新建的设计库以reference参考库和工艺技术文件为依托,咋就不一致了?
icc_shell> create_mw_lib -technology /mylab/IC_Compiler_2010.12-SP2/ref/tech/cb13_6m.tf -mw_reference_library {/mylab/IC_Compiler_2010.12-SP2/ref/mw_lib/sc /mylab/IC_Compiler_2010.12-SP2/ref/mw_lib/io /mylab/IC_Compiler_2010.12-SP2/ref/mw_lib/ram16x128} -bus_naming_style {[%d]} -open /mylab/IC_Compiler_2010.12-SP2/lab1_data_setup/risc_chip.mw
Start to load technology file /mylab/IC_Compiler_2010.12-SP2/ref/tech/cb13_6m.tf.
Warning: Layer 'PRODUM' is missing the attribute 'minSpacing'. (line 312) (TFCHK-014)
Warning: Layer 'PRODUM' is missing the attribute 'minWidth'. (line 312) (TFCHK-014)
Warning: CapModel sections are missing. Capacitance models should be loaded with a TLU+ file later. (TFCHK-084)
Technology file /mylab/IC_Compiler_2010.12-SP2/ref/tech/cb13_6m.tf has been loaded successfully.
Warning: Reference Library Inconsistent With Main Library
Reference Library: /mylab/IC_Compiler_2010.12-SP2/ref/mw_lib/sc (MWLIBP-300)
Warning: Inconsistent Number Of Metal Layers:
6 (Main Library) <==> 4 (Reference Library). (MWLIBP-301)
Warning: Inconsistent Data for Contact Code 1
Main Library (risc_chip.mw) | Reference Library (sc)
Lower Layer METAL (55, 10) | METAL (65, 10) (MWLIBP-324)
Warning: Inconsistent Data for Contact Code 2
Lower Layer METAL (10, 55) | METAL (10, 65) (MWLIBP-324)
Warning: Inconsistent Data for Contact Code 4
Cut Layer VIA3 (190, 190) | VIA3 (400, 400)
Lower Layer METAL3 (65, 5) | METAL3 (50, 10)
Upper Layer METAL4 (5, 50) | METAL4 (90, 90) (MWLIBP-324)
Warning: Inconsistent Data for Contact Code 11
Cut Layer VIA3 (190, 190) | VIA3 (400, 400) (MWLIBP-324)
Warning: Inconsistent Data for Contact Code 12
Cut Layer VIA4 (400, 400) | CONT (400, 400)
Lower Layer METAL4 (200, 200) | CP (200, 200)
Upper Layer METAL5 (200, 200) | METAL (200, 200) (MWLIBP-324)
Reference Library: /mylab/IC_Compiler_2010.12-SP2/ref/mw_lib/io (MWLIBP-300)
Main Library (risc_chip.mw) | Reference Library (io)
Reference Library: /mylab/IC_Compiler_2010.12-SP2/ref/mw_lib/ram16x128 (MWLIBP-300)
Main Library (risc_chip.mw) | Reference Library (ram16x128)
{risc_chip.mw}
