- ;;create software root directory
- sudo mkdir /software && sudo chmod 777 /software
- mkdir /software/eda/cadence
- ;;Enable 32bit repo
- sudo dpkg --add-architecture i386
- sudo apt update
- sudo apt upgrade
- ;;Clean shared lib error/warning while run iscape.sh
- ;;Tips
- ;; "apt" always use lower case to search the package, so if system missing some lib,
- ;; use the libname(lowerCase,without .so.*)+libversion(number)+[:i386](for 32bit) to install.
- ;; "yum/cnf" use libName(with .so.*)+[i686](for 32bit)
- ;; if some use uppercase, cannot find package.
- sudo apt install openjdk-11-jdk
- sudo apt install libc6:i386
- sudo apt install libxext6:i386
- sudo apt install libxtst6:i386
- ;;Install xterm for configture window
- sudo apt install xterm
- ;;install package for IC, $CDSHOME is IC root install directory
- Error:
- bash: $CDSHOME/bin/virtuoso: /bin/ksh: bad interpreter: No such file or directory
- Solution:
- sudp apt install ksh
- Error:
- bash: $CDSHOME/tools.lnx86/bin/checkSysConf: /bin/csh: bad interpreter: No such file or directory
- Solution:
- apt install csh
- Error:
- $CDSHOME/share/oa/bin/sysname: 209: $CDSHOME/share/oa/bin/sysname: [[: not found
- $CDSHOME/share/oa/bin/sysname: 243: $CDSHOME/share/oa/bin/sysname: [[: not found
- virtuoso: ERROR: The OA2.2 library directory ($CDSHOME/share/oa/lib/linux_64/opt) does not seem to exist.
- virtuoso: INFO: Note that OpenAccess (OA) requires running the Configure phase.
- virtuoso: See the "OpenAccess Installation and Configuration Guide" before
- virtuoso: you complete the configuration step. This manual is included with
- virtuoso: the Cadence product documentation.
- Solution:
- ;;Solve "OA2.2 not found"
- mv $CDSHOME/oa_v22.60.043/lib/linux_rhel60_64/ $CDSHOME/oa_v22.60.043/lib/linux_64/
- ;;set env
- export OA_UNSUPPORTED_PLAT=linux_rhel60
- export W3264_NO_HOST_CHECK=1
- ;;Solve "[[: not found", this is tools script bug, used wrong expression
- sed -i "s/\[\[/\[/g;s/\]\]/\]/g" $CDSHOME/share/oa/bin/sysname
- Error:
- $CDSHOME/tools.lnx86/dfII/bin/64bit/virtuoso: error while loading shared libraries: libcrypto.so.10: cannot open shared object file: No such file or directory
- $CDSHOME/tools.lnx86/dfII/bin/64bit/virtuoso: error while loading shared libraries: libssl.so.10: cannot open shared object file: No such file or directory
- Solution:
- ;;set env:
- export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/lib:/usr/lib/x86_64-linux-gnu:/software/ocad/share/lib64
- Error:
- $CDSHOME/tools.lnx86/dfII/bin/64bit/virtuoso: error while loading shared libraries: libaprutil-1.so.0: cannot open shared object file: No such file or directory
- Solution:
- sudo apt install libaprutil1-dev
- Error:
- $CDSHOME/tools.lnx86/dfII/bin/64bit/virtuoso: error while loading shared libraries: libdb-4.7.so: cannot open shared object file: No such file or directory
- Solution:
- sudo apt install libdb-dev
- sudo ln -s /lib/x86_64-linux-gnu/libdb-5.3.so /lib/x86_64-linux-gnu/libdb-4.7.so
复制代码 附件包含了debian系系统缺失的一些lib,加载到LD_LIBRARY_PATH变量中即可。后续会放虚拟机出来
更新:解决debian系系统无法启动lmgrd的错误
Error:
bash: lmgrd: No such file or directory
Solution:
use "file" command check the interpreter of lmgrd, return:
lmgrd: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-lsb-x86-64.so.3, for GNU/Linux 2.6.18, stripped
search "/lib64/ld-lsb-x86-64.so.3" in redhat6/7, find it is a symbol link of "/lib64/ld-lsb-x86-64.so.3",so:
sudo apt install lsb-release
sudo ln -s /lib64/ld-linux-x86-64.so.2 /lib64/ld-lsb-x86-64.so.3
ocad.zip
10.64 MB, 下载次数: 211
, 下载积分:
资产 -4 信元, 下载支出 4 信元
