发表于 2021-1-19 17:03:43
显示全部楼层
set_path_margin
Specifies a margin to adjust required times for paths in the
current design.
DESCRIPTION
This command adjusts the data required time for specified paths by a
specified amount, margin_value. The required time for any startpoint in
from_list to any endpoint in to_list is adjusted by margin_value. A
positive margin value results in a more restrictive or tighter check,
whereas a negative margin value results in a less restrictive or looser
check. Based on the type of timing constraint, either setup or hold,
the margin value is either subtracted from or added to the default data
required time.
The set_path_margin command is a point-to-point timing exception com-
mand; that is, it adjusts the required time of the path and hence the
endpoint slack for the timing paths.
EXAMPLES
The following example shows how to adjust the required time to a port
named Y by 10 units. The adjustment results in a more restrictive,
tighter timing constraint because the margin value is positive.
prompt> set_path_margin 10.0 -to {Y}
This example shows how to specify that the required time of all paths
from cell ff1a or ff1b that pass through cell u1 and end at cell ff2e
must be adjusted by 15.0 units.
prompt> set_path_margin 15.0 -from {ff1a ff1b} -through {u1} -to {ff2e}
This example shows how to specify that all paths to endpoints clocked
by PHI2 must be adjusted by 8.5 units.
prompt> set_path_margin 8.5 -to [get_clocks PHI2]
This example specifies that all timing paths from pin ff1/CP to pin
ff2/D that rise through at least one of pins U1/Z and U2/Z and fall
through at least one of pins U3/Z and U4/C must be adjusted by 8.0
units.
prompt> set_path_margin 8.0 -from {ff1/CP} -to {ff2/D} \
-rise_through {U1/Z U2/Z} -fall_through {U3/Z U4/C}
