请教一下各位前辈,这些drc那些是真错,然后大致的修复方法是什么?check-routes报出来的。 @@@@@@@ TOTAL VIOLATIONS = 48752
Convex metal cut enclosure : 136
Dense end of line enclosure : 13
Diff net spacing : 1967
Diff net var rule spacing : 299
Diff net via-cut spacing : 1353
Enclosed via spacing : 29
End of line spacing : 11236
Fat wire via keepout enclosure : 293
Less than minimum area : 930
Less than minimum edge length : 178
Less than minimum enclosed area : 4
Less than minimum width : 6
Less than NDR width : 9
MisAligned via wire : 1265
Needs fat contact on extension : 118
Same net spacing : 79
Same net via-cut spacing : 27
Short : 30531
Special notch spacing : 86
Wide Metal Jog : 193
