在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 32882|回复: 107
(已解决)SPECTRE 211所支持新的FX仿真器FEATURE
发表于 2021-9-19 05:08:22 | 显示全部楼层 |阅读模式
论坛的各位大佬们,请问一下SPECTRE 211是采用了新的FEATURE吗,仿真的时候显示waiting for license。但是使用SPECTRE 151,181的时候就没有问题,可以正常仿真。能否自己生成FEATRUE,但是我也不知道SPECTRE 211所需要的FEATURE名字。另外是否需要在环境变量中添加新的变量?
调用SPECTRE 211进行tran仿真出现的问题
tran仿真的界面
tran仿真的界面
 楼主| 发表于 2021-9-19 05:12:03 | 显示全部楼层
我的仿真平台是:
发表于 2021-9-19 12:32:52 | 显示全部楼层
Unfortunately, I do not use graphics mode to set up / run the simulation, so I cannot tell if there is an option to select FX simulation in a simple ADE_L. (by analogy with Spectre_X, this option could be transferred to ADE_Explorer).
To use FastSPICE, you must add these features to your license file:
spectre_FX_sc
Spectre_FX_sc_kernel
Also, just in case, make sure you have all the other Spectre features:
Virtuoso_Multi_mode_Simulation
Virtuoso_Spectre_GXL_MMSIM_Lk
Virtuoso_APS_MMSIM_Lk
Virtuoso_XPS_MMSIM_Lk
Virtuoso_MMSIM_CPU_Accelerator
Virtuoso_Spectre_X_MMSIM_Lk
Spectre_X_MMSIM_Lk
spectre_X_sc
spectre_X_cpu_accelerator
发表于 2021-9-19 17:19:39 | 显示全部楼层
shindziharan 发表于 2021-9-19 12:32
Unfortunately, I do not use graphics mode to set up / run the simulation, so I cannot tell if there  ...
Having added the two features you mentioned, I still got the license check out error saying required license could not be checked out.
In the license log file, it says it has checked out virtuoso_spectre and virtuoso_multi_mode_simulation features, not complaining anything to do with spectre_fx feature. Apparently it still couldn't run Spectre21.
Tried to re-read the modified license file with the two added features, it seems they do not get read in at all as shown in the log file.
Any help?
发表于 2021-9-19 17:36:26 | 显示全部楼层
Spectre_FX_cpu_accelerator
spectre_FX_sc
发表于 2021-9-19 17:46:05 | 显示全部楼层
spectre_FX_sc
The same happened.
发表于 2021-9-19 18:50:09 | 显示全部楼层
before
after
发表于 2021-9-19 19:09:22 来自手机 | 显示全部楼层
amodaman 发表于 2021-9-19 17:19
Having added the two features you mentioned, I still got the license check out error saying requ ...
首先,那几个feature 是没问题的。其次,C家20版以后的和谐方法和18版不一样……你这是和谐不成功。
发表于 2021-9-19 21:45:11 | 显示全部楼层
kankan
 楼主| 发表于 2021-9-19 23:24:02 | 显示全部楼层
hitzhabc 发表于 2021-9-19 19:09
首先,那几个feature 是没问题的。其次,C家20版以后的和谐方法和18版不一样……你这是和谐不成功。 ...
您好,请问一下20之后的和谐方法能否提供一下某度链接
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-17 05:11 , Processed in 0.042529 second(s), 6 queries , Gzip On, Redis On.
