available that havemicroprocessor embedded within them which were designed in a fullcustom manner, all of which now demands "SoC" types of HW/SWintegration skills from the designer.
63)What is "Scan" ?
§Scan Insertion and ATPG helps test ASICs (e.g. chips) duringmanufacture. If you know what JTAG boundary scan is, then Scan is thesame idea except that it is done inside the chip instead of on theentire board. Scan tests for defects in the chip's circuitry after itis manufactured (e.g. Scan does not help you test whether your Designfunctions as intended). ASIC designers usually implement the scanthemselves and occurs just after synthesis. ATPG (Automated TestPattern Generation) refers to the creation of "Test Vectors" that theScan circuitry enables to be introduced into the chip. Here's a briefsummary:
· Scan Insertion is done by a tool and results in all (or most) ofyour design's flip-flops to be replaced by special "Scan Flip-flops".Scan flops have additional inputs/outputs that allow them to beconfigured into a "chain" (e.g. a big shift register) when the chip isput into a test mode.
· The Scan flip-flops are connected up into a chain (perhaps multiple chains)
· The ATPG tool, which knows about the scan chain you've created, generates a series of test vectors.
· The ATPG test vectors include both "Stimulus" and "Expected" bitpatterns. These bit vectors are shifted into the chip on the scanchains, and the chips reaction to the stimulus is shifted back outagain.
· The ATE (Automated Test Equipment) at the chip factory can put thechip into the scan test mode, and apply the test vectors. If anyvectors do not match, then the chip is defective and it is thrown away.
· Scan/ATPG tools will strive to maximize the "coverage" of the ATPGvectors. In other words, given some measure of the total number ofnodes in the chip that could be faulty (shorted, grounded, "stuck at1", "stuck at 0"), what percentage of them can be detected with theATPG vectors? Scan is a good technology and can achive high coverage inthe 90% range.
· Scan testing does not solve all test problems. Scan testing typicallydoes not test memories (no flip-flops!), needs a gate-level netlist towork with, and can take a long time to run on the ATE.
· FPGA designers may be unfamiliar with scan since FPGA testing hasalready been done by the FPGA manufacturer. ASIC designers do not havethis luxury and must handle all the manufacturing test detailsthemselves.
· Check out the Synopsys WWW site for more info.
1) Write a verilog code to swap contents of two registers with and without a temporary register?
With temp reg ;
always @ (posedge clock)
begin
temp=b;
b=a;
a=temp;
end
Without temp reg;
begin
a <= b; b <= a; end 2) Difference between blocking andnon-blocking?(Verilog interview questions that is most commonly asked)
The Verilog language has two forms of the procedural assignmentstatement: blocking and non-blocking. The two are distinguished by the= and <= assignment operators. The blocking assignment statement (=operator) acts much like in traditional programming languages. Thewhole statement is done before control passes on to the next statement.The non-blocking (<= operator) evaluates all the right-hand sidesfor the current time unit and assigns the left-hand sides at the end ofthe time unit. For example, the following Verilog program // testingblocking and non-blocking assignment module blocking; reg [0] A, B;initial begin: init1 A = 3; #1 A = A + 1; // blocking proceduralassignment B = A + 1; $display("Blocking: A= %b B= %b", A, B ); A = 3;#1 A <= A + 1; // non-blocking procedural assignment
B <= A + 1; #1 $display("Non-blocking: A= %b B= %b", A, B );end endmodule produces the following output: Blocking: A= 00000100 B=00000101 Non-blocking: A= 00000100 B= 00000100 The effect is for allthe non-blocking assignments to use the old values of the variables atthe beginning of the current time unit and to assign the registers newvalues at the end of the current time unit. This reflects how registertransfers occur in some hardware systems. blocking proceduralassignment is used for combinational logic and non-blocking proceduralassignment for sequential
Click to view more
Difference between task and function?
Function:
A function is unable to enable a task however functions can enable other functions.
A function will carry out its required duty in zero simulationtime. ( The program time will not be incremented during the functionroutine)
Within a function, no event, delay or timing control statements are permitted
In the invocation of a function their must be at least one argument to be passed.
Functions will only return a single value and can not use either output or inout statements.
Tasks:
Tasks are capable of enabling a function as well as enabling other versions of a Task
Tasks also run with a zero simulation however they can if required be executed in a non zero simulation time.
Tasks are allowed to contain any of these statements.
A task is allowed to use zero or more arguments which are of type output, input or inout.
A Task is unable to return a value but has the facility to pass multiple values via the output and inout statements .
4) Difference between inter statement and intra statement delay?
//define register variables
reg a, b, c;
//intra assignment delays
initial
begin
a = 0; c = 0;
b = #5 a + c; //Take value of a and c at the time=0, evaluate
//a + c and then wait 5 time units to assign value
//to b.
end
//Equivalent method with temporary variables and regular delay control
initial
begin
a = 0; c = 0;
temp_ac = a + c;
#5 b = temp_ac; //Take value of a + c at the current time and
//store it in a temporary variable. Even though a and c
//might change between 0 and 5,
//the value assigned to b at time 5 is unaffected.
end
5) What is delta simulation time?
6) Difference between $monitor,$display & $strobe?
These commands have the same syntax, and display text on the screenduring simulation. They are much less convenient than waveform displaytools like cwaves?. $display and $strobe display once every time theyare executed, whereas $monitor displays every time one of itsparameters changes.
The difference between $display and $strobe is that $strobedisplays the parameters at the very end of the current simulation timeunit rather than exactly where it is executed. The format string islike that in C/C++, and may contain format characters. Formatcharacters include %d (decimal), %h (hexadecimal), %b (binary), %c(character), %s (string) and %t (time), %m (hierarchy level). %5d, %5betc. would give exactly 5 spaces for the number instead of the spaceneeded. Append b, h, o to the task name to change default format tobinary, octal or hexadecimal.
Syntax:
$display ("format_string", par_1, par_2, ... );
$strobe ("format_string", par_1, par_2, ... );
$monitor ("format_string", par_1, par_2, ... );
7) What is difference between Verilog full case and parallel case?
A "full" case statement is a case statement in which all possiblecase-expression binary patterns can be matched to a case item or to acase default. If a case statement does not include a case default andif it is possible to find a binary case expression that does not matchany of the defined case items, the case statement is not "full."
A "parallel" case statement is a case statement in which it is onlypossible to match a case expression to one and only one case item. Ifit is possible to find a case expression that would match more than onecase item, the matching case items are called "overlapping" case itemsand the case statement is not "parallel."
What is meant by inferring latches,how to avoid it?
Consider the following :
always @(s1 or s0 or i0 or i1 or i2 or i3)
case ({s1, s0})
2'd0 : out = i0;
2'd1 : out = i1;
2'd2 : out = i2;
endcase
in a case statement if all the possible combinations are notcompared and default is also not specified like in example above alatch will be inferred ,a latch is inferred because to reproduce theprevious value when unknown branch is specified.
For example in above case if {s1,s0}=3 , the previous stored value is reproduced for this storing a latch is inferred.
The same may be observed in IF statement in case an ELSE IF is not specified.
To avoid inferring latches make sure that all the cases are mentioned if not default condition is provided.
9) Tell me how blocking and non blocking statements get executed?
Execution of blocking assignments can be viewed as a one-step process:
1. Evaluate the RHS (right-hand side equation) and update the LHS(left-hand side expression) of the blocking assignment withoutinterruption from any other Verilog statement. A blocking assignment"blocks" trailing assignments in the same always block from occurringuntil after the current assignment has been completed
Execution of nonblocking assignments can be viewed as a two-step process:
1. Evaluate the RHS of nonblocking statements at the beginning ofthe time step. 2. Update the LHS of nonblocking statements at the endof the time step.
10) Variable and signal which will be Updated first?
Signals
11) What is sensitivity list?
The sensitivity list indicates that when a change occurs to any oneof elements in the list change, begin…end statement inside that alwaysblock will get executed.
12) In a pure combinational circuit is it necessary to mention all the inputs in sensitivity disk? if yes, why?
Yes in a pure combinational circuit is it necessary to mention allthe inputs in sensitivity disk other wise it will result in pre andpost synthesis mismatch.
13) Tell me structure of Verilog code you follow?
A good template for your Verilog file is shown below.
// timescale directive tells the simulator the base units and precision of the simulation
`timescale 1 ns / 10 ps
module name (input and outputs);
// parameter declarations
parameter parameter_name = parameter value;
// Input output declarations
input in1;
input in2; // single bit inputs
output [msb] out; // a bus output
// internal signal register type declaration - register types (only assigned within always statements). reg register variable 1;
reg [msb] register variable 2;
// internal signal. net type declaration - (only assigned outside always statements) wire net variable 1;
// hierarchy - instantiating another module
reference name instance name (
.pin1 (net1),
.pin2 (net2),
.pinn (netn)
// synchronous procedures
begin
end
// combinatinal procedures
always @ (signal1 or signal2 or signal3)
begin
end
assign net variable = combinational logic;
endmodule
14) Difference between Verilog and vhdl?
Compilation
VHDL. Multiple design-units (entity/architecture pairs), thatreside in the same system file, may be separately compiled if sodesired. However, it is good design practice to keep each design unitin it's own system file in which case separate compilation should notbe an issue.
Verilog. The Verilog language is still rooted in it's nativeinterpretative mode. Compilation is a means of speeding up simulation,but has not changed the original nature of the language. As a resultcare must be taken with both the compilation order of code written in asingle file and the compilation order of multiple files. Simulationresults can change by simply changing the order of compilation.
Data types
VHDL. A multitude of language or user defined data types can beused. This may mean dedicated conversion functions are needed toconvert objects from one type to another. The choice of which datatypes to use should be considered wisely, especially enumerated(abstract) data types. This will make models easier to write, clearerto read and avoid unnecessary conversion functions that can clutter thecode. VHDL may be preferred because it allows a multitude of languageor user defined data types to be used.
Verilog. Compared to VHDL, Verilog data types a re very simple,easy to use and very much geared towards modeling hardware structure asopposed to abstract hardware modeling. Unlike VHDL, all data types usedin a Verilog model are defined by the Verilog language and not by theuser. There are net data types, for example wire, and a register datatype called reg. A model with a signal whose type is one of the netdata types has a corresponding electrical wire in the implied modeledcircuit. Objects, that is signals, of type reg hold their value oversimulation delta cycles and should not be confused with the modeling ofa hardware register. Verilog may be preferred because of it'ssimplicity.
Design reusability
VHDL. Procedures and functions may be placed in a package so thatthey are avail able to any design-unit that wishes to use them.
Verilog. There is no concept of packages in Verilog. Functions andprocedures used within a model must be defined in the module. To makefunctions and procedures generally accessible from different modulestatements the functions and procedures must be placed in a separatesystem file and included using the `include compiler directive.
15) What are different styles of Verilog coding I mean gate-level,continuous level and others explain in detail?
16) Can you tell me some of system tasks and their purpose?
$display, $displayb, $displayh, $displayo, $write, $writeb, $writeh, $writeo.
The most useful of these is $display.This can be used for displaying strings, expression or values of variables.
Here are some examples of usage.
$display("Hello oni");
--- output: Hello oni
$display($time) // current simulation time.
--- output: 460
counter = 4'b10;
$display(" The count is %b", counter);
--- output: The count is 0010
$reset resets the simulation back to time 0; $stop halts the simulator and puts it in interactive mode where the
user can enter commands; $finish exits the simulator back to the operating system
17) Can you list out some of enhancements in Verilog 2001?
In earlier version of Verilog ,we use 'or' to specify more than oneelement in sensitivity list . In Verilog 2001, we can use comma asshown in the example below.
// Verilog 2k example for usage of comma
always @ (i1,i2,i3,i4)
Verilog 2001 allows us to use star in sensitive list instead oflisting all the variables in RHS of combo logics . This removes typomistakes and thus avoids simulation and synthesis mismatches,
Verilog 2001 allows port direction and data type in the port list of modules as shown in the example below
module memory (
input r,
input wr,
input [7] data_in,
input [3] addr,
output [7] data_out
18)Write a Verilog code for synchronous and asynchronous reset?
Synchronous reset, synchronous means clock dependent so reset must not be present in sensitivity disk eg:
always @ (posedge clk )
begin if (reset)
. . . end
Asynchronous means clock independent so reset must be present in sensitivity list.
Eg
Always @(posedge clock or posedge reset)
begin
if (reset)
. . . end
19) What is pli?why is it used?
Programming Language Interface (PLI) of Verilog HDL is a mechanismto interface Verilog programs with programs written in C language. Italso provides mechanism to access internal databases of the simulatorfrom the C program.
PLI is used for implementing system calls which would have beenhard to do otherwise (or impossible) using Verilog syntax. Or, in otherwords, you can take advantage of both the paradigms - parallel andhardware related features of Verilog and sequential flow of C - usingPLI.
20) There is a triangle and on it there are 3 ants one on eachcorner and are free to move along sides of triangle what is probabilitythat they will collide?
Ants can move only along edges of triangle in either of direction,let's say one is represented by 1 and another by 0, since there are 3sides eight combinations are possible, when all ants are going in samedirection they won't collide that is 111 or 000 so probability ofcollision is 2/8=1/4
21) Tell me about file I/O?
21)What is difference between freeze deposit and force?
$deposit(variable, value);
This system task sets a Verilog register or net to the specified value. variable is the
register or net to be changed; value is the new value for the register or net. The value
remains until there is a subsequent driver transaction or another $deposit task for the
same register or net. This system task operates identically to the ModelSim
force -deposit command.
The force command has -freeze, -drive, and -deposit options. When none of these is
specified, then -freeze is assumed for unresolved signals and -drive is assumed for resolved
signals. This is designed to provide compatibility with force files. But if you prefer -freeze
as the default for both resolved and unresolved signals.
Verilog interview Questions
22)Will case infer priority register if yes how give an example?
yes case can infer priority register depending on coding style
reg r;
// Priority encoded mux,
always @ (a or b or c or select2)
begin
r = c;
case (select2)
2'b00: r = a;
2'b01: r = b;
endcase
end
23)Casex,z difference,which is preferable,why?
CASEZ :
Special version of the case statement which uses a Z logic value to represent don't-care bits. CASEX :
Special version of the case statement which uses Z or X logic values to represent don't-care bits.
CASEZ should be used for case statements with wildcard don't cares,otherwise use of CASE is required; CASEX should never be used.
This is because:
Don't cares are not allowed in the "case" statement. Thereforecasex or casez are required. Casex will automatically match any x or zwith anything in the case statement. Casez will only match z's -- x'srequire an absolute match.
24)Given the following Verilog code, what value of "a" is displayed?
always @(clk) begin
a = 0;
a <= 1; $display(a); end This is a tricky one! Verilogscheduling semantics basically imply a four-level deep queue for thecurrent simulation time: 1: Active Events (blocking statements) 2:Inactive Events (#0 delays, etc) 3: Non-Blocking Assign Updates(non-blocking statements) 4: Monitor Events ($display, $monitor, etc).Since the "a = 0" is an active event, it is scheduled into the 1st"queue". The "a <= 1" is a non-blocking event, so it's placed intothe 3rd queue. Finally, the display statement is placed into the 4thqueue. Only events in the active queue are completed this sim cycle, sothe "a = 0" happens, and then the display shows a = 0. If we were tolook at the value of a in the next sim cycle, it would show 1. 25) Whatis the difference between the following two lines of Verilog code?
#5 a = b;
a = #5 b;
#5 a = b; Wait five time units before doing the action for "a = b;".
a = #5 b; The value of b is calculated and stored in an internaltemp register,After five time units, assign this stored value to a.
26)What is the difference between:
c = foo ? a : b;
and
if (foo) c = a;
else c = b;
The ? merges answers if the condition is "x", so for instance iffoo = 1'bx, a = 'b10, and b = 'b11, you'd get c = 'b1x. On the otherhand, if treats Xs or Zs as FALSE, so you'd always get c = b.
27)What are Intertial and Transport Delays ??
28)What does `timescale 1 ns/ 1 ps signify in a verilog code?
'timescale directive is a compiler directive.It is used to measure simulation time or delay time. Usage : `timescale
34)what is verilog case (1) ?
wire [3] x;
always @(...) begin
case (1'b1)
x[0]: SOMETHING1;
x[1]: SOMETHING2;
x[2]: SOMETHING3;
x[3]: SOMETHING4;
endcase
end
The case statement walks down the list of cases and executes thefirst one that matches. So here, if the lowest 1-bit of x is bit 2,then something3 is the statement that will get executed (or selected bythe logic).
35) Why is it that "if (2'b01 & 2'b10)..." doesn't run the true case?
This is a popular coding error. You used the bit wise AND operator(&) where you meant to use the logical AND operator (&&).
36)What are Different types of Verilog Simulators ?
There are mainly two types of simulators available.
Event Driven
Cycle Based
Event-based Simulator:
This Digital Logic Simulation method sacrifices performance for richfunctionality: every active signal is calculated for every device itpropagate ......... |
