在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
EETOP诚邀模拟IC相关培训讲师 创芯人才网--重磅上线啦!
查看: 3125|回复: 7
[转贴] Nuhertz Filter Solutions 2019 version 16.3.6 fixed
发表于 2021-8-8 11:01:48 | 显示全部楼层 |阅读模式
https://downloadly.net/2020/15/5074/03/filter-solutions/12/?#/5074-nuhertz-072108082008.html
2021.08.07 at 6:09 pmEngineering specialized
Filter Solutions, Filter Solutions crack, Filter Solutions crack download, Filter Solutions download, Filter Solutions free, Filter Solutions free download, Filter Solutions full crack, Filter Solutions patch
Description
Filter Solutions is a product of Nuhertz Technology, a comprehensive software package for the design, analysis and synthesis of electronic filters. The company is one of the leaders in analyzing and analyzing low-pass and high-pass filters, Filter Solutions provides capacitors, switches, active and passive synthesizers and has the ability to analyze parasitic effects. It is also possible to design IIR and FIR filters in C language. Filter design modules This application is used by electronic engineers in a variety of fields including telecommunication systems, military electronics, medicine, instrumentation, oil exploration and antenna design, as well as IC, MMIC and RFIC design. Passive Filter, Distributed Filter, Active Filter, Digital Filter, Switched Capacitor, and Zmatch ما modules are available in this application. Using these modules you have everything you need to design and synthesize electronic filters.
Features and Features of Filter Solutions Software:
  • Elliptical filtering, hourglass, chapishev one and two and bastros, etc.
  • Accurate and efficient synthesizer
  • Ability to design high pass, low pass, mid pass, mid pass filters
  • Ability to modify active, inactive, and distributed components
  • Ability to use Duplexers and Trlexers
  • Custom design based on S and Z values ​​entered by the user
  • Multi-band design for low-pass, high-pass, mid-pass and mid-pass filters with different parameters for each band individually designed
  • Supports conversions of Coruda, Richardson, Norton
  • S parameter analysis and time analysis for passive and distributive design
  • Analyzing user time data
  • Phase deviation analysis and batch delays
  • Monte Carlo analysis
  • Ability to export to AWRCorp tools
  • Ability to send DXF output for AutoCAD software
  • Output for Sonnet software
  • And…
required system
Windows 7 / 8.1 / 10
[size=1.7]Installation guide
After installing, copy and paste the file in the Crack folder where the program is installed.
Run the program and in the license activation window, enter the phrase test for both the username and password values.
Version 16.3.6 was installed and successfully activated on August 7, 2021 on Windows 10 64-bit version.
发表于 2021-8-8 18:39:05 | 显示全部楼层
dakadaka
发表于 2021-8-15 22:22:54 | 显示全部楼层
看看看
发表于 2021-9-5 19:50:41 | 显示全部楼层
16.7 with all Export (such as sonnet export).
 楼主| 发表于 2021-9-5 21:17:38 | 显示全部楼层
发表于 2021-9-19 09:31:48 | 显示全部楼层
hi_china59 发表于 2021-9-5 21:17
https://downloadly.net/2020/15/5074/03/filter-solutions/12/?#/5074-nuhertz-172146095705.html
There is no addon/ output extension for Sonnet Suites of this.
发表于 2021-11-26 10:54:03 | 显示全部楼层
下载不了
发表于 2024-3-23 23:18:10 | 显示全部楼层
thanks for sharing
站长推荐 上一条 /3 下一条
GMT+8, 2024-4-19 20:13 , Processed in 0.025088 second(s), 6 queries , Gzip On, Redis On.
